[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-933-gb85f9dcf6
Thu May 25 08:33:29 PDT 2023
the project "PostGIS".
       via  b85f9dcf6af50b90bf3112c86a47b1a08d601c79 (commit)
      from  1cf9e7b197334fc35f883415dc79d706bc9e2d5f (commit)
revisions in full, below.
commit b85f9dcf6af50b90bf3112c86a47b1a08d601c79
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu May 25 08:30:57 2023 -0700
    Functions to expose metadata about Proj entries.
    Works with Proj6+, and queries the internal Proj database
    for information about the CRS entries.
    postgis_srs_codes() lists all codes in an authority
    postgis_srs_all() lists all codes in the proj db
    postgis_srs() shows info about specific code
    postgis_srs_search() finds planar CRSs that fit query bounds
diff --git a/doc/reference_srs.xml b/doc/reference_srs.xml
index 05c401fed..ed773806e 100644
--- a/doc/reference_srs.xml
+++ b/doc/reference_srs.xml
@@ -489,4 +489,243 @@ SELECT ST_AsText(ST_TransformPipeline('SRID=4939;POINT(143.0 -37.0)'::geometry,
     </refsection>
   </refentry>
+  <refentry id="postgis_srs_codes">
+    <refnamediv>
+    <refname>postgis_srs_codes</refname>
+    <refpurpose>Return the list of SRS codes associated with the given authority.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>setof text <function>postgis_srs_codes</function></funcdef>
+                <paramdef><type>text </type> <parameter>auth_name</parameter></paramdef>
+            </funcprototype>
+        </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+      <title>Description</title>
+      <para>Returns a set of all <varname>auth_srid</varname> for the given <varname>auth_name</varname>.</para>
+      <para>Availability: 3.4.0</para>
+      <para>Proj version 6+</para>
+    </refsection>
+    <refsection>
+      <title>Examples</title>
+      <para>List the first ten codes associated with the EPSG authority.</para>
+      <programlisting>
+SELECT * FROM postgis_srs_codes('EPSG') LIMIT 10;
+ postgis_srs_codes
+ 2000
+ 20004
+ 20005
+ 20006
+ 20007
+ 20008
+ 20009
+ 2001
+ 20010
+ 20011
+    </programlisting>
+    </refsection>
+    <!-- Optionally add a "See Also" section -->
+    <refsection>
+    <title>See Also</title>
+    <para><xref linkend="postgis_srs" />, <xref linkend="postgis_srs_all" />, <xref linkend="postgis_srs_search" /></para>
+    </refsection>
+  </refentry>
+  <refentry id="postgis_srs">
+    <refnamediv>
+    <refname>postgis_srs</refname>
+    <refpurpose>Return a metadata record for the requested authority and srid.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>setof record <function>postgis_srs</function></funcdef>
+                <paramdef><type>text </type> <parameter>auth_srid</parameter></paramdef>
+            </funcprototype>
+        </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+      <para>Returns a metadata record for the requested <varname>auth_srid</varname> for the given <varname>auth_name</varname>. The record will have the <varname>auth_name</varname>, <varname>auth_srid</varname>, <varname>srname</varname>, <varname>srtext</varname>, <varname>proj4text</varname>, and the corners of the area of usage, <varname>point_sw</varname> and <varname>point_ne</varname>.</para>
+    </refsection>
+    <refsection>
+      <para>Get the metadata for EPSG:3005.</para>
+      <programlisting>
+SELECT * FROM postgis_srs('EPSG', '3005');
+auth_name | EPSG
+auth_srid | 3005
+srname    | NAD83 / BC Albers
+srtext    | PROJCS["NAD83 / BC Albers", ... ]]
+proj4text | +proj=aea +lat_0=45 +lon_0=-126 +lat_1=50 +lat_2=58.5 +x_0=1000000 +y_0=0 +datum=NAD83 +units=m +no_defs +type=crs
+point_sw  | 0101000020E6100000E17A14AE476161C00000000000204840
+point_ne  | 0101000020E610000085EB51B81E855CC0E17A14AE47014E40
