[postgis-tickets] [SCM] postgis.net branch website updated. clarity-final-19-gc535830
Thu May 18 13:22:18 PDT 2023
the project "postgis.net".
The branch, website has been updated
       via  c535830c6eddb68d0be21e088ce45bc8c1b46db0 (commit)
      from  c99bd2d97949b02421b11e543dcad14f5b4041fb (commit)
revisions in full, below.
commit c535830c6eddb68d0be21e088ce45bc8c1b46db0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu May 18 13:22:09 2023 -0700
    remove redundant tip
diff --git a/content/documentation/tips/tip_pgadmin_shows_no_data.md b/content/documentation/tips/tip_pgadmin_shows_no_data.md
deleted file mode 100644
index 2cb0df4..0000000
--- a/content/documentation/tips/tip_pgadmin_shows_no_data.md
+++ /dev/null
@@ -1,83 +0,0 @@
-title: "pgAdmin shows no data"
-slug: "tip_pgadmin_shows_no_data"
-layout: post
-category: tips
-tags: [newbie,geometry,geography,raster]
-author: Regina Obe
-date: "2013-10-05"
-thumbnail:
-geekdocHidden: true
-geekdocHiddenTocTree: false
-weight: 90
-Every one or two months, someone asks on the PostGIS users list usually somewhat panicked, *My geometry is missing when I look in pgAdmin III*
-This is documented in the PostGIS Frequently Asked questions section of the manual <a href="/docs/manual-dev/PostGIS_FAQ.html#pgadmin_shows_no_data_in_geom" target="_blank">I tried to use PgAdmin to view my geometry column and it is blank, what gives?</a>
-Since this question gets asked so much, I thought it best to highlight it again.
-Spatial objects can be big things and if your geometry, geography, or raster row field is big enough, pgAdmin is not going to load it
-and will just show an empty field.  This is by design.  There are a couple of ways to verify you really have data and even how big your geometry, geography or raster column is
-<!--more-->
-**Examples**
-***Check there is really data.  This will work for anything and will return a count of all objects that have no data in geom column***
-This query will also work for raster, geometry, and geography
-```postgres
-SELECT count(*)
- FROM  mytable
-  WHERE geom IS NULL;
-**How big are my spatial objects?**
-These next examples may take a while to run depending on how big your table, so proceed with caution.
-***How big are my geometries?***
-This will return the max number of points in a geometry column
-```postgres
-SELECT Max(ST_NPoints(geom))
-FROM mytable;
-***How big are my geographies?***
-Unfortunately geography doesn't have a native <a href="/docs/manual-dev/ST_NPoints.html" target="_blank">```ST_NPoints```</a> function, but you can piggy back on the geometry one.
-```postgres
-SELECT Max(
- ST_NPoints(geog::geometry)
-FROM mytable;
-***How big are my rasters?***
-A raster column has widthxheight number of pixels in it.  So the below query will give you a sense of how many pixels you've got
-in each row.
-```postgres
-SELECT
- Max(ST_Width(rast)) As w
- , Max(ST_Height(rast)) As h
-FROM mytable;
-If you loaded your rasters with -C constraint option, you can do the much much faster check of raster_columns.
-raster_columns will only show a blocksize_x and blocksize_y if you applied constraints and all your raster tiles
-are off the same width/height dimensions.
-```postgres
-SELECT
- blocksize_x As w
- , blocksize_y As h
-FROM raster_columns
-WHERE r_table_name = 'mytable'
- AND r_raster_column='rast';
Summary of changes:
 .../tips/tip_pgadmin_shows_no_data.md              | 83 ----------------------
 1 file changed, 83 deletions(-)
 delete mode 100644 content/documentation/tips/tip_pgadmin_shows_no_data.md
hooks/post-receive
postgis.net
