[postgis-tickets] [PostGIS] #5384: ST_AsGML with empty nprefix crashes backend
PostGIS trac at osgeo.org
Wed May 17 11:33:58 PDT 2023
  Reporter:  strk     |      Owner:  strk
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 3.0.9
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Reopening as there are more memory issues in that code path, see
 https://debbie.postgis.net/job/PostGIS_Regress/25157/console
 showing:
 20:04:46 +WARNING:  problem in alloc set ExprContext: detected write past
 chunk end in block 0x55c3b87a2590, chunk 0x55c3b87a2628
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5384#comment:9>