+    </programlisting>
+    </refsection>
+    <refsection>
+    <para><xref linkend="postgis_srs_codes" />, <xref linkend="postgis_srs_all" />, <xref linkend="postgis_srs_search" /></para>
+    </refsection>
+  </refentry>
+  <refentry id="postgis_srs_all">
+    <refnamediv>
+    <refname>postgis_srs_all</refname>
+    <refpurpose>Return metadata records for every spatial reference system in the underlying Proj database.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>setof record <function>postgis_srs_all</function></funcdef>
+                <void/>
+            </funcprototype>
+        </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+      <para>Returns a set of all metadata records in the underlying Proj database. The records will have the <varname>auth_name</varname>, <varname>auth_srid</varname>, <varname>srname</varname>, <varname>srtext</varname>, <varname>proj4text</varname>, and the corners of the area of usage, <varname>point_sw</varname> and <varname>point_ne</varname>.</para>
+    </refsection>
+    <refsection>
+      <para>Get the first 10 metadata records from the Proj database.</para>
+      <programlisting>
+SELECT auth_name, auth_srid, srname FROM postgis_srs_all() LIMIT 10;
+ auth_name | auth_srid |                  srname
+ EPSG      | 2000      | Anguilla 1957 / British West Indies Grid
+ EPSG      | 20004     | Pulkovo 1995 / Gauss-Kruger zone 4
+ EPSG      | 20005     | Pulkovo 1995 / Gauss-Kruger zone 5
+ EPSG      | 20006     | Pulkovo 1995 / Gauss-Kruger zone 6
+ EPSG      | 20007     | Pulkovo 1995 / Gauss-Kruger zone 7
+ EPSG      | 20008     | Pulkovo 1995 / Gauss-Kruger zone 8
+ EPSG      | 20009     | Pulkovo 1995 / Gauss-Kruger zone 9
+ EPSG      | 2001      | Antigua 1943 / British West Indies Grid
+ EPSG      | 20010     | Pulkovo 1995 / Gauss-Kruger zone 10
+ EPSG      | 20011     | Pulkovo 1995 / Gauss-Kruger zone 11    </programlisting>
+    </refsection>
+    <refsection>
+    <para><xref linkend="postgis_srs_codes" />, <xref linkend="postgis_srs" />, <xref linkend="postgis_srs_search" /></para>
+    </refsection>
+  </refentry>
+  <refentry id="postgis_srs_search">
+    <refnamediv>
+    <refname>postgis_srs_search</refname>
+    <refpurpose>Return metadata records for projected coordinate systems that have areas of useage that fully contain the bounds parameter.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>setof record <function>postgis_srs_search</function></funcdef>
+                <paramdef><type>geometry </type> <parameter>bounds</parameter></paramdef>
+                <paramdef choice="opt"><type>text </type> <parameter>auth_name=EPSG</parameter></paramdef>
+            </funcprototype>
+        </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+      <para>Return a set of metadata records for projected coordinate systems that have areas of useage that fully contain the bounds parameter. Each record will have the <varname>auth_name</varname>, <varname>auth_srid</varname>, <varname>srname</varname>, <varname>srtext</varname>, <varname>proj4text</varname>, and the corners of the area of usage, <varname>point_sw</varname> and <varname>point_ne</varname>.
+      </para>
+      <para>The search only looks for projected coordinate systems, and is intended for users to explore the possible systems that work for the extent of their data.</para>
+    </refsection>
+    <refsection>
+      <para>Search for projected coordinate systems in Louisiana.</para>
+      <programlisting>
+SELECT auth_name, auth_srid, srname,
+  ST_AsText(point_sw) AS point_sw,
+  ST_AsText(point_ne) AS point_ne
+FROM postgis_srs_search('SRID=4326;LINESTRING(-90 30, -91 31)')
+LIMIT 3;
