[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-939-gde7fb38f5
Thu May 25 22:08:31 PDT 2023
the project "PostGIS".
       via  de7fb38f5bb4b29e9d30715e5004ff1c878f8d74 (commit)
       via  fb183c70a127448d8008521d93f89025e45af425 (commit)
       via  78d97da03ed19478d4cbe2ac24bf589444f3258e (commit)
       via  8ff1ed0d6d6360438c283dc5ce504c46bccb54df (commit)
      from  64275fdbadd085fd06ded2e98d67c07ec431f4b7 (commit)
revisions in full, below.
commit de7fb38f5bb4b29e9d30715e5004ff1c878f8d74
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Fri May 26 03:34:11 2023 +0000
    Translated reference_coverage using Weblate (Japanese)
    Currently translated at 69.6% (23 of 33 strings)
    Translation: postgis/reference_coverage
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_coverage/ja/
diff --git a/doc/po/ja/reference_coverage.xml.po b/doc/po/ja/reference_coverage.xml.po
index 0ffe4dea9..f35914377 100644
--- a/doc/po/ja/reference_coverage.xml.po
+++ b/doc/po/ja/reference_coverage.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "Project-Id-Version: ming 64gcc81\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-05-25 20:53+0000\n"
-"PO-Revision-Date: 2023-05-15 11:08+0000\n"
+"PO-Revision-Date: 2023-05-26 05:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "reference_coverage/ja/>\n"
@@ -392,7 +392,7 @@ msgstr ""
 #: reference_coverage.xml:174
 #, no-c-format
 msgid ", <xref linkend=\"ST_Union\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_Union\"/>"
 #, no-c-format
 #~ msgid ""
commit fb183c70a127448d8008521d93f89025e45af425
Date:   Fri May 26 03:33:27 2023 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (222 of 222 strings)
    Translation: postgis/installation.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/installationxml/ja/
diff --git a/doc/po/ja/installation.xml.po b/doc/po/ja/installation.xml.po
index e0766215f..1159134f8 100644
--- a/doc/po/ja/installation.xml.po
+++ b/doc/po/ja/installation.xml.po
 "Project-Id-Version: PostGIS\n"
-"PO-Revision-Date: 2022-12-01 10:30+0000\n"
 "installationxml/ja/>\n"
@@ -16,7 +16,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 4.14.1\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: title
 #: installation.xml:3
@@ -502,6 +502,12 @@ msgid ""
 "a PCRE library, or you pass in a valid <varname>--with-pcre-dir=/path/to/"
 "pcre</varname> during configure."
 msgstr ""
+"<xref linkend=\"Address_Standardizer\"/>をビルドするには、PCRE <ulink url="
+"\"http://www.pcre.org\">http://www.pcre.org</ulink> "
+"(通常はnixシステムにはインストールされています)も必要です。"
+"PCREライブラリを検出したら<xref linkend=\"Address_Standardizer\""
+"/>は自動でビルドされます。もしくは、コンフィギュアの際に有効な<varname"
+">--with-pcre-dir=/path/to/pcre</varname>を指定します。"
 #. Tag: para
 #: installation.xml:254
@@ -2018,7 +2024,7 @@ msgstr ""
 #: installation.xml:813
 #, no-c-format
 msgid "Tiger Geocoder Enabling your PostGIS database"
-msgstr ""
+msgstr "TigerジオコーダをPostGISデータベースで有効にする"
 #. Tag: para
 #: installation.xml:815
@@ -2027,6 +2033,8 @@ msgid ""
 "These directions assume your PostgreSQL installation already has the "
 "postgis_tiger_geocoder extension installed."
 msgstr ""
+"ここの説明では、お手持ちのPostgreSQLにpostgis_tiger_geocoderエクステンション"
+"がインストールされていると仮定します。"
 #. Tag: para
 #: installation.xml:816
@@ -2336,6 +2344,10 @@ msgid ""
 "  3235\n"
 "(1 row)"
 msgstr ""
+"count\n"
+"-------\n"
+"  3235\n"
+"(1 row)"
 #. Tag: programlisting
 #: installation.xml:857
commit 78d97da03ed19478d4cbe2ac24bf589444f3258e
Date:   Fri May 26 03:34:45 2023 +0000
    Currently translated at 100.0% (192 of 192 strings)
    Translation: postgis/reference_sfcgal.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_sfcgalxml/ja/
diff --git a/doc/po/ja/reference_sfcgal.xml.po b/doc/po/ja/reference_sfcgal.xml.po
index 5678ca5d7..aa8b1f7b5 100644
--- a/doc/po/ja/reference_sfcgal.xml.po
+++ b/doc/po/ja/reference_sfcgal.xml.po
@@ -8,7 +8,7 @@ msgstr ""
 "reference_sfcgalxml/ja/>\n"
@@ -1201,6 +1201,8 @@ msgid ""
 ", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend=\"ST_Tesselate\"/"
 ">, <xref linkend=\"ST_ConcaveHull\"/>, <xref linkend=\"ST_Dump\"/>"
 msgstr ""
+", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend=\"ST_Tesselate\"/"
+">, <xref linkend=\"ST_ConcaveHull\"/>, <xref linkend=\"ST_Dump\"/>"
 #. Tag: refname
 #: reference_sfcgal.xml:661
commit 8ff1ed0d6d6360438c283dc5ce504c46bccb54df
Date:   Fri May 26 03:34:12 2023 +0000
    Currently translated at 100.0% (255 of 255 strings)
    Translation: postgis/reference_constructor.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_constructorxml/ja/
diff --git a/doc/po/ja/reference_constructor.xml.po b/doc/po/ja/reference_constructor.xml.po
index 3d35d6e9c..f887dea09 100644
--- a/doc/po/ja/reference_constructor.xml.po
+++ b/doc/po/ja/reference_constructor.xml.po
 "POT-Creation-Date: 2022-08-27 04:57+0000\n"
 "reference_constructorxml/ja/>\n"
Summary of changes:
 doc/po/ja/installation.xml.po          | 18 +++++++++++++++---
 doc/po/ja/reference_constructor.xml.po |  2 +-
 doc/po/ja/reference_coverage.xml.po    |  4 ++--
 doc/po/ja/reference_sfcgal.xml.po      |  4 +++-
 4 files changed, 21 insertions(+), 7 deletions(-)
hooks/post-receive
