[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-895-g03d46d8ea
Mon May 15 11:45:53 PDT 2023
the project "PostGIS".
       via  03d46d8eaa264ddf310e3a0285dce659bd5da1b7 (commit)
       via  4b6b0de917d05520e108de1ea4545ae17ce07a2b (commit)
      from  46ebbe834632b320c75c9743795d7c3c0bad7c77 (commit)
revisions in full, below.
commit 03d46d8eaa264ddf310e3a0285dce659bd5da1b7
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 15 20:45:24 2023 +0200
    Fix xml entities in french translation
    This was done by running utils/fix_xml_entities.sh
diff --git a/doc/po/fr/extras_historytable.xml.po b/doc/po/fr/extras_historytable.xml.po
index 0380dc768..2443645b6 100644
--- a/doc/po/fr/extras_historytable.xml.po
+++ b/doc/po/fr/extras_historytable.xml.po
@@ -176,8 +176,8 @@ msgid ""
 "        ( date_deleted >= 'January 1, 2001' OR date_deleted IS NULL );"
 msgstr ""
 "SELECT * FROM roads_history\n"
-"    WHERE date_added &lt ; 'January 1, 2001' AND\n"
-"        ( date_deleted &gt ;= 'January 1, 2001' OR date_deleted IS NULL ) ;"
+"    WHERE date_added < 'January 1, 2001' AND\n"
+"        ( date_deleted >= 'January 1, 2001' OR date_deleted IS NULL ) ;"
 #. Tag: refname
 #: extras_historytable.xml:38
diff --git a/doc/po/fr/reference_accessor.xml.po b/doc/po/fr/reference_accessor.xml.po
index bdc3a60a1..b7fe01537 100644
--- a/doc/po/fr/reference_accessor.xml.po
+++ b/doc/po/fr/reference_accessor.xml.po
@@ -387,7 +387,7 @@ msgstr "&sfs_compliant; OGC SPEC s2.1.1.1"
 #: reference_accessor.xml:94
 #, no-c-format
 msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 5.1.17"
-msgstr "&sqlmm_compliant ; SQL-MM IEC 13249-3 : 5.1.17"
+msgstr "&sqlmm_compliant; SQL-MM IEC 13249-3 : 5.1.17"
 #. Tag: para
 #: reference_accessor.xml:96
@@ -2158,7 +2158,7 @@ msgstr "&sfs_compliant; s2.1.1.1"
 #: reference_accessor.xml:673
 #, no-c-format
 msgid "&sqlmm_compliant; SQL-MM 3: 5.1.19"
-msgstr "&sqlmm_compliant ; SQL-MM 3 : 5.1.19"
+msgstr "&sqlmm_compliant; SQL-MM 3 : 5.1.19"
 #. Tag: programlisting
 #: reference_accessor.xml:679
@@ -2492,7 +2492,7 @@ msgstr ""
 "11, 12 11))') )\n"
 "        )As foo(geom)\n"
 "        CROSS JOIN generate_series(1,100) n\n"
-"WHERE n &lt ;= ST_NumGeometries(geom) ;\n"
+"WHERE n <= ST_NumGeometries(geom) ;\n"
 "\n"
 " n |               geomewkt\n"
 "---+-----------------------------------------\n"
@@ -2508,7 +2508,7 @@ msgstr ""
 "\n"
 "SELECT gid, n, ST_GeometryN(geom, n)\n"
 "FROM sometable CROSS JOIN generate_series(1,100) n\n"
-"WHERE n &lt ;= ST_NumGeometries(geom) ;"
+"WHERE n <= ST_NumGeometries(geom) ;"
 #: reference_accessor.xml:798
@@ -4263,7 +4263,7 @@ msgstr "Disponibilité : 2.0.0"
 #: reference_accessor.xml:1680 reference_accessor.xml:1771
 #, no-c-format
