[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-902-g9ea7418ef
Wed May 17 04:37:44 PDT 2023
the project "PostGIS".
       via  9ea7418efd73a964327c73447c6feaf98fc41db6 (commit)
       via  4b5eebc5556000586497e850bb1c3579bf913c02 (commit)
       via  0d8a0c88a74da999134bdb18a6935db1160e0d56 (commit)
       via  cc3cb675883706af22dbfa2d1088c7202910a2d8 (commit)
      from  994b97db9af7d193469bf0036a5808e7dafa522b (commit)
revisions in full, below.
commit 9ea7418efd73a964327c73447c6feaf98fc41db6
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed May 17 13:37:28 2023 +0200
    Allow passing a custom name for the garden db
diff --git a/regress/Makefile.in b/regress/Makefile.in
index 41f1ebe62..070f1388a 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -23,6 +23,12 @@ POSTGIS_MAJOR_VERSION=@POSTGIS_MAJOR_VERSION@
 POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
 POSTGIS_MICRO_VERSION=@POSTGIS_MICRO_VERSION@
+# To use a custom database name, run:
+#    make garden GARDENDB=custom_db_name
+GARDENDB=postgis_garden
 # Where we put our regression installation
 # See https://trac.osgeo.org/postgis/ticket/5066
 ifeq ($(MINGWBUILD),1)
@@ -94,16 +100,16 @@ staged-install:
 	$(PERL) -pi -e 's,\$$libdir,$(REGRESS_INSTALLDIR)/lib,g' $(REGRESS_INSTALLDIR)/share/contrib/postgis/*.sql
 garden: staged-install
-	createdb postgis_garden
-	psql -qX -v ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/postgis.sql
-	psql -qX -v ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/spatial_ref_sys.sql
-	psql -qX -v ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/rtpostgis.sql
+	createdb $(GARDENDB)
+	psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/postgis.sql
+	psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/spatial_ref_sys.sql
+	psql -qX -v ON_ERROR_STOP=true -d $(GARDENDB) < $(REGRESS_INSTALLDIR)/share/contrib/postgis/rtpostgis.sql
 	@echo '-------------------------------------------------'
 	@echo 'Regression tests in progress (it will take time)'
 	@echo 'Result output: ./regress/postgis_garden_result.txt'
-	psql -X -ad postgis_garden < ../doc/postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > postgis_garden_result.txt 2>&1
+	psql -X -ad $(GARDENDB) < ../doc/postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > postgis_garden_result.txt 2>&1
 	tail postgis_garden_result.txt
-	psql -X -ad postgis_garden < ../doc/raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > raster_garden_result.txt 2>&1
+	psql -X -ad $(GARDENDB) < ../doc/raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > raster_garden_result.txt 2>&1
 	tail raster_garden_result.txt
-	#dropdb postgis_garden
+	#dropdb $(GARDENDB)
commit 4b5eebc5556000586497e850bb1c3579bf913c02
Date:   Wed May 17 13:12:30 2023 +0200
    Stop using createlang plpgsql, not needed since PostgreSQL 9.0
diff --git a/extras/template_gis/postgres_lib.sh.in b/extras/template_gis/postgres_lib.sh.in
index 2daf29812..331d66fd1 100644
--- a/extras/template_gis/postgres_lib.sh.in
+++ b/extras/template_gis/postgres_lib.sh.in
@@ -81,14 +81,11 @@ function template_mk()
 	    if [ -n "$GRID" ]; then
 			psql -d $TDB -c "UPDATE pg_database SET datdba = $GRID WHERE datname = '$TDB';" 2>&1 | cat > /dev/null
 	    fi
-		if [ -x @bindir@/createlang ]; then
-			@bindir@/createlang plpgsql $TDB 2>&1 | cat > /dev/null
-		fi
 		for script in $SCRIPTS ; do
 			psql -d $TDB -f $script 2>&1 | cat > /dev/null
 		done
 		#pseudo tables for postgresql 7.2 and 7.4. feel free to add more, for other postgresql versions
-		PSEUDO_TABLES="'pg_xactlock', 'sql_features', 'sql_implementation_info', 'sql_languages',
+		PSEUDO_TABLES="'pg_xactlock', 'sql_features', 'sql_implementation_info', 'sql_languages',
 					   'sql_packages', 'sql_sizing', 'sql_sizing_profiles'"
 		TABLES=`psql -d $TDB -At -c "select tablename from pg_tables where tablename not in ($PSEUDO_TABLES);"`
diff --git a/raster/scripts/python/Makefile.rt.sample b/raster/scripts/python/Makefile.rt.sample
index a9d0514bc..afb83d13c 100644
--- a/raster/scripts/python/Makefile.rt.sample
+++ b/raster/scripts/python/Makefile.rt.sample
@@ -61,7 +61,6 @@ create:
 ifdef DBNAME
 	@echo "****** Creating database '$(DBNAME)'..."
