[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.4-26-gd04d1fc9f
Tue May 16 08:14:10 PDT 2023
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  d04d1fc9f0c99ca5fce006ae43af03e7de197351 (commit)
      from  76505b970ea1c91bdde2870652c4415ab359083e (commit)
revisions in full, below.
commit d04d1fc9f0c99ca5fce006ae43af03e7de197351
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue May 16 17:13:37 2023 +0200
    Use library minor version in berrie, bessie and dronie too
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index d737795f6..7711a7412 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -16,7 +16,8 @@ echo $WORKSPACE
 sh autogen.sh
 ./configure --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${GEOS_PATH}/bin/geos-config \
-	--without-protobuf
+  --without-protobuf \
+  --with-library-minor-version
 #make clean
 make
 export err_status=0
diff --git a/ci/bessie/postgis_regress.sh b/ci/bessie/postgis_regress.sh
index 020fe565a..7057d0649 100644
--- a/ci/bessie/postgis_regress.sh
+++ b/ci/bessie/postgis_regress.sh
@@ -1,7 +1,11 @@
 #BRANCH is passed in via jenkins which is set via svn hook
 export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
 sh autogen.sh
-./configure --with-projdir=/usr/local --with-libiconv=/usr/local --without-interrupt-tests
+./configure \
+  --with-projdir=/usr/local \
+  --with-libiconv=/usr/local \
+  --without-interrupt-tests \
 make clean
 make
 export PGUSER=postgres
diff --git a/ci/bessie32/postgis_regress.sh b/ci/bessie32/postgis_regress.sh
index 0d721ca43..3e0251b47 100644
--- a/ci/bessie32/postgis_regress.sh
+++ b/ci/bessie32/postgis_regress.sh
@@ -9,7 +9,19 @@ export CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/g
 export CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc"
 sh autogen.sh
-./configure PKG_CONFIG=/usr/local/bin/pkgconf LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --without-interrupt-tests --with-topology --with-raster --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf --with-wagyu
+./configure \
+  PKG_CONFIG=/usr/local/bin/pkgconf \
+  LDFLAGS="-L/usr/local/lib" \
+  --with-libiconv-prefix=/usr/local \
+  --without-gui \
+  --with-topology \
+  --with-raster \
+  --with-sfcgal=/usr/local/bin/sfcgal-config \
+  --with-address-standardizer \
+  --with-protobuf \
+  --with-wagyu \
 make
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index 2f38d0210..67caf8719 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -8,7 +8,10 @@ export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{pr
 export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
 psql --version
 ./autogen.sh
-./configure CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
+./configure \
+  CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror" \
 make clean
 make -j
 # we should maybe wait for postgresql service to startup here...
Summary of changes:
 ci/berrie/postgis_regress.sh   |  3 ++-
 ci/bessie/postgis_regress.sh   |  6 +++++-
 ci/bessie32/postgis_regress.sh | 14 +++++++++++++-
 ci/dronie/postgis_regress.sh   |  5 ++++-
 4 files changed, 24 insertions(+), 4 deletions(-)
hooks/post-receive
