[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-804-ge1ae681ae
Fri May 12 06:00:30 PDT 2023
the project "PostGIS".
       via  e1ae681ae1888daa08dca0fcd4775cfe39572777 (commit)
       via  a4d7c1e9c7e0527d199fb09661c7be0bc4e6add6 (commit)
       via  860a4aafd9ed72d3b2de6b1f209b14602b9d5117 (commit)
       via  8a7471598c2db71ba130c687fe570f02c4a4a018 (commit)
      from  ad81538a23e4126cae79678f6fcb4cfbb5fd855d (commit)
revisions in full, below.
commit e1ae681ae1888daa08dca0fcd4775cfe39572777
Author: Vincent Bre <vincent.bre at oslandia.com>
Date:   Fri May 12 10:11:55 2023 +0000
    Translated using Weblate (French)
    Currently translated at 10.8% (70 of 644 strings)
    Translation: postgis/extras_topology.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_topologyxml/fr/
diff --git a/doc/po/fr/extras_topology.xml.po b/doc/po/fr/extras_topology.xml.po
index 05cb7e546..f689f90f2 100644
--- a/doc/po/fr/extras_topology.xml.po
+++ b/doc/po/fr/extras_topology.xml.po
@@ -13,7 +13,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-05-04 20:31+0000\n"
-"PO-Revision-Date: 2023-05-10 15:08+0000\n"
+"PO-Revision-Date: 2023-05-12 13:00+0000\n"
 "Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "extras_topologyxml/fr/>\n"
@@ -1517,7 +1517,7 @@ msgstr ""
 #: extras_topology.xml:818
 #, no-c-format
 msgid "Availability: 1.0.0"
-msgstr ""
+msgstr "Disponibilité : 1.0.0"
 #. Tag: para
 #: extras_topology.xml:820
@@ -5146,7 +5146,7 @@ msgstr ""
 #: extras_topology.xml:3555
 #, no-c-format
 msgid "ST_SRID"
-msgstr ""
+msgstr "ST_SRID"
 #. Tag: refpurpose
 #: extras_topology.xml:3556
@@ -5169,6 +5169,8 @@ msgid ""
 "Returns the spatial reference identifier for the ST_Geometry as defined in "
 "spatial_ref_sys table. <xref linkend=\"spatial_ref_sys\"/>"
 msgstr ""
+"Renvoie l'identifiant de référence spatiale pour la ST_Geometry tel que "
+"défini dans la table spatial_ref_sys. <xref linkend=\"spatial_ref_sys\"/>"
 #. Tag: para
 #: extras_topology.xml:3572
@@ -5179,6 +5181,11 @@ msgid ""
 "system to another. So verifying you have the right spatial reference system "
 "identifier is important if you plan to ever transform your geometries."
 msgstr ""
+"La table spatial_ref_sys est une table qui répertorie tous les systèmes de "
+"référence spatiale connus de PostGIS et qui est utilisée pour les "
+"transformations d'un système de référence spatiale à un autre. Il est donc "
+"important de vérifier que vous disposez du bon identifiant de système de "
+"référence spatiale si vous envisagez de transformer vos géométries."
 #. Tag: para
 #: extras_topology.xml:3576
commit a4d7c1e9c7e0527d199fb09661c7be0bc4e6add6
Date:   Fri May 12 10:51:09 2023 +0000
    Currently translated at 10.4% (168 of 1609 strings)
    Translation: postgis/reference_raster.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_rasterxml/fr/
diff --git a/doc/po/fr/reference_raster.xml.po b/doc/po/fr/reference_raster.xml.po
index 87054e782..4ceb373b8 100644
--- a/doc/po/fr/reference_raster.xml.po
+++ b/doc/po/fr/reference_raster.xml.po
@@ -8,7 +8,7 @@ msgstr ""
 "POT-Creation-Date: 2022-12-04 00:50+0000\n"
-"PO-Revision-Date: 2023-05-12 10:08+0000\n"
 "reference_rasterxml/fr/>\n"
@@ -4942,7 +4942,7 @@ msgstr ""
 #: reference_raster.xml:2699
 #, no-c-format
 msgid "ST_SRID"
-msgstr ""
+msgstr "ST_SRID"
 #. Tag: refpurpose
 #: reference_raster.xml:2700
@@ -8847,7 +8847,7 @@ msgstr ""
 #: reference_raster.xml:4672
 #, no-c-format
 msgid "ST_SetSRID"
-msgstr ""
+msgstr "ST_SetSRID"
 #. Tag: refpurpose
 #: reference_raster.xml:4674
@@ -9757,7 +9757,7 @@ msgstr ""
 #: reference_raster.xml:5155
 #, no-c-format
 msgid "ST_Transform"
-msgstr ""
+msgstr "ST_Transform"
 #. Tag: refpurpose
 #: reference_raster.xml:5156
commit 860a4aafd9ed72d3b2de6b1f209b14602b9d5117
Date:   Fri May 12 10:11:47 2023 +0000
    Currently translated at 100.0% (117 of 117 strings)
    Translation: postgis/reference_bbox.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_bboxxml/fr/
diff --git a/doc/po/fr/reference_bbox.xml.po b/doc/po/fr/reference_bbox.xml.po
index c7015b455..734c4b13c 100644
--- a/doc/po/fr/reference_bbox.xml.po
+++ b/doc/po/fr/reference_bbox.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "POT-Creation-Date: 2022-04-16 08:20+0000\n"
 "reference_bboxxml/fr/>\n"
@@ -357,18 +357,22 @@ msgid ""
 "function returns NULL. Prior to version 1.5.4 an exception was thrown "
 "instead."
 msgstr ""
+"En l'absence de statistiques (table vide ou pas d'ANALYZE), cette fonction "
+"renvoie NULL. Avant la version 1.5.4, une exception était levée."
 #. Tag: para
 #: reference_bbox.xml:160
 #, no-c-format
-msgstr ""
 #. Tag: para
 #: reference_bbox.xml:161
 #, no-c-format
 msgid "Changed: 2.1.0. Up to 2.0.x this was called ST_Estimated_Extent."
 msgstr ""
+"Modifié : 2.1.0. Jusqu'à la version 2.0.x, cette fonction était appelée "
+"ST_Estimated_Extent."
 #. Tag: programlisting
 #: reference_bbox.xml:170
@@ -382,18 +386,25 @@ msgid ""
 "--result--\n"
 "BOX(-124.659652709961 24.6830825805664,-67.7798080444336 49.0012092590332)"
 msgstr ""
+"SELECT ST_EstimatedExtent('ny', 'edges', 'geom') ;\n"
+"--résultat--\n"
+"BOX(-8877653 4912316,-8010225.5 5589284)\n"
+"\n"
+"SELECT ST_EstimatedExtent('feature_poly', 'geom') ;\n"
+"--résultat--\n"
+"BOX(-124.659652709961 24.6830825805664,-67.7798080444336 49.0012092590332)"
 #. Tag: para
 #: reference_bbox.xml:177
 #, no-c-format
 msgid ", <xref linkend=\"ST_3DExtent\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_3DExtent\"/>"
 #. Tag: refname
 #: reference_bbox.xml:183
 #, no-c-format
 msgid "ST_Expand"
-msgstr ""
+msgstr "ST_Expand"
 #. Tag: refpurpose
 #: reference_bbox.xml:184
@@ -401,6 +412,8 @@ msgstr ""
 msgid ""
 "Returns a bounding box expanded from another bounding box or a geometry."
 msgstr ""
+"Renvoie une boîte de délimitation développée à partir d'une autre boîte de "
+"délimitation ou d'une géométrie."
 #. Tag: funcsynopsis
 #: reference_bbox.xml:188
@@ -435,6 +448,33 @@ msgid ""
 "choice=\"opt\"><type>float</type> <parameter>dz=0</parameter></paramdef> </"
 "funcprototype>"
 msgstr ""
+"<funcprototype> <funcdef>geometry <function>ST_Expand</function></funcdef> "
+"<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef> "
+"<paramdef><type>float</type> <parameter>units_to_expand</parameter></"
+"paramdef> </funcprototype> <funcprototype> <funcdef>geometry "
+"<function>ST_Expand</function></funcdef> <paramdef><type>geometry </type> "
+"<parameter>geom</parameter></paramdef> <paramdef><type>float</type> "
+"<parameter>dx</parameter></paramdef> <paramdef><type>float</type> "
+"<parameter>dy</parameter></paramdef> <paramdef choice=\"opt\"><type>float</"
+"type> <parameter>dz=0</parameter></paramdef> <paramdef choice=\"opt\""
+"><type>float</type> <parameter>dm=0</parameter></paramdef> </funcprototype> "
+"<funcprototype> <funcdef>box2d <function>ST_Expand</function></funcdef> "
+"<paramdef><type>box2d </type> <parameter>box</parameter></paramdef> "
+"paramdef> </funcprototype> <funcprototype> <funcdef>box2d "
+"<function>ST_Expand</function></funcdef> <paramdef><type>box2d </type> "
+"<parameter>box</parameter></paramdef> <paramdef><type>float</type> "
+"<parameter>dy</parameter></paramdef> </funcprototype> <funcprototype> "
+"<funcdef>box3d <function>ST_Expand</function></funcdef> "
+"<paramdef><type>box3d </type> <parameter>box</parameter></paramdef> "
+"paramdef> </funcprototype> <funcprototype> <funcdef>box3d "
+"<function>ST_Expand</function></funcdef> <paramdef><type>box3d </type> "
+"type> <parameter>dz=0</parameter></paramdef> </funcprototype>"
 #. Tag: para
 #: reference_bbox.xml:236
@@ -446,6 +486,13 @@ msgid ""
 "precision. Can be used for distance queries, or to add a bounding box filter "
 "to a query to take advantage of a spatial index."
 msgstr ""
+"Renvoie une boîte de délimitation développée à partir de la boîte de "
+"délimitation de l'entrée, soit en spécifiant une distance unique avec "
+"laquelle la boîte doit être développée sur les deux axes, soit en spécifiant "
+"une distance de développement pour chaque axe. Utilise la double précision. "
+"Peut être utilisé pour les requêtes de distance, ou pour ajouter un filtre "
+"de boîte de délimitation à une requête afin de tirer parti d'un index "
+"spatial."
