[postgis-tickets] [PostGIS] #5384: ST_AsGML with empty nprefix crashes backend
PostGIS trac at osgeo.org
Wed May 17 11:11:41 PDT 2023
  Reporter:  strk     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.0.9
 Component:  postgis  |    Version:  3.0.x
Resolution:  fixed    |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"72385411f024b32c4975f88886c42e3ce3ca032c/git"
 72385411/git]:
 {{{#!CommitTicketReference repository="git"
 revision="72385411f024b32c4975f88886c42e3ce3ca032c"
 Fix crash in ST_AsGML when given id is longer than given prefix
 Includes regress test.
 Closes #5384 in 3.0 branch (3.0.9dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5384#comment:5>
