[postgis-tickets] [PostGIS] #5386: ST_MapAlgebra not respecting NULL nodatavalues
PostGIS trac at osgeo.org
Fri May 19 04:28:22 PDT 2023
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  high    |  Milestone:  PostGIS 3.0.9
 Component:  raster  |    Version:  3.3.x
Resolution:          |   Keywords:
Comment (by robe):
 I also tried the original signature:
 st_mapalgebraexpr(
         rast raster,
         band integer,
         pixeltype text,
         expression text,
         nodataval double precision DEFAULT NULL::double precision)
  and this also seems to ignore the input nodataval even calling by named
 args
 SELECT ST_BandNoDataValue(st_mapalgebraexpr(rast => rast, band => 1,
 pixeltype => NULL, expression => '[rast.val]*1'::text, nodataval => 1))
 FROM test_robe WHERE rid = 1 ;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5386#comment:2>