 #. Tag: para
 #: reference_bbox.xml:243
@@ -455,6 +502,9 @@ msgid ""
 "variants are provided that accept and return <xref linkend=\"box2d_type\"/> "
 "and <xref linkend=\"box3d_type\"/> data types."
 msgstr ""
+"Outre la version de ST_Expand acceptant et renvoyant une géométrie, des "
+"variantes sont fournies qui acceptent et renvoient des types de données "
+"<xref linkend=\"box2d_type\"/> et <xref linkend=\"box3d_type\"/>."
 #. Tag: para
 #: reference_bbox.xml:248
@@ -462,6 +512,8 @@ msgstr ""
 msgid ""
 "Distances are in the units of the spatial reference system of the input."
 msgstr ""
+"Les distances sont exprimées dans les unités du système de référence "
+"spatiale de l'entrée."
 #. Tag: para
 #: reference_bbox.xml:250
@@ -471,6 +523,9 @@ msgid ""
 "buffering expands a geometry in all directions, ST_Expand expands the "
 "bounding box along each axis."
 msgstr ""
+"ST_Expand est similaire à <xref linkend=\"ST_Buffer\"/>, mais alors que la "
+"mise en mémoire tampon étend une géométrie dans toutes les directions, "
+"ST_Expand étend la boîte de délimitation le long de chaque axe."
 #. Tag: para
 #: reference_bbox.xml:255
@@ -482,6 +537,12 @@ msgid ""
 "20)') < 10</code>. This has been replaced by the simpler and more "
 "efficient <xref linkend=\"ST_DWithin\"/> function."
 msgstr ""
+"Avant la version 1.3, ST_Expand était utilisé en conjonction avec <xref "
+"linkend=\"ST_Distance\"/> pour effectuer des requêtes de distance "
+"indexables. Par exemple, <code>geom && ST_Expand('POINT(10 20)', 10) "
+"AND ST_Distance(geom, 'POINT(10 20)') < 10</code>. Cette fonction a été "
+"remplacée par la fonction <xref linkend=\"ST_DWithin\"/>, plus simple et "
+"plus efficace."
 #. Tag: para
 #: reference_bbox.xml:260
@@ -490,6 +551,8 @@ msgid ""
 "Availability: 1.5.0 behavior changed to output double precision instead of "
 "float4 coordinates."
 msgstr ""
+"Disponibilité : 1.5.0 comportement modifié pour afficher les coordonnées en "
+"double précision au lieu des coordonnées float4."
 #. Tag: para
 #: reference_bbox.xml:262
@@ -498,6 +561,8 @@ msgid ""
 "Enhanced: 2.3.0 support was added to expand a box by different amounts in "
 "different dimensions."
 msgstr ""
+"Amélioration : 2.3.0 : prise en charge de l'expansion d'une boîte par "
+"différentes quantités dans différentes dimensions."
 #. Tag: para
 #: reference_bbox.xml:271
@@ -506,6 +571,8 @@ msgid ""
 "Examples below use US National Atlas Equal Area (SRID=2163) which is a meter "
 "projection"
 msgstr ""
+"Les exemples ci-dessous utilisent l'Atlas national américain Equal Area "
+"(SRID=2163) qui est une projection en mètres."
 #: reference_bbox.xml:272
@@ -534,24 +601,51 @@ msgid ""
 " SRID=2163;POLYGON((2312970 110666,2312970 110686,2312990 110686,2312990 "
 "110666,2312970 110666))"
 msgstr ""
+"<!-- TODO : corriger les résultats de la documentation pour refléter le "
+"nouveau comportement -->\n"
+"--Boîte élargie de 10 mètres autour de la bbox d'une linestring\n"
+"SELECT CAST(ST_Expand(ST_GeomFromText('LINESTRING(2312980 110676,2312923 "
+"110701,2312892 110714)', 2163),10) As box2d) ;\n"
+"                                         st_expand\n"
+"------------------------------------\n"
+" BOX(2312882 110666,2312990 110724)\n"
+"\n"
+"--Boîte 3D étendue de 10 mètres d'une boîte 3D\n"
+"SELECT ST_Expand(CAST('BOX3D(778783 2951741 1,794875 2970042.61545891 10)' "
+"As box3d),10)\n"
+"                                                          st_expand\n"
+"-----------------------------------------------------\n"
+" BOX3D(778773 2951731 -9,794885 2970052.61545891 20)\n"
+"\n"
+" --Géométrie de 10 mètres à l'extérieur d'une boîte étendue autour d'un "
+"point Géométrie de 10 mètres à l'extérieur d'une boîte étendue autour d'un "
+"point géométrique\n"
+" SELECT ST_AsEWKT(ST_Expand(ST_GeomFromEWKT('SRID=2163 ;POINT(2312980 "
+"110676)'),10)) ;\n"
+"           st_asewkt\n"
+"--------------------\n"
+" SRID=2163 ;POLYGON((2312970 110666,2312970 110686,2312990 110686,2312990 "
+"110666,2312970 110666))"
 #. Tag: para
 #: reference_bbox.xml:277
 #, no-c-format
 msgid ", <xref linkend=\"ST_DWithin\"/>, <xref linkend=\"ST_SRID\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_DWithin\"/>, <xref linkend=\"ST_SRID\"/>"
 #. Tag: refname
 #: reference_bbox.xml:283
 #, no-c-format
 msgid "ST_Extent"
-msgstr ""
+msgstr "ST_Extent"
 #. Tag: refpurpose
 #: reference_bbox.xml:284
 #, no-c-format
 msgid "Aggregate function that returns the bounding box of geometries."
-msgstr ""
+msgstr "Fonction agrégée qui renvoie la boîte de délimitation des géométries."
 #. Tag: funcprototype
 #: reference_bbox.xml:289
@@ -561,6 +655,9 @@ msgid ""
 "<paramdef><type>geometry set</type> <parameter>geomfield</parameter></"
 "paramdef>"
 msgstr ""
+"<funcdef>box2d <function>ST_Extent</function></funcdef> "
+"<paramdef><type>geometry set</type> "
+"<parameter>geomfield</parameter></paramdef>"
 #. Tag: para
 #: reference_bbox.xml:299
@@ -569,6 +666,8 @@ msgid ""
 "An aggregate function that returns a <xref linkend=\"box2d_type\"/> bounding "
 "box that bounds a set of geometries."
 msgstr ""
+"Une fonction agrégée qui renvoie une <xref linkend=\"box2d_type\"/> boîte de "
+"délimitation qui délimite un ensemble de géométries."
 #. Tag: para
 #: reference_bbox.xml:303 reference_bbox.xml:361
@@ -577,6 +676,8 @@ msgid ""
 "The bounding box coordinates are in the spatial reference system of the "
 "input geometries."
 msgstr ""
+"Les coordonnées de la boîte de délimitation sont dans le système de "
+"référence spatiale des géométries d'entrée."
 #. Tag: para
 #: reference_bbox.xml:305
@@ -584,6 +685,8 @@ msgstr ""
 msgid ""
 "ST_Extent is similar in concept to Oracle Spatial/Locator's SDO_AGGR_MBR."
 msgstr ""
+"Le concept de ST_Extent est similaire à celui de SDO_AGGR_MBR d'Oracle "
+"Spatial/Locator."
 #. Tag: para
 #: reference_bbox.xml:308
@@ -592,6 +695,9 @@ msgid ""
 "ST_Extent returns boxes with only X and Y ordinates even with 3D geometries. "
 "To return XYZ ordinates use <xref linkend=\"ST_3DExtent\"/>."
 msgstr ""
+"ST_Extent renvoie des boîtes avec seulement les coordonnées X et Y, même "
+"avec des géométries 3D. Pour renvoyer les coordonnées XYZ, utilisez <xref "
+"linkend=\"ST_3DExtent\"/>."
 #. Tag: para
 #: reference_bbox.xml:313 reference_bbox.xml:364
@@ -601,12 +707,17 @@ msgid ""
 "linkend=\"ST_SetSRID\"/> to convert it into a geometry with SRID metadata. "
 "The SRID is the same as the input geometries."
 msgstr ""
+"La valeur <code>box3d</code> renvoyée ne contient pas de SRID. Utilisez "
+"<xref linkend=\"ST_SetSRID\"/> pour la convertir en une géométrie avec des "
+"métadonnées SRID. Le SRID est le même que celui des géométries d'entrée."