+ auth_name | auth_srid |                srname                |      point_sw       |      point_ne
+ EPSG      | 2801      | NAD83(HARN) / Louisiana South        | POINT(-93.94 28.85) | POINT(-88.75 31.07)
+ EPSG      | 3452      | NAD83 / Louisiana South (ftUS)       | POINT(-93.94 28.85) | POINT(-88.75 31.07)
+ EPSG      | 3457      | NAD83(HARN) / Louisiana South (ftUS) | POINT(-93.94 28.85) | POINT(-88.75 31.07)
+</programlisting>
+      <para>Scan a table for max extent and find projected coordinate systems that might suit.</para>
+      <programlisting>
+WITH ext AS (
+  SELECT ST_Extent(geom) AS geom, Max(ST_SRID(geom)) AS srid
+  FROM foo
+FROM ext
+CROSS JOIN postgis_srs_search(ST_SetSRID(ext.geom, ext.srid))
+LIMIT 3;</programlisting>
+    </refsection>
+    <refsection>
+    <para><xref linkend="postgis_srs_codes" />, <xref linkend="postgis_srs_all" />, <xref linkend="postgis_srs" /></para>
+    </refsection>
+  </refentry>
   </sect1>
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 13a5fd936..f79303a57 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2452,6 +2452,7 @@ int lwgeom_transform_from_str(LWGEOM *geom, const char* instr, const char* outst
 int lwgeom_transform(LWGEOM *geom, LWPROJ* pj);
 int ptarray_transform(POINTARRAY *pa, LWPROJ* pj);
+int box3d_transform(GBOX *box, LWPROJ *pj);
  * Allocate a new LWPROJ containing the reference to the PROJ's PJ
diff --git a/liblwgeom/lwgeom_transform.c b/liblwgeom/lwgeom_transform.c
index 64e2a3ecc..8adf4da44 100644
--- a/liblwgeom/lwgeom_transform.c
+++ b/liblwgeom/lwgeom_transform.c
@@ -205,6 +205,27 @@ lwgeom_transform_pipeline(LWGEOM *geom, const char* pipelinestr, bool is_forward
 	return ret;
+int
+box3d_transform(GBOX *gbox, LWPROJ *pj)
+	POINT4D pt;
+	POINTARRAY *pa = ptarray_construct(0, 0, 4);
+	pt = (POINT4D){gbox->xmin, gbox->ymin, 0, 0};
+	ptarray_set_point4d(pa, 0, &pt);
+	pt = (POINT4D){gbox->xmax, gbox->ymin, 0, 0};
+	ptarray_set_point4d(pa, 1, &pt);
+	pt = (POINT4D){gbox->xmax, gbox->ymax, 0, 0};
+	ptarray_set_point4d(pa, 2, &pt);
+	pt = (POINT4D){gbox->xmin, gbox->ymax, 0, 0};
+	ptarray_set_point4d(pa, 3, &pt);
+	ptarray_transform(pa, pj);
+	return ptarray_calculate_gbox_cartesian(pa, gbox);
 int
 ptarray_transform(POINTARRAY *pa, LWPROJ *pj)
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 646f0e6dd..3d631faa8 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -25,10 +25,12 @@
 #include "postgres.h"
 #include "fmgr.h"
+#include "funcapi.h"
 #include "utils/builtins.h"
 #include "../postgis_config.h"
 #include "liblwgeom.h"
+#include "lwgeodetic.h"
 #include "lwgeom_transform.h"
@@ -198,9 +200,13 @@ Datum transform_pipeline_geom(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(postgis_proj_version);
 Datum postgis_proj_version(PG_FUNCTION_ARGS)
+#if POSTGIS_PROJ_VERSION < 61
+	const char *ver = pj_get_release();
+	text *result = cstring_to_text(ver);
+#else
 	PJ_INFO pji = proj_info();
 	text *result = 	cstring_to_text(pji.version);
+#endif
 	PG_RETURN_POINTER(result);
@@ -267,3 +273,483 @@ Datum LWGEOM_asKML(PG_FUNCTION_ARGS)
 		PG_RETURN_TEXT_P(kml);
 	PG_RETURN_NULL();
+ * PROJ database reading functions
+#if POSTGIS_PROJ_VERSION >= 61
+struct srs_entry {
+	text* auth_name;
+	text* auth_code;
+	double sort;
+struct srs_data {
+	struct srs_entry* entries;
+	uint32_t num_entries;
+	uint32_t capacity;
+	uint32_t current_entry;
+static int
+srs_entry_cmp (const void *a, const void *b)
+	const struct srs_entry *entry_a = (const struct srs_entry*)(a);
+	const struct srs_entry *entry_b = (const struct srs_entry*)(b);
+	if      (entry_a->sort < entry_b->sort) return -1;
+	else if (entry_a->sort > entry_b->sort) return 1;
+	else return 0;
+static Datum
+srs_tuple_from_entry(const struct srs_entry* entry, TupleDesc tuple_desc)
