[postgis-tickets] [SCM] postgis.net branch website updated. clarity-final-17-g0c38926
Thu May 18 08:59:39 PDT 2023
the project "postgis.net".
The branch, website has been updated
       via  0c3892672c0d334ba420bd9703e40b7f06f8f04f (commit)
       via  46a81c174872dc96304bac1adaef1ab362350d3c (commit)
      from  6ef1f3a9d54778ec79f30f402125c311d9958ef7 (commit)
revisions in full, below.
commit 0c3892672c0d334ba420bd9703e40b7f06f8f04f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu May 18 08:59:33 2023 -0700
    Another image!
diff --git a/content/documentation/faq/intersection-intersect/grid.png b/content/documentation/faq/intersection-intersect/grid.png
new file mode 100644
index 0000000..bd92cc1
Binary files /dev/null and b/content/documentation/faq/intersection-intersect/grid.png differ
diff --git a/content/documentation/faq/intersection-intersect.md b/content/documentation/faq/intersection-intersect/index.md
similarity index 99%
rename from content/documentation/faq/intersection-intersect.md
rename to content/documentation/faq/intersection-intersect/index.md
index 2955deb..7943569 100644
--- a/content/documentation/faq/intersection-intersect.md
+++ b/content/documentation/faq/intersection-intersect/index.md
@@ -33,6 +33,8 @@ Coordinates in PostGIS are represented as pairs of "[floating point](https://en.
 The rule that "where A intersects B at P, P will be on both A and B" is a mathematical rule for the "real numbers" of which there are an infinite number. The finite quantity of numbers that a computer's floating point can represent end up looking like a piece of graph paper.
+![](grid.png)
 If you draw a straight line on a piece of graph paper, mostly the line won't hit many graph crossing points. The same is true of lines in the world of the "floating point grid". The result is that the calculated intersection of two lines, frequently does not land on either of the lines, but instead lands on a (very very close) nearby point that is representable as a floating point number.
commit 46a81c174872dc96304bac1adaef1ab362350d3c
Date:   Thu May 18 08:38:44 2023 -0700
    Add an image to a faq entry!
diff --git a/content/documentation/faq/geography-inside.md b/content/documentation/faq/geography-inside/index.md
similarity index 98%
rename from content/documentation/faq/geography-inside.md
rename to content/documentation/faq/geography-inside/index.md
index c36145b..82a57ba 100644
--- a/content/documentation/faq/geography-inside.md
+++ b/content/documentation/faq/geography-inside/index.md
@@ -38,5 +38,7 @@ The answer is in the different spaces the two types work within:
 In our example, the northernmost edge of the box will be a `LINESTRING(0 10, 80 10)` which in geometry is a horizontal straight line, but in geography is a great circle that curves slightly to the north, so much so that it passes to the north of our test 'POINT(40 10.1)'.
+![](linestring.png)
 In reasoning about geography, it is always important to remember that the **edges are great circles**. East/west lines north of the equator will bend north a little, and south of the equator will bend south a little.
diff --git a/content/documentation/faq/geography-inside/linestring.png b/content/documentation/faq/geography-inside/linestring.png
index 0000000..836001b
Binary files /dev/null and b/content/documentation/faq/geography-inside/linestring.png differ
Summary of changes:
 .../{geography-inside.md => geography-inside/index.md} |   2 ++
 .../documentation/faq/geography-inside/linestring.png  | Bin 0 -> 269511 bytes
 .../documentation/faq/intersection-intersect/grid.png  | Bin 0 -> 39232 bytes
 .../index.md}                                          |   2 ++
 4 files changed, 4 insertions(+)
 rename content/documentation/faq/{geography-inside.md => geography-inside/index.md} (98%)
 create mode 100644 content/documentation/faq/geography-inside/linestring.png
 create mode 100644 content/documentation/faq/intersection-intersect/grid.png
 rename content/documentation/faq/{intersection-intersect.md => intersection-intersect/index.md} (99%)
hooks/post-receive
postgis.net