 #. Tag: para
 #: reference_bbox.xml:326
 #, no-c-format
 msgid "Examples below use Massachusetts State Plane ft (SRID=2249)"
 msgstr ""
+"Les exemples ci-dessous utilisent le plan de l'État du Massachusetts "
+"(SRID=2249)"
 #: reference_bbox.xml:327
@@ -640,24 +751,53 @@ msgid ""
 "2970042.75,\n"
 " 794875.8125 2908247.25,739651.875 2908247.25))"
 msgstr ""
+"SELECT ST_Extent(geom) as bextent FROM sometable ;\n"
+"                                         st_bextent\n"
+"BOX(739651.875 2908247.25,794875.8125 2970042.75)\n"
+"\n"
+"\n"
+"--Retour de l'étendue de chaque catégorie de géométrie\n"
+"SELECT ST_Extent(geom) as bextent\n"
+"FROM sometable\n"
+"GROUP BY category ORDER BY category ;\n"
+"\n"
+"                                          bextent                       |"
+"         name\n"
+"----------------------------------------------------+----------------\n"
+" BOX(778783.5625 2951741.25,794875.8125 2970042.75) | A\n"
+" BOX(751315.8125 2919164.75,765202.6875 2935417.25) | B\n"
+" BOX(739651.875 2917394.75,756688.375 2935866)      | C\n"
+"\n"
+" -- Forcer le retour dans une géométrie\n"
+" -- et rendre la représentation textuelle étendue de cette géométrie\n"
+"SELECT ST_SetSRID(ST_Extent(geom),2249) as bextent FROM sometable ;\n"
+"\n"
+"                                bextent\n"
+"---\n"
+" SRID=2249 ;POLYGON((739651.875 2908247.25,739651.875 2970042.75,794875.8125 "
+"2970042.75,\n"
+" 794875.8125 2908247.25,739651.875 2908247.25))"
 #. Tag: para
 #: reference_bbox.xml:332
 #, no-c-format
 msgid ", <xref linkend=\"ST_3DExtent\"/>, <xref linkend=\"ST_SetSRID\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_3DExtent\"/>, <xref linkend=\"ST_SetSRID\"/>"
 #. Tag: refname
 #: reference_bbox.xml:342
 #, no-c-format
 msgid "ST_3DExtent"
-msgstr ""
+msgstr "ST_3DExtent"
 #. Tag: refpurpose
 #: reference_bbox.xml:343
 #, no-c-format
 msgid "Aggregate function that returns the 3D bounding box of geometries."
 msgstr ""
+"Fonction d'agrégation qui renvoie la boîte de délimitation 3D des géométries."
 #: reference_bbox.xml:348
@@ -667,6 +807,9 @@ msgid ""
 "paramdef>"
 msgstr ""
+"<funcdef>box3d <function>ST_3DExtent</function></funcdef> "
 #. Tag: para
 #: reference_bbox.xml:358
@@ -675,12 +818,16 @@ msgid ""
 "An aggregate function that returns a <xref linkend=\"box3d_type\"/> "
 "(includes Z ordinate) bounding box that bounds a set of geometries."
 msgstr ""
+"Une fonction d'agrégation qui renvoie une <xref linkend=\"box3d_type\"/> (y "
+"compris l'ordonnée Z) qui délimite un ensemble de géométries."
 #. Tag: para
 #: reference_bbox.xml:370
 #, no-c-format
 msgid "Changed: 2.0.0 In prior versions this used to be called ST_Extent3D"
 msgstr ""
+"Modifié : 2.0.0 Dans les versions précédentes, cette fonction était appelée "
+"ST_Extent3D."
 #: reference_bbox.xml:379
@@ -707,24 +854,45 @@ msgid ""
 " BOX3D(1 0 0,4 2 2)"
 msgstr ""
+"SELECT ST_3DExtent(foo.geom) As b3extent\n"
+"FROM (SELECT ST_MakePoint(x,y,z) As geom\n"
+"        FROM generate_series(1,3) As x\n"
+"                CROSS JOIN generate_series(1,2) As y\n"
+"                CROSS JOIN generate_series(0,2) As Z) As foo ;\n"
+"          b3extent\n"
+" BOX3D(1 1 0,3 2 2)\n"
+"\n"
+"-- Obtenir l'étendue de diverses lignes circulaires surélevées\n"
+"FROM (SELECT "
+"ST_Translate(ST_Force_3DZ(ST_LineToCurve(ST_Buffer(ST_Point(x,y),1))),0,0,z) "
+"As geom\n"
+"\n"
+"        b3extent\n"
+" BOX3D(1 0 0,4 2 2)"
 #. Tag: para
 #: reference_bbox.xml:384
 #, no-c-format
 msgid ", <xref linkend=\"ST_Force_3DZ\"/>, <xref linkend=\"ST_SetSRID\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_Force_3DZ\"/>, <xref linkend=\"ST_SetSRID\"/>"
 #. Tag: refname
 #: reference_bbox.xml:390
 #, no-c-format
 msgid "ST_MakeBox2D"
-msgstr ""
+msgstr "ST_MakeBox2D"
 #. Tag: refpurpose
 #: reference_bbox.xml:392
 #, no-c-format
 msgid "Creates a BOX2D defined by two 2D point geometries."
-msgstr ""
+msgstr "Crée un BOX2D défini par deux géométries de points 2D."
 #: reference_bbox.xml:397
@@ -735,6 +903,10 @@ msgid ""
 "paramdef> <paramdef><type>geometry </type> <parameter>pointUpRight</"
 "parameter></paramdef>"
 msgstr ""
+"<funcdef>box2d <function>ST_MakeBox2D</function></funcdef> "
+"<paramdef><type>geometry </type> <parameter>pointLowLeft</parameter></"
+"paramdef> <paramdef><type>geometry </type> "
+"<parameter>pointUpRight</parameter></paramdef>"
 #. Tag: para
 #: reference_bbox.xml:408
@@ -743,6 +915,8 @@ msgid ""
 "Creates a <xref linkend=\"box2d_type\"/> defined by two Point geometries. "
 "This is useful for doing range queries."
 msgstr ""
+"Crée une <xref linkend=\"box2d_type\"/> définie par deux géométries de "
+"points. Ceci est utile pour effectuer des requêtes sur des intervalles."
 #: reference_bbox.xml:416
@@ -758,24 +932,34 @@ msgid ""
 "528439.5625),\n"
 "        ST_Point(-987121.375 ,529933.1875)),2163)"
 msgstr ""
+"--Retourner toutes les caractéristiques qui se trouvent ou se trouvent "
+"partiellement dans une boîte de délimitation des coordonnées de l'atlas "
+"national des États-Unis.\n"
+"--On suppose ici que les géométries sont stockées avec SRID = 2163 (zone "
+"égale de l'atlas national des États-Unis).\n"
+"SELECT feature_id, feature_name, geom\n"
+"FROM features\n"
+"WHERE geom &&amp ; ST_SetSRID(ST_MakeBox2D(ST_Point(-989502.1875, 528439."
+"5625),\n"
+"        ST_Point(-987121.375 ,529933.1875)),2163)"
 #. Tag: para
 #: reference_bbox.xml:423 reference_bbox.xml:469
 #, no-c-format
 msgid ", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_SRID\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_SRID\"/>"
 #. Tag: refname
 #: reference_bbox.xml:429
 #, no-c-format
 msgid "ST_3DMakeBox"
-msgstr ""
+msgstr "ST_3DMakeBox"
 #. Tag: refpurpose
 #: reference_bbox.xml:431
 #, no-c-format
 msgid "Creates a BOX3D defined by two 3D point geometries."
-msgstr ""
+msgstr "Crée un BOX3D défini par deux géométries de points 3D."
 #: reference_bbox.xml:435
@@ -786,6 +970,11 @@ msgid ""
 "parameter></paramdef> <paramdef><type>geometry </type> "
 "<parameter>point3DUpRightTop</parameter></paramdef>"
 msgstr ""
+"<funcdef>box3d <function>ST_3DMakeBox</function></funcdef> "
+"<paramdef><type>geometry </type> "
+"<parameter>point3DLowLeftBottom</parameter></paramdef> "
+"<parameter>point3DUpRightTop</parameter></paramdef>"
 #. Tag: para
 #: reference_bbox.xml:446
@@ -793,18 +982,22 @@ msgstr ""
 msgid ""
 "Creates a <xref linkend=\"box3d_type\"/> defined by two 3D Point geometries."
 msgstr ""
+"Crée une <xref linkend=\"box3d_type\"/> définie par deux géométries de "
+"points 3D."
 #. Tag: para
 #: reference_bbox.xml:453
 #, no-c-format
 msgid "This function supports 3D and will not drop the z-index."
-msgstr ""
+msgstr "Cette fonction prend en charge la 3D et ne supprime pas l'indice z."
 #. Tag: para
 #: reference_bbox.xml:455
 #, no-c-format
 msgid "Changed: 2.0.0 In prior versions this used to be called ST_MakeBox3D"
 msgstr ""
+"Modifié : 2.0.0 Dans les versions précédentes, cette fonction s'appelait "
+"ST_MakeBox3D"
 #: reference_bbox.xml:462
@@ -817,12 +1010,18 @@ msgid ""
 "--------\n"
 "BOX3D(-989502.1875 528439.5625 10,-987121.375 529933.1875 10)"
 msgstr ""
+"SELECT ST_3DMakeBox(ST_MakePoint(-989502.1875, 528439.5625, 10),\n"
+"        ST_MakePoint(-987121.375 ,529933.1875, 10)) As abb3d\n"
+"\n"
+"--bb3d--\n"
+"--------\n"
+"BOX3D(-989502.1875 528439.5625 10,-987121.375 529933.1875 10)"
 #. Tag: refname
 #: reference_bbox.xml:475
 #, no-c-format
 msgid "ST_XMax"
-msgstr ""
+msgstr "ST_XMax"
 #. Tag: refpurpose
 #: reference_bbox.xml:477
@@ -831,6 +1030,8 @@ msgid ""
 "<refpurpose>Returns the X maxima of a 2D or 3D bounding box or a geometry.</"
 "refpurpose>"
 msgstr ""
+"<refpurpose>Retourne les maxima X d'une boîte de délimitation 2D ou 3D ou "
+"d'une géométrie.</refpurpose>"
 #: reference_bbox.xml:482
@@ -839,6 +1040,8 @@ msgid ""
 "<funcdef>float <function>ST_XMax</function></funcdef> <paramdef><type>box3d "
 "</type> <parameter>aGeomorBox2DorBox3D</parameter></paramdef>"
 msgstr ""
+"<funcdef>float <function>ST_XMax</function></funcdef> <paramdef><type>box3d "
+"</type> <parameter>aGeomorBox2DorBox3D</parameter></paramdef>"
 #. Tag: para
 #: reference_bbox.xml:492
@@ -846,6 +1049,8 @@ msgstr ""
 msgid ""
 "<para>Returns the X maxima of a 2D or 3D bounding box or a geometry.</para>"
 msgstr ""
+"<para>Retourne les maxima X d'une boîte de délimitation 2D ou 3D ou d'une "
+"géométrie.</para>"
 #. Tag: para
 #: reference_bbox.xml:495
@@ -855,6 +1060,11 @@ msgid ""
 "and geometry values due to automatic casting. However, it will not accept a "
 "geometry or box2d text representation, since those do not auto-cast."
 msgstr ""
+"Bien que cette fonction ne soit définie que pour box3d, elle fonctionne "
+"également pour box2d et les valeurs géométriques en raison du moulage "
+"automatique. Cependant, elle n'acceptera pas de représentation textuelle de "
+"la géométrie ou de la box2d, car ces dernières ne sont pas soumises à la "
+"conversion automatique."
