[postgis-tickets] [SCM] postgis.net branch website updated. clarity-final-20-ga321833
Wed May 24 12:24:52 PDT 2023
the project "postgis.net".
The branch, website has been updated
       via  a3218338cb5d08ce61c1e509bb5ef8fb50ec0318 (commit)
      from  c535830c6eddb68d0be21e088ce45bc8c1b46db0 (commit)
revisions in full, below.
commit a3218338cb5d08ce61c1e509bb5ef8fb50ec0318
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed May 24 12:24:46 2023 -0700
    Add raster FAQ entry
diff --git a/content/documentation/faq/raster-inout.md b/content/documentation/faq/raster-inout.md
new file mode 100644
index 0000000..e9b02ac
--- /dev/null
+++ b/content/documentation/faq/raster-inout.md
@@ -0,0 +1,61 @@
+title: "How do I import/export raster data?"
+date: 2023-05-23
+draft: false
+geekdocHidden: true
+geekdocHiddenTocTree: false
+tags: [raster, gdal]
+## Importing Data
+You can import raster data using either `raster2pgsql`, which is part of the PostGIS distribution, or `gdal_translate`, which is part of [GDAL](https://gdal.org).
+The `raster2pgsql` is usually easier for loading, as the [options for controlling the load](https://postgis.net/docs/using_raster_dataman.html#RT_Loading_Rasters) are exposed directly.
+## Exporting Data
+The `gdal_translate` utility is usually easier for exporting raster data.
+PGHOST=localhost \
+PGPORT=5432 \
+PGUSER=postgres \
+PGPASSWORD=password \
+gdal_translate \
+    -of PNG \
+    -outsize 10% 10% \
+    "PG:dbname=db table=tbl" \
+You can also use SQL "where" clauses in your export, adding the filter you would like to be placed after the "where" into your connection string. Note that the single quotes in the filter have been artfully escaped.
+PGHOST=localhost \
+PGPORT=5432 \
+PGUSER=postgres \
+gdal_translate \
+    -of PNG \
+    "PG:dbname=db table=tbl where='filename=\'abcd.sid\'' " \
+You can also use spatial filters in the "where" clause.
+PGHOST=localhost \
+PGPORT=5432 \
+PGUSER=postgres \
+gdal_translate \
+    -of PNG \
+    "PG:dbname=db table=tbl where='ST_Intersects(rast, ST_SetSRID(ST_Point(-71.0,42.3),4326))' " \
Summary of changes:
 content/documentation/faq/raster-inout.md | 61 +++++++++++++++++++++++++++++++
 1 file changed, 61 insertions(+)
 create mode 100644 content/documentation/faq/raster-inout.md
hooks/post-receive
postgis.net
