[postgis-tickets] [PostGIS] #5297: woodie and dronie not picking up docbook check issues
PostGIS trac at osgeo.org
Tue May 16 10:25:18 PDT 2023
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  critical   |  Milestone:  PostGIS 3.4.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by strk):
 I've started build https://debbie.postgis.net/view/PostGIS/job/PostGIS-
 docker/33/ which hopefully will result in publishing the updated image
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5297#comment:5>