 #: reference_bbox.xml:507
@@ -886,6 +1096,31 @@ msgid ""
 "--------\n"
 "220288.248780547"
 msgstr ""
+"SELECT ST_XMax('BOX3D(1 2 3, 4 5 6)') ;\n"
+"st_xmax\n"
+"-------\n"
+"4\n"
+"\n"
+"SELECT ST_XMax(ST_GeomFromText('LINESTRING(1 3 4, 5 6 7)')) ;\n"
+"st_xmax\n"
+"-------\n"
+"5\n"
+"\n"
+"SELECT ST_XMax(CAST('BOX(-3 2, 3 4)' As box2d)) ;\n"
+"st_xmax\n"
+"-------\n"
+"3\n"
+"--Observez que cela ne fonctionne pas, car cela tente de convertir "
+"automatiquement la représentation de la ligne en BOX3D.\n"
+"SELECT ST_XMax('LINESTRING(1 3, 5 6)') ;\n"
+"\n"
+"--ERREUR :  BOX3D parser - ne commence pas par BOX3D(\n"
+"\n"
+"SELECT ST_XMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 "
+"2,220227 150406 3)')) ;\n"
+"st_xmax\n"
+"--------\n"
+"220288.248780547"
 #. Tag: para
 #: reference_bbox.xml:514 reference_bbox.xml:559
@@ -894,12 +1129,14 @@ msgid ""
 ", <xref linkend=\"ST_YMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend="
 "\"ST_ZMax\"/>, <xref linkend=\"ST_ZMin\"/>"
 msgstr ""
+", <xref linkend=\"ST_YMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend="
+"\"ST_ZMax\"/>, <xref linkend=\"ST_ZMin\"/>"
 #. Tag: refname
 #: reference_bbox.xml:520
 #, no-c-format
 msgid "ST_XMin"
-msgstr ""
+msgstr "ST_XMin"
 #. Tag: refpurpose
 #: reference_bbox.xml:522
@@ -908,6 +1145,8 @@ msgid ""
 "<refpurpose>Returns the X minima of a 2D or 3D bounding box or a geometry.</"
 "refpurpose>"
 msgstr ""
+"<refpurpose>Retourne les minima X d'une boîte de délimitation 2D ou 3D ou "
 #: reference_bbox.xml:527
@@ -916,6 +1155,8 @@ msgid ""
 "<funcdef>float <function>ST_XMin</function></funcdef> <paramdef><type>box3d "
 msgstr ""
+"<funcdef>float <function>ST_XMin</function></funcdef> <paramdef><type>box3d "
 #. Tag: para
 #: reference_bbox.xml:537
@@ -923,6 +1164,8 @@ msgstr ""
 msgid ""
 "<para>Returns the X minima of a 2D or 3D bounding box or a geometry.</para>"
 msgstr ""
+"<para>Retourne les minima X d'une boîte de délimitation 2D ou 3D ou d'une "
 #. Tag: para
 #: reference_bbox.xml:540 reference_bbox.xml:585 reference_bbox.xml:630
@@ -933,6 +1176,11 @@ msgid ""
 "and geometry values due to automatic casting. However it will not accept a "
 msgstr ""
+"la géométrie ou de la box2d, car celles-ci ne sont pas coulées "
+"automatiquement."
 #: reference_bbox.xml:552
@@ -964,12 +1212,37 @@ msgid ""
 "--------\n"
 "220186.995121892"
 msgstr ""
+"SELECT ST_XMin('BOX3D(1 2 3, 4 5 6)') ;\n"
+"st_xmin\n"
+"-------\n"
+"1\n"
+"\n"
+"SELECT ST_XMin(ST_GeomFromText('LINESTRING(1 3 4, 5 6 7)')) ;\n"
+"st_xmin\n"
+"-------\n"
+"1\n"
+"\n"
+"SELECT ST_XMin(CAST('BOX(-3 2, 3 4)' As box2d)) ;\n"
+"st_xmin\n"
+"-------\n"
+"-3\n"
+"-- Observez que cela ne fonctionne pas, car cela tente de convertir "
+"SELECT ST_XMin('LINESTRING(1 3, 5 6)') ;\n"
+"\n"
+"--ERREUR :  BOX3D parser ne commence pas par BOX3D(\n"
+"\n"
+"SELECT ST_XMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 "
+"st_xmin\n"
+"--------\n"
+"220186.995121892"
 #. Tag: refname
 #: reference_bbox.xml:565
 #, no-c-format
 msgid "ST_YMax"
-msgstr ""
+msgstr "ST_YMax"
 #. Tag: refpurpose
 #: reference_bbox.xml:567
@@ -978,6 +1251,8 @@ msgid ""
 "<refpurpose>Returns the Y maxima of a 2D or 3D bounding box or a geometry.</"
 "refpurpose>"
 msgstr ""
+"<refpurpose>Retourne les maxima Y d'une boîte de délimitation 2D ou 3D ou "
 #: reference_bbox.xml:572
@@ -986,6 +1261,8 @@ msgid ""
 "<funcdef>float <function>ST_YMax</function></funcdef> <paramdef><type>box3d "
 msgstr ""
+"<funcdef>float <function>ST_YMax</function></funcdef> <paramdef><type>box3d "
 #. Tag: para
 #: reference_bbox.xml:582
@@ -993,6 +1270,8 @@ msgstr ""
 msgid ""
 "<para>Returns the Y maxima of a 2D or 3D bounding box or a geometry.</para>"
 msgstr ""
+"<para>Retourne les maxima Y d'une boîte de délimitation 2D ou 3D ou d'une "
 #: reference_bbox.xml:597
@@ -1024,6 +1303,31 @@ msgid ""
 "--------\n"
 "150506.126829327"
 msgstr ""
+"SELECT ST_YMax('BOX3D(1 2 3, 4 5 6)') ;\n"
+"st_ymax\n"
+"-------\n"
+"5\n"
+"\n"
+"SELECT ST_YMax(ST_GeomFromText('LINESTRING(1 3 4, 5 6 7)')) ;\n"
+"st_ymax\n"
+"-------\n"
+"6\n"
+"\n"
+"SELECT ST_YMax(CAST('BOX(-3 2, 3 4)' As box2d)) ;\n"
+"st_ymax\n"
+"-------\n"
+"4\n"
+"SELECT ST_YMax('LINESTRING(1 3, 5 6)') ;\n"
+"\n"
+"\n"
+"SELECT ST_YMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 "
+"st_ymax\n"
+"--------\n"
+"150506.126829327"
 #. Tag: para
 #: reference_bbox.xml:604
@@ -1032,12 +1336,14 @@ msgid ""
 ", <xref linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend="
 msgstr ""
+", <xref linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend="
 #. Tag: refname
 #: reference_bbox.xml:610
 #, no-c-format
 msgid "ST_YMin"
-msgstr ""
+msgstr "ST_YMin"
 #. Tag: refpurpose
 #: reference_bbox.xml:612
@@ -1046,6 +1352,8 @@ msgid ""
 "<refpurpose>Returns the Y minima of a 2D or 3D bounding box or a geometry.</"
 "refpurpose>"
 msgstr ""
+"<refpurpose>Retourne les minima Y d'une boîte de délimitation 2D ou 3D ou "
 #: reference_bbox.xml:617
@@ -1054,6 +1362,8 @@ msgid ""
 "<funcdef>float <function>ST_YMin</function></funcdef> <paramdef><type>box3d "
 msgstr ""
+"<funcdef>float <function>ST_YMin</function></funcdef> <paramdef><type>box3d "
 #. Tag: para
 #: reference_bbox.xml:627
@@ -1061,6 +1371,8 @@ msgstr ""
 msgid ""
 "<para>Returns the Y minima of a 2D or 3D bounding box or a geometry.</para>"
 msgstr ""
+"<para>Retourne les minima Y d'une boîte englobante 2D ou 3D ou d'une "
 #: reference_bbox.xml:642
@@ -1092,6 +1404,31 @@ msgid ""
 "--------\n"
 "150406"
 msgstr ""
+"SELECT ST_YMin('BOX3D(1 2 3, 4 5 6)') ;\n"
+"st_ymin\n"
+"-------\n"
+"2\n"
+"\n"
+"SELECT ST_YMin(ST_GeomFromText('LINESTRING(1 3 4, 5 6 7)')) ;\n"
+"st_ymin\n"
+"-------\n"
+"3\n"
+"\n"
+"SELECT ST_YMin(CAST('BOX(-3 2, 3 4)' As box2d)) ;\n"
+"st_ymin\n"
+"-------\n"
+"2\n"
+"-- Observez que ceci ne fonctionne pas car il essaiera d'auto-castrer la "
+"représentation de la ligne dans une BOX3D\n"
+"SELECT ST_YMin('LINESTRING(1 3, 5 6)') ;\n"
+"\n"
+"\n"
+"SELECT ST_YMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 "
+"st_ymin\n"
+"--------\n"
+"150406"
 #. Tag: para
 #: reference_bbox.xml:649
@@ -1100,12 +1437,14 @@ msgid ""
 ", <xref linkend=\"ST_XMin\"/>, <xref linkend=\"ST_XMax\"/>, <xref linkend="
 "\"ST_YMax\"/>, <xref linkend=\"ST_ZMax\"/>, <xref linkend=\"ST_ZMin\"/>"
 msgstr ""
+", <xref linkend=\"ST_XMin\"/>, <xref linkend=\"ST_XMax\"/>, <xref linkend="
+"\"ST_YMax\"/>, <xref linkend=\"ST_ZMax\"/>, <xref linkend=\"ST_ZMin\"/>"
 #. Tag: refname
 #: reference_bbox.xml:655
 #, no-c-format
 msgid "ST_ZMax"
-msgstr ""
+msgstr "ST_ZMax"
 #. Tag: refpurpose
 #: reference_bbox.xml:657
@@ -1114,6 +1453,8 @@ msgid ""
 "<refpurpose>Returns the Z maxima of a 2D or 3D bounding box or a geometry.</"
 "refpurpose>"
 msgstr ""
