[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-925-gd14231460
Wed May 24 14:48:03 PDT 2023
the project "PostGIS".
       via  d1423146031c674613718c8e27018156af75e72a (commit)
       via  d9b79d4a37a5080f19f69afb755a7b11ec7d82b5 (commit)
      from  a4f354398e52ad7ed3564c47773701e4b6b87ae8 (commit)
revisions in full, below.
commit d1423146031c674613718c8e27018156af75e72a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed May 24 14:47:34 2023 -0700
    Remove MIGRATION file
diff --git a/MIGRATION b/MIGRATION
deleted file mode 100644
index a91a1e1ca..000000000
--- a/MIGRATION
+++ /dev/null
@@ -1,182 +0,0 @@
-PostGIS 2.0 Migration Guide
-PostGIS 2.0 introduces changes that may affect backwards compatibility
-for some applications. This document lists those changes.
-Deprecated Functions Removed
-Since PostGIS 1.2, we have been encouraging users to use functions with
-the ST_ prefix. The ST_ prefixed functions are part of the ISO SQL/MM
-standard and used by other spatial SQL databases, so we want to conform
-as closely to the industry usage as we can.
-At 2.0, we have finally removed the old functions. If you have an
-application that *still* requires the old function signatures, please
-look to the legacy_*.sql files to add the old signatures back in.
-If you are using MapServer, upgrade to the latest versions of the 6.0
-or 6.2 releases. For earlier releases, you will have to install the
-legacy.sql files.
-Unknown SRID
-The "unknown SRID", assigned to geometries when SRID is not specified,
-is now 0, not -1.  ST_SRID will now return 0 when called on a geometry
-with no known SRID.
-ST_AsBinary, ST_AsText and 3D
-Previous versions of PostGIS returned 2D versions of objects when
-ST_AsBinary and ST_AsText were called. PostGIS 2.0 returns ISO SQL/MM
-versions when 3D or 4D objects are used.  For example, a 3D point with a
-Z dimension will return as 'POINT Z (0 0 0)'. A 4D point will return as
-'POINT ZM (0 0 0 0)'.
-For WKB, extra dimensionality is indicated in the type numbers. The Z,
-M, and ZM type numbers are indicated by adding 1000, 2000, and 3000
-respectively to the usual 2D type numbers. So, for example, a 2D Point
-has a type number of 1. A 4D PointZM has a type number of 3001.  A 2D
-polygon has a type number of 3. A PolygonZ has a type number of 2003.
-geometry_columns
-In PostGIS 2.0, the ``geometry_columns`` metadata has been changed from
-a table to a view.
-  * For applications that manage ``geometry_columns``
-    using the standard AddGeometryColumn() and other methods, there should
-    be no change.
-  * Applications that have inserted directly into ``geometry_columns``
-    will need to either move to the standard functions, or change
-    their create table syntax to include type/srid/dimensionality
-    information.
-    For example, to specify a 3D feature in WGS84::
-      CREATE TABLE mytable (
-        id SERIAL PRIMARY KEY,
-        g Geometry(PointZ,4326)
-  * Applications reading metadata from ``geometry_columns`` should expect
-    that the geometry type strings will be mixed case and include the
-    dimensionality modifiers. For example: PointZM, MultiLineStringZ.
-  * If you have views built on tables that were built
-    the old constraint way or that use processing
-    functions to return new geometries, they will not register correctly
-    in geometry_columns.  They will all appear as Geometry with srid=0.
-  	In order to fix this, you have to cast the geometries in the view.
-  	So for example, If you had a view that looked like this:
-  	CREATE OR REPLACE VIEW vwparcels AS
-  		SELECT gid, parcel_id,
-  			ST_Transform(geom, 26986) As geom_26986, -- a transformed geometry
-  			geom, --one that used constraints before
-  			ST_Centroid(geom) As cent_geom -- one that used processing function
-  		FROM parcels;
-  	You will need to drop and recreate the view.
-  	Sadly CREATE OR REPLACE will not work since the casting
-	  makes geometries be treated as a different type as far as
-	  CREATE OR REPLACE is concerned.
-  	NOTE for this, it might help to lookup in geometry_columns
-  	    to see the raw table srid/type
-  	Alternatively you can convert some of your table columns to typmod,
-  	then you would only need to CAST when doing processing.
-  	This however still requires you rebuild your dependent views
-  	DROP VIEW vwparcels;
-  		   ST_Transform(geom, 26986)::geometry(MultiPolygon,26986)
-  		      As geom_26986,
-  			geom::geometry(MultiPolygon, 2249) As geom,
-  			ST_Centroid(geom)::geometry(Point,2249) As cent_geom
-  		FROM parcels;
-Restoring data from prior versions -- GOTCHAS
-The populate_geometry_columns() function in PostGIS 1.5 and below,
-used the deprecated functions ndims() and srid() for defining constraints.