+	HeapTuple tuple;
+	Datum tuple_data[7] = {0, 0, 0, 0, 0, 0, 0};
+	bool  tuple_null[7] = {true, true, true, true, true, true, true};
+	PJ_CONTEXT * ctx = NULL;
+	const char * const empty_options[2] = {NULL};
+	const char * const wkt_options[2] = {"MULTILINE=NO", NULL};
+	const char * srtext;
+	const char * proj4text;
+	const char * srname;
+	double w_lon, s_lat, e_lon, n_lat;
+	int ok;
+	PJ *obj = proj_create_from_database(ctx,
+	            text_to_cstring(entry->auth_name),
+	            text_to_cstring(entry->auth_code),
+	            PJ_CATEGORY_CRS, 0, empty_options);
+	if (!obj)
+		return (Datum) 0;
+	srtext = proj_as_wkt(ctx, obj, PJ_WKT1_GDAL, wkt_options);
+	proj4text = proj_as_proj_string(ctx, obj, PJ_PROJ_4, empty_options);
+	srname = proj_get_name(obj);
+	ok = proj_get_area_of_use(ctx, obj, &w_lon, &s_lat, &e_lon, &n_lat, NULL);
+	if (entry->auth_name) {
+		tuple_data[0] = PointerGetDatum(entry->auth_name);
+		tuple_null[0] = false;
+	if (entry->auth_code) {
+		tuple_data[1] = PointerGetDatum(entry->auth_code);
+		tuple_null[1] = false;
+	if (srname) {
+		tuple_data[2] = PointerGetDatum(cstring_to_text(srname));
+		tuple_null[2] = false;
+	if (srtext) {
+		tuple_data[3] = PointerGetDatum(cstring_to_text(srtext));
+		tuple_null[3] = false;
+	if (proj4text) {
+		tuple_data[4] = PointerGetDatum(cstring_to_text(proj4text));
+		tuple_null[4] = false;
+	if (ok) {
+		LWPOINT *p_sw = lwpoint_make2d(4326, w_lon, s_lat);
+		LWPOINT *p_ne = lwpoint_make2d(4326, e_lon, n_lat);
+		GSERIALIZED *g_sw = geometry_serialize((LWGEOM*)p_sw);
+		GSERIALIZED *g_ne = geometry_serialize((LWGEOM*)p_ne);
+		tuple_data[5] = PointerGetDatum(g_sw);
+		tuple_null[5] = false;
+		tuple_data[6] = PointerGetDatum(g_ne);
+		tuple_null[6] = false;
+	tuple = heap_form_tuple(tuple_desc, tuple_data, tuple_null);
+	proj_destroy(obj);
+	return HeapTupleGetDatum(tuple);
+static struct srs_data *
+srs_state_init()
+	struct srs_data *state = palloc0(sizeof(*state));
+	state->capacity = 8192;
+	state->num_entries = 0;
+	state->entries = palloc0(state->capacity * sizeof(*(state->entries)));
+	return state;
+static void
+srs_state_memcheck(struct srs_data *state)
+	if (state->num_entries == state->capacity)
+		state->capacity *= 2;
+		state->entries = repalloc(state->entries, state->capacity * sizeof(*(state->entries)));
+	return;
+static void
+srs_state_codes(const char* auth_name, struct srs_data *state)
+	* Only a subset of supported proj types actually
+	* show up in spatial_ref_sys
+	#define ntypes 3
+	PJ_TYPE types[ntypes] = {PJ_TYPE_PROJECTED_CRS, PJ_TYPE_GEOGRAPHIC_CRS, PJ_TYPE_COMPOUND_CRS};
+	uint32_t j;
+	for (j = 0; j < ntypes; j++)
+		PJ_CONTEXT *ctx = NULL;
+		int allow_deprecated = 0;
+		PJ_TYPE type = types[j];
+		PROJ_STRING_LIST codes_ptr = proj_get_codes_from_database(ctx, auth_name, type, allow_deprecated);
+		PROJ_STRING_LIST codes = codes_ptr;
+		const char *code;
+		while(codes && *codes)
+			/* Read current code and move forward one entry */
+			code = *codes++;
+			/* Ensure there is space in the entry list */
+			srs_state_memcheck(state);
+			/* Write the entry into the entry list and increment */
+			state->entries[state->num_entries].auth_name = cstring_to_text(auth_name);
+			state->entries[state->num_entries].auth_code = cstring_to_text(code);
+			state->num_entries++;
+		/* Clean up system allocated memory */
+		proj_string_list_destroy(codes_ptr);
+static void
+srs_find_planar(const char *auth_name, const LWGEOM *bounds, struct srs_data *state)
+	int32_t srid_from = lwgeom_get_srid(bounds);
+	const int32_t srid_to = 4326;
+	GBOX gbox = *(lwgeom_get_bbox(bounds));
+	PJ_TYPE types[1] = {PJ_TYPE_PROJECTED_CRS};
+	PROJ_CRS_INFO **crs_list_ptr, **crs_list;
+	int crs_count;