+"<refpurpose>Retourne les maxima Z d'une boîte de délimitation 2D ou 3D ou "
 #: reference_bbox.xml:662
@@ -1122,6 +1463,8 @@ msgid ""
 "<funcdef>float <function>ST_ZMax</function></funcdef> <paramdef><type>box3d "
 msgstr ""
+"<funcdef>float <function>ST_ZMax</function></funcdef> <paramdef><type>box3d "
 #. Tag: para
 #: reference_bbox.xml:672
@@ -1129,6 +1472,8 @@ msgstr ""
 msgid ""
 "<para>Returns the Z maxima of a 2D or 3D bounding box or a geometry.</para>"
 msgstr ""
+"<para>Retourne les maxima Z d'une boîte de délimitation 2D ou 3D ou d'une "
 #: reference_bbox.xml:687
@@ -1160,6 +1505,31 @@ msgid ""
 "--------\n"
 "3"
 msgstr ""
+"SELECT ST_ZMax('BOX3D(1 2 3, 4 5 6)') ;\n"
+"st_zmax\n"
+"-------\n"
+"6\n"
+"\n"
+"SELECT ST_ZMax(ST_GeomFromEWKT('LINESTRING(1 3 4, 5 6 7)')) ;\n"
+"st_zmax\n"
+"-------\n"
+"7\n"
+"\n"
+"SELECT ST_ZMax('BOX3D(-3 2 1, 3 4 1)' ) ;\n"
+"st_zmax\n"
+"-------\n"
+"1\n"
+"SELECT ST_ZMax('LINESTRING(1 3 4, 5 6 7)') ;\n"
+"\n"
+"\n"
+"SELECT ST_ZMax(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 "
+"st_zmax\n"
+"--------\n"
+"3"
 #. Tag: para
 #: reference_bbox.xml:694
@@ -1168,12 +1538,14 @@ msgid ""
 "\"ST_YMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend=\"ST_ZMax\"/>"
 msgstr ""
+"\"ST_YMax\"/>, <xref linkend=\"ST_YMin\"/>, <xref linkend=\"ST_ZMax\"/>"
 #. Tag: refname
 #: reference_bbox.xml:700
 #, no-c-format
 msgid "ST_ZMin"
-msgstr ""
+msgstr "ST_ZMin"
 #. Tag: refpurpose
 #: reference_bbox.xml:702
@@ -1182,6 +1554,8 @@ msgid ""
 "<refpurpose>Returns the Z minima of a 2D or 3D bounding box or a geometry.</"
 "refpurpose>"
 msgstr ""
+"<refpurpose>Retourne les minima Z d'une boîte de délimitation 2D ou 3D ou "
 #: reference_bbox.xml:707
@@ -1190,6 +1564,8 @@ msgid ""
 "<funcdef>float <function>ST_ZMin</function></funcdef> <paramdef><type>box3d "
 msgstr ""
+"<funcdef>float <function>ST_ZMin</function></funcdef> <paramdef><type>box3d "
 #. Tag: para
 #: reference_bbox.xml:717
@@ -1197,6 +1573,8 @@ msgstr ""
 msgid ""
 "<para>Returns the Z minima of a 2D or 3D bounding box or a geometry.</para>"
 msgstr ""
+"<para>Retourne les minima Z d'une boîte de délimitation 2D ou 3D ou d'une "
 #: reference_bbox.xml:732
@@ -1228,6 +1606,31 @@ msgid ""
 "--------\n"
 "1"
 msgstr ""
+"SELECT ST_ZMin('BOX3D(1 2 3, 4 5 6)') ;\n"
+"st_zmin\n"
+"-------\n"
+"3\n"
+"\n"
+"SELECT ST_ZMin(ST_GeomFromEWKT('LINESTRING(1 3 4, 5 6 7)')) ;\n"
+"st_zmin\n"
+"-------\n"
+"4\n"
+"\n"
+"SELECT ST_ZMin('BOX3D(-3 2 1, 3 4 1)' ) ;\n"
+"st_zmin\n"
+"-------\n"
+"1\n"
+"SELECT ST_ZMin('LINESTRING(1 3 4, 5 6 7)') ;\n"
+"\n"
+"\n"
+"SELECT ST_ZMin(ST_GeomFromEWKT('CIRCULARSTRING(220268 150415 1,220227 150505 "
+"st_zmin\n"
+"--------\n"
+"1"
 #. Tag: para
 #: reference_bbox.xml:739
@@ -1237,3 +1640,6 @@ msgid ""
 "linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMax\"/>, <xref linkend=\"ST_YMin"
 "\"/>, <xref linkend=\"ST_ZMax\"/>"
 msgstr ""
+", <xref linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_XMin\"/>, <xref "
+"linkend=\"ST_XMax\"/>, <xref linkend=\"ST_YMax\"/>, <xref linkend=\"ST_YMin\""
+"/>, <xref linkend=\"ST_ZMax\"/>"
commit 8a7471598c2db71ba130c687fe570f02c4a4a018
Date:   Fri May 12 10:48:59 2023 +0000
    Currently translated at 100.0% (80 of 80 strings)
    Translation: postgis/reference_srs.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_srsxml/fr/
diff --git a/doc/po/fr/reference_srs.xml.po b/doc/po/fr/reference_srs.xml.po
index 5d821f6cd..35b9fdb5f 100644
--- a/doc/po/fr/reference_srs.xml.po
+++ b/doc/po/fr/reference_srs.xml.po
 "POT-Creation-Date: 2022-11-01 14:51+0000\n"
 "reference_srsxml/fr/>\n"
@@ -24,18 +24,20 @@ msgid ""
 "These functions work with the Spatial Reference System of geometries as "
 "defined in the <varname>spatial_ref_sys</varname> table."
 msgstr ""
+"Ces fonctions fonctionnent avec le système de référence spatiale des "
+"géométries défini dans la table <varname>spatial_ref_sys</varname>."
 #. Tag: title
 #: reference_srs.xml:10
 #, no-c-format
 msgid "Spatial Reference System Functions"
-msgstr ""
+msgstr "Fonctions des systèmes de référence spatiale"
 #. Tag: refname
 #: reference_srs.xml:14
 #, no-c-format
 msgid "ST_InverseTransformPipeline"
-msgstr ""
+msgstr "ST_InverseTransformPipeline"
 #. Tag: refpurpose
 #: reference_srs.xml:16
@@ -45,6 +47,9 @@ msgid ""
 "reference system using the inverse of a defined coordinate transformation "
 "pipeline."
 msgstr ""
+"Renvoie une nouvelle géométrie dont les coordonnées ont été transformées "
+"dans un système de référence spatial différent en utilisant l'inverse d'un "
+"pipeline de transformation de coordonnées défini."
 #: reference_srs.xml:23
@@ -56,6 +61,11 @@ msgid ""
 "<paramdef choice=\"opt\"><type>integer </type> <parameter>to_srid</"
 msgstr ""
+"<funcdef>geometry <function>ST_InverseTransformPipeline</function></funcdef> "
+"<paramdef><type>text </type> <parameter>pipeline</parameter></paramdef> "
+"<paramdef choice=\"opt\"><type>integer </type> "
+"<parameter>to_srid</parameter></paramdef>"
 #. Tag: title
 #: reference_srs.xml:33 reference_srs.xml:95 reference_srs.xml:142
@@ -72,6 +82,9 @@ msgid ""
 "reference system using a defined coordinate transformation pipeline to go in "
 "the inverse direction."
 msgstr ""
+"dans un système de référence spatial différent à l'aide d'un pipeline de "
+"transformation de coordonnées défini pour aller dans la direction inverse."
 #. Tag: para
 #: reference_srs.xml:40
@@ -80,6 +93,8 @@ msgid ""
 "Refer to <xref linkend=\"ST_TransformPipeline\"/> for details on writing a "
 "transformation pipeline."
 msgstr ""
+"Voir <xref linkend=\"ST_TransformPipeline\"/> pour plus de détails sur "
+"l'écriture d'un pipeline de transformation."
 #. Tag: para
 #: reference_srs.xml:42 reference_srs.xml:343
@@ -98,6 +113,12 @@ msgid ""
 "direction. Using `ST_InverseTransformPipeline()` the pipeline is executed in "
 msgstr ""
+"Le SRID de la géométrie en entrée est ignoré et le SRID de la géométrie de "
+"sortie sera mis à zéro à moins qu'une valeur ne soit fournie via le "
+"paramètre facultatif <varname>to_srid</varname>. Lors de l'utilisation de "
+"<xref linkend=\"ST_TransformPipeline\"/>, le pipeline est exécuté dans le "
+"sens direct. En utilisant `ST_InverseTransformPipeline()`, le pipeline est "
+"exécuté dans le sens inverse."
 #. Tag: para
 #: reference_srs.xml:50 reference_srs.xml:351
@@ -108,6 +129,10 @@ msgid ""
 "correct operations to convert between coordinate systems, and should be "
 "preferred."
 msgstr ""
+"Les transformations utilisant des pipelines sont une version spéciale de "
+"<xref linkend=\"ST_Transform\"/>. Dans la plupart des cas, `ST_Transform` "
+"choisira les opérations correctes pour convertir entre les systèmes de "
+"coordonnées, et devrait être préféré."
