[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-767-gaebf89db1
Fri May 5 15:02:59 PDT 2023
the project "PostGIS".
       via  aebf89db170d4dfb9aee4b445c2f7958f1d90592 (commit)
      from  cd68a9dfcf940025b1da085425ff61236b329334 (commit)
revisions in full, below.
commit aebf89db170d4dfb9aee4b445c2f7958f1d90592
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat May 6 00:02:43 2023 +0200
    Quote more ...
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 9b3db4e20..20963c959 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -346,7 +346,7 @@ EOF
     print "Executor slow factor: $test_executor_slow_factor ($ms_to_fetch_full_version ms to fetch full version)\n";
-    sql("ALTER DATABASE \"$DB\" SET test.executor_slow_factor = $test_executor_slow_factor");
+    sql("ALTER DATABASE \\\"$DB\\\" SET test.executor_slow_factor = $test_executor_slow_factor");
 compute_executor_slow_factor;
Summary of changes:
 regress/run_test.pl | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