+	PROJ_CRS_LIST_PARAMETERS *params = proj_get_crs_list_parameters_create();
+	params->types = types;
+	params->typesCount = 1;
+	params->crs_area_of_use_contains_bbox = true;
+	params->bbox_valid = true;
+	params->allow_deprecated = false;
+#if POSTGIS_PROJ_VERSION >= 81
+	params->celestial_body_name = "Earth";
+#endif
+	if (srid_from != srid_to)
+		LWPROJ *pj;
+		if (lwproj_lookup(srid_from, srid_to, &pj) == LW_FAILURE)
+			elog(ERROR, "%s: Lookup of SRID %u => %u transform failed",
+			    __func__, srid_from, srid_to);
+		box3d_transform(&gbox, pj);
+	params->west_lon_degree = gbox.xmin;
+	params->south_lat_degree = gbox.ymin;
+	params->east_lon_degree = gbox.xmax;
+	params->north_lat_degree = gbox.ymax;
+	crs_list = crs_list_ptr = proj_get_crs_info_list_from_database(
+	                            ctx, auth_name, params, &crs_count);
+	/* TODO, throw out really huge / dumb areas? */
+	while (crs_list && *crs_list)
+		/* Read current crs and move forward one entry */
+		PROJ_CRS_INFO *crs = *crs_list++;
+		/* Read the corners of the CRS area of use */
+		double area;
+		double height = crs->north_lat_degree - crs->south_lat_degree;
+		double width = crs->east_lon_degree - crs->west_lon_degree;
+		if (width < 0.0)
+			width = 360 - (crs->west_lon_degree - crs->east_lon_degree);
+		area = width * height;
+		state->entries[state->num_entries].auth_name = cstring_to_text(crs->auth_name);
+		state->entries[state->num_entries].auth_code = cstring_to_text(crs->code);
+		state->entries[state->num_entries].sort = area;
+	/* Put the list of entries into order of area size, smallest to largest */
+	qsort(state->entries, state->num_entries, sizeof(struct srs_data), srs_entry_cmp);
+	proj_crs_info_list_destroy(crs_list_ptr);
+	proj_get_crs_list_parameters_destroy(params);
+#endif
+ * Search for srtext and proj4text given auth_name and auth_srid,
+ * returns TABLE(auth_name text, auth_srid text, srtext text, proj4text text)
+Datum postgis_srs_entry(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(postgis_srs_entry);
+#if POSTGIS_PROJ_VERSION < 60
+	elog(ERROR, "%s is not supported with Proj < 6.0", __func__);
+#else
+	Datum result;
+	struct srs_entry entry;
+	text* auth_name = PG_GETARG_TEXT_P(0);
+	text* auth_code = PG_GETARG_TEXT_P(1);
+	TupleDesc tuple_desc;
+	if (get_call_result_type(fcinfo, 0, &tuple_desc) != TYPEFUNC_COMPOSITE)
+		ereport(ERROR, (errcode(ERRCODE_FEATURE_NOT_SUPPORTED),
+			errmsg("%s called with incompatible return type", __func__)));
+	BlessTupleDesc(tuple_desc);
+	entry.auth_name = auth_name;
+	entry.auth_code = auth_code;
+	result = srs_tuple_from_entry(&entry, tuple_desc);
+	if (result)
+		PG_RETURN_DATUM(srs_tuple_from_entry(&entry, tuple_desc));
+	else
+		PG_RETURN_NULL();
+#endif
+Datum postgis_srs_entry_all(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(postgis_srs_entry_all);
+#else
+	FuncCallContext *funcctx;
+	MemoryContext oldcontext;
+	struct srs_data *state;
+	Datum result;
+	* On the first call, fill in the state with all
+	* of the auth_name/auth_srid pairings in the
+	* proj database. Then the per-call routine is just
+	* one isolated call per pair.
+	if (SRF_IS_FIRSTCALL())
+		funcctx = SRF_FIRSTCALL_INIT();
+		oldcontext = MemoryContextSwitchTo(funcctx->multi_call_memory_ctx);
+		* Could read all authorities from database, but includes
+		* authorities (IGN, OGC) that use non-integral values in
+		* auth_srid. So hand-coded list for now.
+		state = srs_state_init();
+		srs_state_codes("EPSG", state);
+		srs_state_codes("ESRI", state);
+		srs_state_codes("IAU_2015", state);
+		* Read the TupleDesc from the FunctionCallInfo. The SQL definition
+		* of the function must have the right number of fields and types
+		* to match up to this C code.