 #. Tag: title
 #: reference_srs.xml:57 reference_srs.xml:111 reference_srs.xml:155
@@ -121,6 +146,7 @@ msgstr "Exemples"
 #, no-c-format
 msgid "Change WGS 84 long lat to UTM 31N using the EPSG:16031 conversion"
 msgstr ""
+"Changer WGS 84 long lat en UTM 31N en utilisant la conversion EPSG:16031"
 #: reference_srs.xml:59
@@ -136,12 +162,21 @@ msgid ""
 " POINT(2 48.99999999999999)\n"
 "(1 row)"
 msgstr ""
+"-- Inverser la direction\n"
+"SELECT ST_AsText(ST_InverseTransformPipeline('POINT(426857.9877165967 5427937"
+".523342293)'::geometry,\n"
+"  'urn:ogc:def:coordinateOperation:EPSG::16031')) AS wgs_geom;\n"
+"\n"
+"          wgs_geom\n"
+"----------------------------\n"
+" POINT(2 48.99999999999999)\n"
+"(1 row)"
 #. Tag: para
 #: reference_srs.xml:61 reference_srs.xml:362
 #, no-c-format
 msgid "GDA2020 example."
-msgstr ""
+msgstr "Exemple GDA2020."
 #: reference_srs.xml:62
@@ -156,6 +191,15 @@ msgid ""
 " POINT(143.00000635638918 -36.999986706128176)\n"
 "(1 row)"
 msgstr ""
+"-- en utilisant ST_Transform avec sélection automatique d'un pipeline de "
+"conversion.\n"
+"SELECT ST_AsText(ST_Transform('SRID=4939;POINT(143.0 -37.0) ::geometry, "
+"7844)) AS gda2020_auto ;\n"
+"\n"
+"                 gda2020_auto\n"
+"-----------------------------------------------\n"
+" POINT(143.00000635638918 -36.999986706128176)\n"
+"(1 row)"
 #. Tag: title
 #: reference_srs.xml:67 reference_srs.xml:119 reference_srs.xml:160
@@ -168,19 +212,19 @@ msgstr "Voir aussi"
 #: reference_srs.xml:69
 #, no-c-format
 msgid ", <xref linkend=\"ST_TransformPipeline\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_TransformPipeline\"/>"
 #. Tag: refname
 #: reference_srs.xml:75
 #, no-c-format
 msgid "ST_SetSRID"
-msgstr ""
 #. Tag: refpurpose
 #: reference_srs.xml:77
 #, no-c-format
 msgid "Set the SRID on a geometry."
-msgstr ""
+msgstr "Définir le SRID d'une géométrie."
 #: reference_srs.xml:82
@@ -190,6 +234,9 @@ msgid ""
 "<paramdef><type>integer </type> <parameter>srid</parameter></paramdef>"
 msgstr ""
+"<funcdef>geometry <function>ST_SetSRID</function></funcdef> "
+"<paramdef><type>integer </type> <parameter>srid</parameter></paramdef>"
 #. Tag: para
 #: reference_srs.xml:97
@@ -198,6 +245,8 @@ msgid ""
 "Sets the SRID on a geometry to a particular integer value. Useful in "
 "constructing bounding boxes for queries."
 msgstr ""
+"Définit le SRID d'une géométrie à une valeur entière particulière. Utile "
+"pour construire des boîtes de délimitation pour les requêtes."
 #. Tag: para
 #: reference_srs.xml:101
@@ -208,6 +257,11 @@ msgid ""
 "is assumed to be in. Use <xref linkend=\"ST_Transform\"/> if you want to "
 "transform the geometry into a new projection."
 msgstr ""
+"Cette fonction ne transforme en aucune façon les coordonnées de la géométrie "
+"- elle définit simplement les métadonnées définissant le système de "
+"référence spatiale dans lequel la géométrie est supposée se trouver. "
+"Utilisez <xref linkend=\"ST_Transform\"/> si vous souhaitez transformer la "
+"géométrie dans une nouvelle projection."
 #. Tag: para
 #: reference_srs.xml:106
@@ -225,7 +279,7 @@ msgstr "&curve_support;"
 #: reference_srs.xml:112
 #, no-c-format
 msgid "-- Mark a point as WGS 84 long lat --"
-msgstr ""
+msgstr "-- Marquer un point comme WGS 84 long lat --"
 #: reference_srs.xml:113
@@ -235,6 +289,9 @@ msgid ""
 "-- the ewkt representation (wrap with ST_AsEWKT) -\n"
 "SRID=4326;POINT(-123.365556 48.428611)"
 msgstr ""
+"SELECT ST_SetSRID(ST_Point(-123.365556, 48.428611),4326) As wgs84long_lat ;\n"
+"-- la représentation ewkt (avec ST_AsEWKT) -\n"
+"SRID=4326 ;POINT(-123.365556 48.428611)"
 #. Tag: para
 #: reference_srs.xml:114
@@ -243,6 +300,8 @@ msgid ""
 "-- Mark a point as WGS 84 long lat and then transform to web mercator "
 "(Spherical Mercator) --"
 msgstr ""
+"-- Marquer un point comme WGS 84 long lat puis le transformer en mercator "
+"web (Mercator Sphérique) --"
 #: reference_srs.xml:115
@@ -253,6 +312,10 @@ msgid ""
 "SRID=3785;POINT(-13732990.8753491 6178458.96425423)"
 msgstr ""
+"SELECT ST_Transform(ST_SetSRID(ST_Point(-123.365556, 48.428611),4326),3785) "
+"As spere_merc;\n"
+"SRID=3785;POINT(-13732990.8753491 6178458.96425423)"
 #. Tag: para
 #: reference_srs.xml:121
@@ -261,18 +324,20 @@ msgid ""
 ", <xref linkend=\"ST_SRID\"/>, <xref linkend=\"ST_Transform\"/>, <xref "
 "linkend=\"UpdateGeometrySRID\"/>"
 msgstr ""
+", <xref linkend=\"ST_SRID\"/>, <xref linkend=\"ST_Transform\"/>, <xref "
+"linkend=\"UpdateGeometrySRID\"/>"
 #. Tag: refname
 #: reference_srs.xml:128
 #, no-c-format
 msgid "ST_SRID"
-msgstr ""
+msgstr "ST_SRID"
 #. Tag: refpurpose
 #: reference_srs.xml:129
 #, no-c-format
 msgid "Returns the spatial reference identifier for a geometry."
-msgstr ""
+msgstr "Renvoie l'identifiant de référence spatiale d'une géométrie."
 #: reference_srs.xml:134
@@ -281,6 +346,8 @@ msgid ""
 "<funcdef>integer <function>ST_SRID</function></funcdef> "
 "<paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>"
 msgstr ""
+"<funcdef>integer <function>ST_SRID</function></funcdef> "
+"<paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>"
 #. Tag: para
 #: reference_srs.xml:144
@@ -289,6 +356,8 @@ msgid ""
 msgstr ""
 #. Tag: para
 #: reference_srs.xml:145
@@ -299,6 +368,11 @@ msgid ""
 msgstr ""
 #. Tag: para
 #: reference_srs.xml:148
@@ -310,7 +384,7 @@ msgstr "&sfs_compliant; s2.1.1.1"
 #: reference_srs.xml:149
 #, no-c-format
 msgid "&sqlmm_compliant; SQL-MM 3: 5.1.5"
-msgstr ""
+msgstr "&sqlmm_compliant ; SQL-MM 3 : 5.1.5"
 #: reference_srs.xml:157
@@ -320,6 +394,9 @@ msgid ""
 "    --result\n"
 "    4326"
 msgstr ""
+"SELECT ST_SRID(ST_GeomFromText('POINT(-71.1043 42.315)',4326)) ;\n"
+"    -- résultat\n"
+"    4326"
 #. Tag: para
 #: reference_srs.xml:162
@@ -328,12 +405,14 @@ msgid ""
 ", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_Transform\"/>, <xref "
 "linkend=\"RT_ST_SRID\"/>, <xref linkend=\"TG_ST_SRID\"/>"
 msgstr ""
+", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_Transform\"/>, <xref "
+"linkend=\"RT_ST_SRID\"/>, <xref linkend=\"TG_ST_SRID\"/>"
 #. Tag: refname
 #: reference_srs.xml:168
 #, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #: reference_srs.xml:170
@@ -342,6 +421,8 @@ msgid ""
 "Return a new geometry with coordinates transformed to a different spatial "
 "reference system."
 msgstr ""
+"dans un système de référence spatial différent."
 #: reference_srs.xml:175
@@ -364,6 +445,22 @@ msgid ""
 "parameter></paramdef> <paramdef><type>integer </type> <parameter>to_srid</"
 "parameter></paramdef> </funcprototype>"
 msgstr ""
+"<funcprototype> <funcdef>geometry <function>ST_Transform</function></"
+"funcdef> <paramdef><type>geometry </type> <parameter>g1</parameter></"
+"paramdef> <paramdef><type>integer </type> <parameter>srid</parameter></"
+"<function>ST_Transform</function></funcdef> <paramdef><type>geometry </type> "
+"<parameter>geom</parameter></paramdef> <paramdef><type>text </type> "
+"<parameter>to_proj</parameter></paramdef> </funcprototype> <funcprototype> "
+"<funcdef>geometry <function>ST_Transform</function></funcdef> "
+"<paramdef><type>text </type> <parameter>from_proj</parameter></paramdef> "
+"<paramdef><type>text </type> <parameter>to_proj</parameter></paramdef> </"
+"funcprototype> <funcprototype> <funcdef>geometry "
+"<parameter>from_proj</parameter></paramdef> <paramdef><type>integer </type> "
+"<parameter>to_srid</parameter></paramdef> </funcprototype>"
 #. Tag: para
 #: reference_srs.xml:208
@@ -381,6 +478,18 @@ msgid ""
 "functions with <varname>from_proj</varname>, input geometries must have a "
 "defined SRID."
 msgstr ""
+"dans un système de référence spatiale différent. La référence spatiale de "
+"destination <varname>to_srid</varname> peut être identifiée par un paramètre "
+"entier SRID valide (c'est-à-dire qu'elle doit exister dans la table "
+"<varname>spatial_ref_sys</varname>). Il est également possible d'utiliser "
+"une référence spatiale définie comme une chaîne PROJ.4 pour "
+"<varname>to_proj</varname> et/ou <varname>from_proj</varname>, mais ces "
+"méthodes ne sont pas optimisées. Si le système de référence spatiale de "
+"destination est exprimé avec une chaîne PROJ.4 au lieu d'un SRID, le SRID de "
+"la géométrie de sortie sera mis à zéro. A l'exception des fonctions avec "
+"<varname>from_proj</varname>, les géométries d'entrée doivent avoir un SRID "
+"défini."
