[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-927-g7aef48a5e
Wed May 24 19:17:52 PDT 2023
the project "PostGIS".
       via  7aef48a5e62e50058bf8df470c183b2871bfffa1 (commit)
      from  e212837e9fb17c131d5e8f0e02ca270df569c707 (commit)
revisions in full, below.
commit 7aef48a5e62e50058bf8df470c183b2871bfffa1
Author: Regina Obe <lr at pcorp.us>
Date:   Wed May 24 22:16:55 2023 -0400
    Fix tiger 2022 faces load
     - Add uace20 to exclusions column list
    References #5388 for PostGIS 3.4.0
diff --git a/extras/tiger_geocoder/tiger_loader_2022.sql b/extras/tiger_geocoder/tiger_loader_2022.sql
index 12e761d8b..af4b9ee25 100644
--- a/extras/tiger_geocoder/tiger_loader_2022.sql
+++ b/extras/tiger_geocoder/tiger_loader_2022.sql
@@ -361,7 +361,7 @@ VALUES(6, 'faces', 'faces', true, true, false,false, 'c',
       , 'cousubfp00', 'submcdfp00', 'conctyfp00', 'placefp00', 'aiannhfp00', 'aiannhce00',
        'comptyp00', 'trsubfp00', 'trsubce00', 'anrcfp00', 'elsdlea00', 'scsdlea00',
        'unsdlea00', 'uace00', 'cd108fp', 'sldust00', 'sldlst00', 'vtdst00', 'zcta5ce00',
-       'tazce00', 'ugace00', 'puma5ce00','vtdst10','tazce10','uace10','puma5ce10','tazce', 'uace', 'vtdst',  'zcta5ce10', 'puma5ce', 'ugace10','pumace10', 'estatefp', 'ugace', 'blockce', 'pumace20', 'sdadmlea']);
+       'tazce00', 'ugace00', 'puma5ce00','vtdst10','tazce10','uace10','puma5ce10','tazce', 'uace', 'vtdst',  'zcta5ce10', 'puma5ce', 'ugace10','pumace10', 'estatefp', 'ugace', 'blockce', 'pumace20', 'sdadmlea', 'uace20']);
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
 VALUES(7, 'featnames', 'featnames', true, true, false,false, 'a',
Summary of changes:
 extras/tiger_geocoder/tiger_loader_2022.sql | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
