[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-893-g46ebbe834
Mon May 15 11:11:45 PDT 2023
the project "PostGIS".
       via  46ebbe834632b320c75c9743795d7c3c0bad7c77 (commit)
      from  0c39e21d947dceac6cf304a4cd3ce04e0069281f (commit)
revisions in full, below.
commit 46ebbe834632b320c75c9743795d7c3c0bad7c77
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 15 20:06:42 2023 +0200
    Add sql script to check downgrade protections
diff --git a/utils/check_extension_downgrades.sql b/utils/check_extension_downgrades.sql
new file mode 100644
index 000000000..53d9dc878
--- /dev/null
+++ b/utils/check_extension_downgrades.sql
@@ -0,0 +1,47 @@
+DO $SQL$
+DECLARE
+	rec RECORD;
+	sql TEXT;
+	test_ext TEXT;
+	from_version TEXT;
+BEGIN
+	-- TODO: test all extensions ?
+	test_ext := 'postgis';
+	FOR rec IN
+		SELECT * FROM pg_available_extension_versions
+		WHERE name = test_ext
+		AND version NOT LIKE '%next'
+		AND version NOT IN ( 'unpackaged', 'ANY')
+		ORDER BY string_to_array(
+			regexp_replace(version, '[^0-9.]', '', 'g'), '.'
+		)::int[] DESC
+	LOOP
+		IF from_version IS NULL THEN
+			from_version := rec.version;
+			sql := format('CREATE EXTENSION %I VERSION %L', test_ext, from_version);
+			EXECUTE sql;
+		ELSE
+			sql := format('ALTER EXTENSION %I UPDATE TO %L', test_ext, rec.version);
+			BEGIN
+				EXECUTE sql;
+				-- expect error like Downgrade of postgis from version 3.4.0dev 3.3.0rc2-808-g6080076af to version 3.3.3dev is forbidden
+			EXCEPTION WHEN OTHERS THEN
+				IF SQLERRM LIKE 'Downgrade % is forbidden' THEN
+					RAISE NOTICE 'PASS: %', SQLERRM;
+				ELSE
+					RAISE EXCEPTION 'FAIL: % to % downgrade was not handled: %',
+						from_version, rec.version, SQLERRM;
+				END IF;
+			END;
+		END IF;
+	END LOOP;
+	sql := format('DROP EXTENSION IF EXISTS %I', test_ext);
+	EXECUTE sql;
+END
+$SQL$ LANGUAGE 'plpgsql';
Summary of changes:
 utils/check_extension_downgrades.sql | 47 ++++++++++++++++++++++++++++++++++++
 1 file changed, 47 insertions(+)
 create mode 100644 utils/check_extension_downgrades.sql
hooks/post-receive