 #. Tag: para
 #: reference_srs.xml:222
@@ -391,6 +500,10 @@ msgid ""
 "reference system to another, while ST_SetSRID() simply changes the SRID "
 "identifier of the geometry."
 msgstr ""
+"ST_Transform est souvent confondu avec <xref linkend=\"ST_SetSRID\"/>. "
+"ST_Transform modifie en fait les coordonnées d'une géométrie d'un système de "
+"référence spatiale à un autre, tandis que ST_SetSRID() modifie simplement "
+"l'identifiant SRID de la géométrie."
 #. Tag: para
 #: reference_srs.xml:226
@@ -400,6 +513,10 @@ msgid ""
 "source and target spatial reference systems. To use a specific conversion "
 "method, use <xref linkend=\"ST_TransformPipeline\"/>."
 msgstr ""
+"ST_Transform sélectionne automatiquement un pipeline de conversion approprié "
+"en fonction des systèmes de référence spatiale source et cible. Pour "
+"utiliser une méthode de conversion spécifique, utilisez <xref linkend="
+"\"ST_TransformPipeline\"/>."
 #. Tag: para
 #: reference_srs.xml:230
@@ -409,6 +526,9 @@ msgid ""
 "linkend=\"PostGIS_Full_Version\"/> to confirm you have PROJ support compiled "
 "in."
 msgstr ""
+"PostGIS doit être compilé avec le support PROJ. Utilisez <xref linkend="
+"\"PostGIS_Full_Version\"/> pour confirmer que vous avez compilé le support "
+"PROJ."
 #. Tag: para
 #: reference_srs.xml:234
@@ -417,6 +537,9 @@ msgid ""
 "If using more than one transformation, it is useful to have a functional "
 "index on the commonly used transformations to take advantage of index usage."
 msgstr ""
+"Si l'on utilise plus d'une transformation, il est utile de disposer d'un "
+"index fonctionnel sur les transformations les plus couramment utilisées afin "
+"de tirer parti de l'utilisation de l'index."
 #. Tag: para
 #: reference_srs.xml:238
@@ -440,12 +563,14 @@ msgstr "Amélioration : 2.0.0 introduction du support des surfaces polyédriques
 #, no-c-format
 msgid "Enhanced: 2.3.0 support for direct PROJ.4 text was introduced."
 msgstr ""
+"Amélioration : la version 2.3.0 a introduit la prise en charge du texte "
+"PROJ.4 direct."
 #. Tag: para
 #: reference_srs.xml:242
 #, no-c-format
 msgid "&sqlmm_compliant; SQL-MM 3: 5.1.6"
-msgstr ""
+msgstr "&sqlmm_compliant; SQL-MM 3: 5.1.6"
 #. Tag: para
 #: reference_srs.xml:244
@@ -458,6 +583,8 @@ msgstr "&P_support;"
 #, no-c-format
 msgid "Change Massachusetts state plane US feet geometry to WGS 84 long lat"
 msgstr ""
+"Changer la géométrie des pieds US du plan de l'État du Massachusetts en WGS "
+"84 long lat"
 #: reference_srs.xml:251
@@ -489,6 +616,32 @@ msgid ""
 " -71.1775844305465 42.3903826677917 3,\n"
 " -71.1775825927231 42.3902893647987 3,-71.1776848522251 42.3902896512902 4)"
 msgstr ""
+"SELECT ST_AsText(ST_Transform(ST_GeomFromText('POLYGON((743238 "
+"2967416,743238 2967450,\n"
+"  743265 2967450,743265.625 2967416,743238 2967416))',2249),4326)) As "
+"wgs_geom ;\n"
+"\n"
+" wgs_geom\n"
+"---------------------------\n"
+" POLYGON((-71.1776848522251 42.3902896512902,-71.1776843766326 42."
+"3903829478009,\n"
+"-71.1775844305465 42.3903826677917,-71.1775825927231 42.3902893647987,-71."
+"177684\n"
+"8522251 42.3902896512902)) ;\n"
+"(1 row)\n"
+"\n"
+"-- exemple de ligne circulaire 3D\n"
+"SELECT ST_AsEWKT(ST_Transform(ST_GeomFromEWKT('SRID=2249;CIRCULARSTRING("
+"743238 2967416 1,743238 2967450 2,743265 2967450 3,743265.625 2967416 "
+"3,743238 2967416 4)'),4326)) ;\n"
+"\n"
+"         st_asewkt\n"
+"---------\n"
+" SRID=4326;CIRCULARSTRING(-71.1776848522251 42.3902896512902 1,-"
+"71.1776843766326 42.3903829478009 2,\n"
+" -71.1775844305465 42.3903826677917 3,\n"
+" -71.1775825927231 42.3902893647987 3,-71.1776848522251 42.3902896512902 4)"
 #. Tag: para
 #: reference_srs.xml:252
@@ -499,6 +652,11 @@ msgid ""
 "that leaves out null geometries which will both conserve space and make your "
 "index smaller and more efficient."
 msgstr ""
+"Exemple de création d'un index fonctionnel partiel. Pour les tables dont "
+"vous n'êtes pas sûr que toutes les géométries seront renseignées, il est "
+"préférable d'utiliser un index partiel qui laisse de côté les géométries "
+"nulles, ce qui permet à la fois de conserver de l'espace et de rendre votre "
+"index plus petit et plus efficace."
 #: reference_srs.xml:254
@@ -510,6 +668,11 @@ msgid ""
 "  (ST_Transform(geom, 26986))\n"
 "  WHERE geom IS NOT NULL;"
 msgstr ""
+"CREATE INDEX idx_geom_26986_parcels\n"
+"  ON parcels\n"
+"  USING gist\n"
+"  (ST_Transform(geom, 26986))\n"
+"  WHERE geom IS NOT NULL ;"
 #. Tag: para
 #: reference_srs.xml:256
@@ -517,6 +680,8 @@ msgstr ""
 msgid ""
 "Examples of using PROJ.4 text to transform with custom spatial references."
 msgstr ""
+"Exemples d'utilisation du texte PROJ.4 pour transformer avec des références "
+"spatiales personnalisées."
 #: reference_srs.xml:257
@@ -543,12 +708,33 @@ msgid ""
 "  POLYGON((-170 74.053793645338,-141 73.4268621378904,-141 68,-170 68,-170 "
 "74.053793645338))"
 msgstr ""
+"-- Trouver l'intersection de deux polygones près du pôle Nord, en utilisant "
+"une projection Gnomic personnalisée\n"
+"-- Voir http://boundlessgeo.com/2012/02/flattening-the-peel/\n"
+" WITH data AS (\n"
+"   SELECT\n"
+"     ST_GeomFromText('POLYGON((170 50,170 72,-130 72,-130 50,170 50))', 4326)"
+" AS p1,\n"
+"     ST_GeomFromText('POLYGON((-170 68,-170 90,-141 90,-141 68,-170 68))', "
+"4326) AS p2,\n"
+"     '+proj=gnom +ellps=WGS84 +lat_0=70 +lon_0=-160 +no_defs'::text AS gnom\n"
+" )\n"
+" SELECT ST_AsText(\n"
+"   ST_Transform(\n"
+"     ST_Intersection(ST_Transform(p1, gnom), ST_Transform(p2, gnom)),\n"
+"   gnom, 4326))\n"
+" FROM données ;\n"
+"                                          st_astext\n"
+"----\n"
+"  POLYGON((-170 74.053793645338,-141 73.4268621378904,-141 68,-170 68,-170 74"
+".053793645338))"
 #. Tag: title
 #: reference_srs.xml:261
 #, no-c-format
 msgid "Configuring transformation behavior"
-msgstr ""
+msgstr "Configurer le comportement de transformation"
 #. Tag: para
 #: reference_srs.xml:262
@@ -563,6 +749,15 @@ msgid ""
 "<varname>proj4text</varname> value within the <varname>spatial_ref_sys</"
 "varname> table."
 msgstr ""
+"Parfois, la transformation de coordonnées impliquant un décalage de grille "
+"peut échouer, par exemple si PROJ.4 n'a pas été construit avec des fichiers "
+"de décalage de grille ou si la coordonnée ne se trouve pas dans la plage "
+"pour laquelle le décalage de grille est défini. Par défaut, PostGIS génère "
+"une erreur si un fichier de décalage de grille n'est pas présent, mais ce "
+"comportement peut être configuré pour chaque SRID, soit en testant "
+"différentes valeurs <varname>to_proj</varname> de texte PROJ.4, soit en "
+"modifiant la valeur <varname>proj4text</varname> dans la table "
+"<varname>spatial_ref_sys</varname>."