 msgid "&sqlmm_compliant; SQL-MM ISO/IEC 13249-3: 8.5"
-msgstr "&sqlmm_compliant ; SQL-MM ISO/IEC 13249-3 : 8.5"
+msgstr "&sqlmm_compliant; SQL-MM ISO/IEC 13249-3 : 8.5"
 #: reference_accessor.xml:1687
diff --git a/doc/po/fr/reference_srs.xml.po b/doc/po/fr/reference_srs.xml.po
index 35b9fdb5f..de7db18c8 100644
--- a/doc/po/fr/reference_srs.xml.po
+++ b/doc/po/fr/reference_srs.xml.po
@@ -384,7 +384,7 @@ msgstr "&sfs_compliant; s2.1.1.1"
 #: reference_srs.xml:149
 #, no-c-format
 msgid "&sqlmm_compliant; SQL-MM 3: 5.1.5"
-msgstr "&sqlmm_compliant ; SQL-MM 3 : 5.1.5"
+msgstr "&sqlmm_compliant; SQL-MM 3 : 5.1.5"
 #: reference_srs.xml:157
diff --git a/doc/po/fr/using_postgis_app.xml.po b/doc/po/fr/using_postgis_app.xml.po
index 72f5ac734..465cbaf04 100644
--- a/doc/po/fr/using_postgis_app.xml.po
+++ b/doc/po/fr/using_postgis_app.xml.po
@@ -233,7 +233,7 @@ msgid ""
 msgstr ""
 "La connexion à la base de données est régie par une \"chaîne de connexion\" "
 "qui est un ensemble standard de clés et de valeurs comme ceci (avec les "
-"valeurs par défaut dans &lt ;&gt ;) :"
+"valeurs par défaut dans <>) :"
 #. Tag: para
 #: using_postgis_app.xml:80
diff --git a/doc/po/fr/using_postgis_query.xml.po b/doc/po/fr/using_postgis_query.xml.po
index 7faa463b5..92547cfa5 100644
--- a/doc/po/fr/using_postgis_query.xml.po
+++ b/doc/po/fr/using_postgis_query.xml.po
@@ -714,7 +714,7 @@ msgstr ""
 "SELECT a.id\n"
 "FROM roads a, roads b\n"
 "WHERE a.id != b.id\n"
-"      AND a.geom &amp ;&amp ; b.geom\n"
+"      AND a.geom && b.geom\n"
 "      AND ST_Relate(a.geom, b.geom, '1*1***1**') ;"
 #. Tag: para
@@ -742,7 +742,7 @@ msgstr ""
 "-- Trouver des quais en partie sur les rives d'un lac\n"
 "SELECT a.lake_id, b.wharf_id\n"
 "FROM lakes a, wharfs b\n"
-"WHERE a.geom &amp ;&amp ; b.geom\n"
+"WHERE a.geom && b.geom\n"
 "      AND ST_Relate(a.geom, b.geom, '102101FF2') ;"
 #. Tag: title
commit 4b6b0de917d05520e108de1ea4545ae17ce07a2b
Date:   Mon May 15 20:45:15 2023 +0200
    Add script to fix xml entities
diff --git a/utils/fix_xml_entities.sh b/utils/fix_xml_entities.sh
new file mode 100755
index 000000000..883c6a71c
--- /dev/null
+++ b/utils/fix_xml_entities.sh
@@ -0,0 +1,7 @@
+#!/bin/sh
+cd $(dirname $0)/..
+perl -CSDL -pi \
+	-e 's/\&([_a-z]*)[\s\h][\s\h]*;/&\1;/g' \
+	$(find doc/po/ -name *.po)
Summary of changes:
 doc/po/fr/extras_historytable.xml.po |  4 ++--
 doc/po/fr/reference_accessor.xml.po  | 10 +++++-----
 doc/po/fr/reference_srs.xml.po       |  2 +-
 doc/po/fr/using_postgis_app.xml.po   |  2 +-
 doc/po/fr/using_postgis_query.xml.po |  4 ++--
 utils/fix_xml_entities.sh            |  7 +++++++
 6 files changed, 18 insertions(+), 11 deletions(-)
 create mode 100755 utils/fix_xml_entities.sh
hooks/post-receive