 	@createdb --tablespace=tablespace2 $(DBNAME) > /dev/null $(ERROUT);
-	@createlang plpgsql $(DBNAME) > /dev/null $(ERROUT);
 	@echo "****** Loading PostGIS into '$(DBNAME)'..."
 	@psql -d $(DBNAME) -f $(POSTGIS)/postgis.sql > /dev/null $(ERROUT);
 	@psql -d $(DBNAME) -f $(POSTGIS)/spatial_ref_sys.sql > /dev/null $(ERROUT);
index 3678a7477..41f1ebe62 100644
@@ -95,7 +95,6 @@ staged-install:
-	createlang plpgsql postgis_garden || true #tolerate an error here
diff --git a/regress/test_index_concurrency b/regress/test_index_concurrency
index 9692affef..0ba8ccebe 100755
--- a/regress/test_index_concurrency
+++ b/regress/test_index_concurrency
@@ -18,18 +18,17 @@ if [ "$1" = "prepare" ]; then
 	echo ""
 	createdb > /dev/null
-	createlang plpgsql > /dev/null
 	psql -f ../lwpostgis.sql > /dev/null 2>&1
-	psql -f regress_lots_of_points.sql
-	psql -c "CREATE INDEX quick_gist on test using gist (the_geom)"
+	psql -f regress_lots_of_points.sql
+	psql -c "CREATE INDEX quick_gist on test using gist (the_geom)"
 else
 if [ "$1" = "run" ]; then
 	# Concurrent clients:
 	psql -c "update test set num=-num WHERE the_geom && 'BOX3D(125 125,135 135)'::box3d"  &
 	wait
 else
 if [ "$1" = "drop" ]; then
commit 0d8a0c88a74da999134bdb18a6935db1160e0d56
Date:   Wed May 17 13:04:45 2023 +0200
    Make garden output quiet
index 7aad562f5..3678a7477 100644
@@ -96,15 +96,15 @@ staged-install:
-	psql --no-psqlrc --variable ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/postgis.sql && \
-	psql --no-psqlrc --variable ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/spatial_ref_sys.sql || true # tolerate an error here
-	psql --no-psqlrc --variable ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/rtpostgis.sql || true #tolerate an error here
+	psql -qX -v ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/postgis.sql
+	psql -qX -v ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/spatial_ref_sys.sql
+	psql -qX -v ON_ERROR_STOP=true -d postgis_garden < $(REGRESS_INSTALLDIR)/share/contrib/postgis/rtpostgis.sql
-	psql --no-psqlrc -ad postgis_garden < ../doc/postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > postgis_garden_result.txt 2>&1
+	psql -X -ad postgis_garden < ../doc/postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > postgis_garden_result.txt 2>&1
-	psql --no-psqlrc -ad postgis_garden < ../doc/raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > raster_garden_result.txt 2>&1
+	psql -X -ad postgis_garden < ../doc/raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql > raster_garden_result.txt 2>&1
commit cc3cb675883706af22dbfa2d1088c7202910a2d8
Date:   Wed May 17 12:58:40 2023 +0200
    Fix make garden from out-of-tree builds
    Closes #5383
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 18f7130fe..38c2c52a7 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -424,12 +424,11 @@ uninstall: comments-uninstall
 ifeq ($(XSLTPROC),)
 garden: requirements_not_met_xsltproc
 else
-garden:	xsl/postgis_gardentest.sql.xsl $(XML_INPUTS)
-	$(XSLTPROC) -o postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql xsl/postgis_gardentest.sql.xsl postgis-out.xml
-	$(XSLTPROC) -o raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql xsl/raster_gardentest.sql.xsl postgis-out.xml
+garden: postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql raster_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
 endif
+%_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql: xsl/postgis_gardentest.sql.xsl postgis-out.xml
+	$(XSLTPROC) -o $@ --path $(srcdir) $^
 check: check-unit
 check-regress:
Summary of changes:
 doc/Makefile.in                          |  7 +++----
 extras/template_gis/postgres_lib.sh.in   |  5 +----
 raster/scripts/python/Makefile.rt.sample |  1 -
 regress/Makefile.in                      | 21 +++++++++++++--------
 regress/test_index_concurrency           |  7 +++----
 5 files changed, 20 insertions(+), 21 deletions(-)
hooks/post-receive
