[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-807-g08ede3e3f
Fri May 12 07:43:09 PDT 2023
the project "PostGIS".
       via  08ede3e3f105c4e0116125d47a4d34c83487a5ff (commit)
      from  2f8729fdc5924292c476f6418b328cae98168ce1 (commit)
revisions in full, below.
commit 08ede3e3f105c4e0116125d47a4d34c83487a5ff
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 12 12:28:18 2023 +0200
    Fix 2.5 upgrades with views using geography based ST_Distance
    Include tests
    References #5380 in master branch
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 948d7d4e5..6da02e208 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -491,6 +491,7 @@ CREATE OR REPLACE FUNCTION ST_AsGeoJson(text)
 -- Availability: 1.5.0
+-- Replaces ST_Distance(geography, geography) deprecated in 3.0.0
 CREATE OR REPLACE FUNCTION ST_Distance(geog1 geography, geog2 geography, use_spheroid boolean DEFAULT true)
 	RETURNS float8
 	AS 'MODULE_PATHNAME','geography_distance'
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index ae5408c28..41be6fd3c 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -191,7 +191,7 @@ DROP FUNCTION IF EXISTS _ST_DistanceRectTree(g1 geometry, g2 geometry);
 DROP FUNCTION IF EXISTS _ST_DistanceRectTreeCached(g1 geometry, g2 geometry);
 -- Deplicative signatures removed
-DROP FUNCTION IF EXISTS ST_Distance(geography, geography);
+DROP FUNCTION IF EXISTS ST_Distance(geography, geography); -- dropped in PostGIS-3.0 (r17300 aka ce70e4906)
 DROP FUNCTION IF EXISTS ST_Distance(geography, geography, float8, boolean);
 DROP FUNCTION IF EXISTS ST_Buffer(geometry, float8, cstring);
 DROP FUNCTION IF EXISTS ST_IsValidDetail(geometry);
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 7f95eb762..b639ff77c 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -6,6 +6,7 @@ DROP VIEW IF EXISTS upgrade_view_test_force_dims;
 DROP VIEW IF EXISTS upgrade_view_test_askml;
 DROP VIEW IF EXISTS upgrade_view_test_dwithin;
 DROP VIEW IF EXISTS upgrade_view_test_clusterkmeans;
+DROP VIEW IF EXISTS upgrade_view_test_distance;
 DROP TABLE upgrade_test;
 -- Drop functions deprecated on upgrade
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index c156548a9..49d0c8139 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -65,6 +65,15 @@ SELECT
 	ST_ClusterKMeans(g1, 1) OVER ()
 FROM upgrade_test;
+-- This view uses ST_Distance signatures, available since 1.5.0
+-- NOTE: 3.0.0 changed them to use default arguments
+-- See https://trac.osgeo.org/postgis/ticket/5380
+CREATE VIEW upgrade_view_test_distance AS
+SELECT
+	ST_Distance(g2, g2) geog_dist1,
+	ST_Distance(g2, g2, true) geog_dist2
+FROM upgrade_test;
 -- Break probin of all postgis functions, as we expect
 -- the upgrade procedure to replace them all
 UPDATE pg_proc SET probin = probin || '-uninstalled'
Summary of changes:
 postgis/geography.sql.in              | 1 +
 postgis/postgis_after_upgrade.sql     | 2 +-
 regress/hooks/hook-after-upgrade.sql  | 1 +
 regress/hooks/hook-before-upgrade.sql | 9 +++++++++
 4 files changed, 12 insertions(+), 1 deletion(-)
hooks/post-receive
