[postgis-tickets] [PostGIS] #2676: Change Debbie to also test extension upgrade
PostGIS trac at osgeo.org
Tue May 16 09:41:04 PDT 2023
  Reporter:  robe         |      Owner:  robe
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  Website Management, Bots
 Component:  buildbots    |    Version:  2.1.x
Resolution:  fixed        |   Keywords:
Changes (by strk):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 Debbie is definitely testing upgrades now, as shown by the (failing)
 upgrade test in https://debbie.postgis.net/job/PostGIS_Regress/25034/
 I think the failure at hand was due to not using postgis minor library
 version when installing, and builds upgrading from installs of other
 builds. Everything pretty unstable if you ask me, but somehow these
 permutations might be also good testing.
 HOpefully [76505b970ea1c91bdde2870652c4415ab359083e/git] fixed the failure
 but the focus of THIS ticket was to request Debbie testing of upgrades and
 so I'm closing it as done.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2676#comment:11>
