[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-910-g9ffcf3546
Thu May 18 16:05:01 PDT 2023
the project "PostGIS".
       via  9ffcf35468db241308ae961fbac851a5443f4fec (commit)
      from  c3a1796345775c49691d5563056ab0f7aad50005 (commit)
revisions in full, below.
commit 9ffcf35468db241308ae961fbac851a5443f4fec
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 19 01:04:41 2023 +0200
    Provide an sql version of extensions unpackage
diff --git a/extensions/extensions_unpackage.sh b/extensions/extensions_unpackage.sh
index 44a6384ca..b88bb7d21 100755
--- a/extensions/extensions_unpackage.sh
+++ b/extensions/extensions_unpackage.sh
@@ -6,30 +6,4 @@ test -n "$1" || {
 db="$1"
-EXTENSIONS="postgis_sfcgal postgis_raster postgis_topology postgis"
-  for ext in $EXTENSIONS; do
-    cat <<EOF
-SELECT 'ALTER EXTENSION ' || extname || ' DROP ' ||
-  regexp_replace(
-    regexp_replace(
-      pg_catalog.pg_describe_object(d.classid, d.objid, 0),
-      E'cast from (.*) to (.*)',
-      E'cast\\(\\\\1 as \\\\2\\)'
-    E'(.*) for access method (.*)',
-    E'\\\\1 using \\\\2'
-  ) || ';' AS sqladd
-FROM pg_catalog.pg_depend AS d
-INNER JOIN pg_extension AS e ON (d.refobjid = e.oid)
-WHERE d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass
-AND deptype = 'e' AND e.extname = '${ext}' ORDER BY sqladd;
-SELECT 'DROP EXTENSION IF EXISTS ${ext};';
-EOF
-  done
-) | psql -XtA ${db}
+psql -XtA -f $(dirname $0)/extensions_unpackage.sql ${db}
diff --git a/extensions/extensions_unpackage.sql b/extensions/extensions_unpackage.sql
new file mode 100644
index 000000000..2638f3d97
--- /dev/null
+++ b/extensions/extensions_unpackage.sql
@@ -0,0 +1,31 @@
+\set QUIET
+BEGIN;
+set client_min_messages to WARNING;
+SELECT 'ALTER EXTENSION ' || extname || ' DROP ' ||
+  regexp_replace(
+    regexp_replace(
+      pg_catalog.pg_describe_object(d.classid, d.objid, 0),
+      'cast from (.*) to (.*)',
+      'cast(\1 as \2)'
+    '(.*) for access method (.*)',
+    '\1 using \2'
+FROM pg_catalog.pg_depend AS d
+INNER JOIN pg_extension AS e ON (d.refobjid = e.oid)
+WHERE d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass
+AND deptype = 'e' AND e.extname in (
+	'postgis_sfcgal',
+	'postgis_raster',
+	'postgis_topology',
+	'postgis'
+ORDER BY length(e.extname) DESC
+\gexec
+DROP EXTENSION IF EXISTS postgis_sfcgal;
+DROP EXTENSION IF EXISTS postgis_raster;
+DROP EXTENSION IF EXISTS postgis_topology;
+DROP EXTENSION IF EXISTS postgis;
+SELECT 'PostGIS objects unpackaged';
+COMMIT;
Summary of changes:
 extensions/extensions_unpackage.sh  | 28 +---------------------------
 extensions/extensions_unpackage.sql | 31 +++++++++++++++++++++++++++++++
 2 files changed, 32 insertions(+), 27 deletions(-)
 create mode 100644 extensions/extensions_unpackage.sql
hooks/post-receive