 #. Tag: para
 #: reference_srs.xml:272
@@ -571,12 +766,14 @@ msgid ""
 "For example, the proj4text parameter +datum=NAD87 is a shorthand form for "
 "the following +nadgrids parameter:"
 msgstr ""
+"Par exemple, le paramètre proj4text +datum=NAD87 est une forme abrégée du "
+"paramètre +nadgrids suivant :"
 #: reference_srs.xml:273
 #, no-c-format
 msgid "+nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat"
-msgstr ""
+msgstr "+nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat"
 #. Tag: para
 #: reference_srs.xml:274
@@ -586,6 +783,10 @@ msgid ""
 "the end of the list is reached with no file having been appropriate (ie. "
 "found and overlapping) then an error is issued."
 msgstr ""
+"Le préfixe @ signifie qu'aucune erreur n'est signalée si les fichiers ne "
+"sont pas présents, mais si la fin de la liste est atteinte sans qu'aucun "
+"fichier n'ait été approprié (c'est-à-dire trouvé et se chevauchant), une "
+"erreur est émise."
 #. Tag: para
 #: reference_srs.xml:275
@@ -595,12 +796,15 @@ msgid ""
 "present, but that if all files were scanned without a hit a null "
 "transformation is applied you could use:"
 msgstr ""
+"Si, à l'inverse, vous voulez vous assurer qu'au moins les fichiers standard "
+"sont présents, mais que si tous les fichiers ont été analysés sans résultat, "
+"une transformation nulle est appliquée, vous pouvez utiliser :"
 #: reference_srs.xml:276
 #, no-c-format
 msgid "+nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat,null"
-msgstr ""
+msgstr "+nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat,null"
 #. Tag: para
 #: reference_srs.xml:277
@@ -611,6 +815,11 @@ msgid ""
 "PostGIS so that transformations to SRID 4267 that didn't lie within the "
 "correct range did not throw an ERROR, you would use the following:"
 msgstr ""
+"Le fichier de décalage de grille nul est un fichier de décalage de grille "
+"valide couvrant le monde entier et n'appliquant aucun décalage. Ainsi, pour "
+"un exemple complet, si vous vouliez modifier PostGIS de manière à ce que les "
+"transformations du SRID 4267 qui ne se situent pas dans la plage correcte "
+"n'entraînent pas d'ERREUR, vous utiliseriez ce qui suit :"
 #: reference_srs.xml:278
@@ -620,6 +829,9 @@ msgid ""
 "+nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat,null +no_defs' WHERE srid "
 "= 4267;"
 msgstr ""
+"UPDATE spatial_ref_sys SET proj4text = '+proj=longlat +ellps=clrk66 "
+"+nadgrids=@conus, at alaska, at ntv2_0.gsb, at ntv1_can.dat,null +no_defs' WHERE srid "
+"= 4267 ;"
 #. Tag: para
 #: reference_srs.xml:285
@@ -628,12 +840,14 @@ msgid ""
 ", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_SRID\"/>, <xref "
 "linkend=\"UpdateGeometrySRID\"/>, <xref linkend=\"ST_TransformPipeline\"/>"
 msgstr ""
+", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_SRID\"/>, <xref linkend="
+"\"UpdateGeometrySRID\"/>, <xref linkend=\"ST_TransformPipeline\"/>"
 #. Tag: refname
 #: reference_srs.xml:291
 #, no-c-format
 msgid "ST_TransformPipeline"
-msgstr ""
+msgstr "ST_TransformPipeline"
 #. Tag: refpurpose
 #: reference_srs.xml:293
@@ -643,6 +857,9 @@ msgid ""
 "different spatial reference system using a defined coordinate transformation "
 "pipeline.</refpurpose>"
 msgstr ""
+"<refpurpose>Retourner une nouvelle géométrie avec des coordonnées "
+"transformées dans un système de référence spatial différent à l'aide d'un "
+"pipeline de transformation de coordonnées défini.</refpurpose>"
 #: reference_srs.xml:300
@@ -654,6 +871,11 @@ msgid ""
 msgstr ""
+"<funcdef>geometry <function>ST_TransformPipeline</function></funcdef> "
+"<paramdef><type>geometry </type> <parameter>g1</parameter></paramdef> "
 #. Tag: para
 #: reference_srs.xml:312
@@ -663,6 +885,9 @@ msgid ""
 "spatial reference system using a defined coordinate transformation pipeline."
 "</para>"
 msgstr ""
+"<para>Retourner une nouvelle géométrie dont les coordonnées ont été "
+"pipeline de transformation de coordonnées défini.</para>"
 #. Tag: para
 #: reference_srs.xml:317
@@ -671,6 +896,8 @@ msgid ""
 "Transformation pipelines are defined using any of the following string "
 "formats:"
 msgstr ""
+"Les pipelines de transformation sont définis à l'aide de l'un des formats de "
+"texte suivants :"
 #. Tag: para
 #: reference_srs.xml:321
@@ -680,6 +907,10 @@ msgid ""
 "that a simple <varname>EPSG:CODE</varname> string does not uniquely identify "
 "a coordinate operation: the same EPSG code can be used for a CRS definition."
 msgstr ""
+"<varname>urn:ogc:def:coordinateOperation:AUTHORITY::CODE</varname>. Notez "
+"qu'une simple chaîne de caractère <varname>EPSG:CODE</varname> n'identifie "
+"pas de manière unique une opération de coordonnées : le même code EPSG peut "
+"être utilisé pour une définition CRS."
 #. Tag: para
 #: reference_srs.xml:329
@@ -690,6 +921,10 @@ msgid ""
 "caller will need to add an additional pipeline step, or remove "
 "<varname>axisswap</varname> steps."
 msgstr ""
+"Une chaîne de caractères de pipeline PROJ de la forme : <varname>+"
+"proj=pipeline ...</varname>. La normalisation automatique des axes ne sera "
+"pas appliquée et, si nécessaire, l'appelant devra ajouter une étape de "
+"pipeline supplémentaire ou supprimer les étapes <varname>axisswap</varname>."
 #. Tag: para
 #: reference_srs.xml:337
@@ -699,6 +934,8 @@ msgid ""
 "coordinateOperation,coordinateOperation:EPSG::3895,coordinateOperation:"
 "EPSG::1618</varname>."
 msgstr ""
+"Opérations concaténées de la forme : <varname>urn:ogc:def:coordinateOperation"
+",coordinateOperation:EPSG::3895,coordinateOperation:EPSG::1618</varname>."
 #. Tag: para
 #: reference_srs.xml:345
@@ -711,6 +948,12 @@ msgid ""
 "linkend=\"ST_InverseTransformPipeline\"/> the pipeline is executed in the "
 "inverse direction."
 msgstr ""
+"Le SRID de la géométrie d'entrée est ignoré, et le SRID de la géométrie de "
+"paramètre optionnel <varname>to_srid</varname>. Lors de l'utilisation de "
+"`ST_TransformPipeline()`, le pipeline est exécuté dans la direction avant. "
+"En utilisant <xref linkend=\"ST_InverseTransformPipeline\"/> le pipeline est "
 #: reference_srs.xml:360
@@ -735,6 +978,24 @@ msgid ""
 "(1 row)"
 msgstr ""
+"-- Direction vers l'avant\n"
+"SELECT ST_AsText(ST_TransformPipeline('SRID=4326;POINT(2 49)'::geometry,\n"
+"  'urn:ogc:def:coordinateOperation:EPSG::16031') AS utm_geom);\n"
+"\n"
+"                  utm_geom\n"
+"--------------------------------------------\n"
+" POINT(426857.9877165967 5427937.523342293)\n"
+"(1 row)\n"
+"\n"
+"-- Direction inverse\n"
+"\n"
+"          wgs_geom\n"
+"(1 row)"
 #: reference_srs.xml:363
@@ -775,9 +1036,45 @@ msgid ""
 " POINT(143.0000063280214 -36.999986718287545)\n"
 "(1 row)"
 msgstr ""
+"conversion.\n"
+"SELECT ST_AsText(ST_Transform('SRID=4939;POINT(143.0 -37.0)'::geometry, "
+"7844)) AS gda2020_auto;\n"
+"\n"
+"                 gda2020_auto\n"
+"(1 row)\n"
+"\n"
+"-- using a defined conversion (EPSG:8447)\n"
+"SELECT ST_AsText(ST_TransformPipeline('SRID=4939;POINT(143.0 -37."
+"0)'::geometry,\n"
+"  'urn:ogc:def:coordinateOperation:EPSG::8447')) AS gda2020_code;\n"
+"\n"
+"                   gda2020_code\n"
+"----------------------------------------------\n"
+" POINT(143.0000063280214 -36.999986718287545)\n"
+"(1 row)\n"
+"\n"
+"-- en utilisant une définition de pipeline PROJ correspondant à EPSG:8447, "
+"telle que renvoyée par\n"
+"-- 'projinfo -s EPSG:4939 -t EPSG:7844'.\n"
+"-- NOTE : toute étape 'axisswap' doit être supprimée.\n"
+"0)'::geometry,\n"
+"  '+proj=pipeline\n"
+"   +step +proj=unitconvert +xy_in=deg +xy_out=rad\n"
+"   +step +proj=hgridshift "
+"+grids=au_icsm_GDA94_GDA2020_conformal_and_distortion.tif\n"
+"   +step +proj=unitconvert +xy_in=rad +xy_out=deg')) AS gda2020_pipeline;\n"
+"\n"
+"                   gda2020_pipeline\n"
+"(1 row)"
 #. Tag: para
 #: reference_srs.xml:370
 #, no-c-format
 msgid ", <xref linkend=\"ST_InverseTransformPipeline\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_InverseTransformPipeline\"/>"
Summary of changes:
 doc/po/fr/extras_topology.xml.po  |  13 +-
 doc/po/fr/reference_bbox.xml.po   | 450 ++++++++++++++++++++++++++++++++++++--
 doc/po/fr/reference_raster.xml.po |   8 +-
 doc/po/fr/reference_srs.xml.po    | 333 ++++++++++++++++++++++++++--
 4 files changed, 757 insertions(+), 47 deletions(-)
hooks/post-receive