-As a result these tables will not
-restore into a fresh PostGIS 2.0 database unless you
-1) Drop these contraints before you restore the data
-or
-2) Install the legacy functions srid() and ndims() found in the legacy.sql
-  file before you try to restore these tables.
-Function is not unique after restore
-After you restore old data into a fresh PostGIS 2.0 database,
-YOU MUST install the uninstall_legacy.sql
-file after the restore.  If you don't you will run into
-"function is not unique" errors in your applications.
-The other issue with having the old functions is the old functions you
-restore will be bound to the old postgis library which is incompatible
-with the new postgis geometry structures.
-If you still require legacy functions, you can install the legacy.sql
-file after the uninstall_legacy.sql.
-GOTCHA with uninstall_legacy.sql
-The uninstall_legacy.sql will not be able to uninstall functions and will
-output errors detailing objects using these functions that are currently
-being used in views and sql functions.
-If you run it in PgAdmin, the whole script will rollback not
-uninstalling anything. So you should run it in PSQL mode.
-If you get errors in uninstall_legacy.sql -- convert those views and sql
-functions to use the newer equivalent functions
-and then rerun the script again.
-BENCHMARK NOTES
-Querying a whole geometry_columns table of 200-240 someodd records
-(tables/views all constraint based)( On windows 9.1beta2)
-Speed for this set of data I'm okay with though a bit slower
-I think the main issue why fancy is slower is that to get the fancy name
-I need to do a double call to get dims since fancy_name needs dims as well
-This I expect to be much faster using typ_mod
-SELECT * FROM geometry_columns_v; -- 2063 ms, 1063 ms (using fancy name)
-SELECT * FROM geometry_columns_v2; -- 656 ms (this is not using fancy name)
-SELECT * FROM geometry_columns; -- original static table 31ms - 150 ms
--- Doing single selects of a table
--- constraint based one -- 76ms, 46ms
-SELECT * FROM geometry_columns_v where f_table_name = 'streets';
--- One I converted to typmod -- 76 ms, 48 ms (first call was slower)
-SELECT * FROM geometry_columns_v where f_table_name = 'buildings_1995';
---Filter query for schema --
--- these are constraint based (7 rows) -- 76 ms, 240 ms, 68 ms
-SELECT * FROM geometry_columns_v where f_table_schema = 'tiger';
--- CONVERTING TO Typmod as I feared is slow for tables with data.
-   I think it follows the same model
--- as converting varchar(100) to text or varchar(100) to varchar(300) etc.
--- This maybe can be remedied somehow in 9.1 since it hasn't been released
--- (haven't tried doing this exercise in 8.4, 9.0)
--- This took  36,018 ms for table of 350,572 records.
-I assume it will be linear with number of records.
-ALTER TABLE buildings_1995
-    ALTER COLUMN the_geom TYPE geometry(MultiPolygon,2249);
commit d9b79d4a37a5080f19f69afb755a7b11ec7d82b5
Date:   Wed May 24 14:14:00 2023 -0700
    Remove old install-from-template section
diff --git a/doc/administration.xml b/doc/administration.xml
index 05c0227b8..13b0945dd 100644
--- a/doc/administration.xml
+++ b/doc/administration.xml
@@ -124,33 +124,6 @@ environment).</para></note>
   </sect2>
-  <sect2 id="templatepostgis">
-	<title>Create a spatially-enabled database from a template</title>
-	<para>
-	  Some packaged distributions of PostGIS (in particular the Win32 installers
-	  for PostGIS >= 1.1.5) load the PostGIS functions into a template
-	  database called <varname>template_postgis</varname>. If the
-	  <varname>template_postgis</varname> database exists in your PostgreSQL
-	  installation then it is possible for users and/or applications to create
-	  spatially-enabled databases using a single command. Note that in both
-	  cases, the database user must have been granted the privilege to create
-	  new databases.
-	</para>
-	<para>
-	  From the shell:
-	</para>
-	<programlisting># createdb -T template_postgis my_spatial_db</programlisting>
-	<para>
-	  From SQL:
-	</para>
-	<programlisting>postgres=# CREATE DATABASE my_spatial_db TEMPLATE=template_postgis</programlisting>
-  </sect2>
   </sect1>
   <sect1 id="upgrading">
Summary of changes:
 MIGRATION              | 182 -------------------------------------------------
 doc/administration.xml |  27 --------
 2 files changed, 209 deletions(-)
 delete mode 100644 MIGRATION
hooks/post-receive