+		if (get_call_result_type(fcinfo, 0, &funcctx->tuple_desc) != TYPEFUNC_COMPOSITE)
+		BlessTupleDesc(funcctx->tuple_desc);
+		funcctx->user_fctx = state;
+		MemoryContextSwitchTo(oldcontext);
+	/* Stuff done on every call of the function */
+	funcctx = SRF_PERCALL_SETUP();
+	state = funcctx->user_fctx;
+	/* Exit when we've read all entries */
+	if (!state->num_entries || state->current_entry == state->num_entries)
+		SRF_RETURN_DONE(funcctx);
+	/* Lookup the srtext/proj4text for this entry */
+	           state->entries + state->current_entry++,
+	           funcctx->tuple_desc);
+	if (result)
+		SRF_RETURN_NEXT(funcctx, result);
+	/* Stop if lookup fails drastically */
+#endif
+Datum postgis_srs_codes(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(postgis_srs_codes);
+#else
+	Datum result;
+	text* auth_code;
+		srs_state_codes(text_to_cstring(auth_name), state);
+	/* Read the code for this entry */
+	auth_code = state->entries[state->current_entry++].auth_code;
+	result = PointerGetDatum(auth_code);
+	/* We are returning setof(text) */
+	if (result)
+#endif
+ * Search for projections given extent and (optional) auth_name
+ * returns TABLE(auth_name, auth_srid, srtext, proj4text, point_sw, point_ne)
+Datum postgis_srs_search(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(postgis_srs_search);
+#else
+	Datum result;
+		GSERIALIZED *gbounds = PG_GETARG_GSERIALIZED_P(0);
+		LWGEOM *bounds = lwgeom_from_gserialized(gbounds);
+		text *auth_name = PG_GETARG_TEXT_P(1);
+		/* Run the Proj query */
+		srs_find_planar(text_to_cstring(auth_name), bounds, state);
+	    state->current_entry == state->num_entries)
+	if (result)
+#endif
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index f30d75425..19d2f2c80 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2872,6 +2872,65 @@ CREATE OR REPLACE FUNCTION postgis_transform_geometry(geom geometry, text, text,
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_MEDIUM;
+-- Availability: 3.4.0
+CREATE OR REPLACE FUNCTION postgis_srs_codes(auth_name text)
+	RETURNS SETOF TEXT
+	AS 'MODULE_PATHNAME', 'postgis_srs_codes'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_MEDIUM;
+CREATE OR REPLACE FUNCTION postgis_srs(auth_name text, auth_srid text)
+	RETURNS TABLE(
+		auth_name TEXT,
+		auth_srid TEXT,
+		srname TEXT,
+		srtext TEXT,
+		proj4text TEXT,
+		point_sw GEOMETRY,
+		point_ne GEOMETRY
+	AS 'MODULE_PATHNAME', 'postgis_srs_entry'
+	_COST_MEDIUM;
+CREATE OR REPLACE FUNCTION postgis_srs_all()
+	RETURNS TABLE(
+		auth_name TEXT,
+		auth_srid TEXT,
+		srname TEXT,
+		srtext TEXT,
+		proj4text TEXT,
+		point_ne GEOMETRY
+	AS 'MODULE_PATHNAME', 'postgis_srs_entry_all'
+	_COST_HIGH;
+CREATE OR REPLACE FUNCTION postgis_srs_search(
+		bounds geometry,
+		authname text DEFAULT 'EPSG')
+	RETURNS TABLE(
+		auth_name TEXT,
+		auth_srid TEXT,
+		srname TEXT,
+		srtext TEXT,
+		proj4text TEXT,
+		point_ne GEOMETRY
+	AS 'MODULE_PATHNAME', 'postgis_srs_search'
+	_COST_HIGH;
 -- PostGIS equivalent of old function: transform(geometry,integer)
 CREATE OR REPLACE FUNCTION ST_Transform(geometry,integer)
 	RETURNS geometry
Summary of changes:
 doc/reference_srs.xml        | 239 +++++++++++++++++++++
 liblwgeom/liblwgeom.h.in     |   1 +
 liblwgeom/lwgeom_transform.c |  21 ++
 postgis/lwgeom_transform.c   | 488 ++++++++++++++++++++++++++++++++++++++++++-
 postgis/postgis.sql.in       |  59 ++++++
 5 files changed, 807 insertions(+), 1 deletion(-)
hooks/post-receive
