[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-941-g4125ba119
Fri May 26 23:08:31 PDT 2023
the project "PostGIS".
       via  4125ba1192e5a7c558881c56cab0932dd6134a0c (commit)
       via  57c733a08eecd92dd38d6994b8fe4ab4fdadda98 (commit)
      from  de7fb38f5bb4b29e9d30715e5004ff1c878f8d74 (commit)
revisions in full, below.
commit 4125ba1192e5a7c558881c56cab0932dd6134a0c
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Fri May 26 07:54:05 2023 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (178 of 178 strings)
    Translation: postgis/using_raster_dataman.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/using_raster_datamanxml/ja/
diff --git a/doc/po/ja/using_raster_dataman.xml.po b/doc/po/ja/using_raster_dataman.xml.po
index d13b8ef75..b4f8ce669 100644
--- a/doc/po/ja/using_raster_dataman.xml.po
+++ b/doc/po/ja/using_raster_dataman.xml.po
@@ -2,13 +2,13 @@
 # Translators:
 # TERAMOTO Ikuhiro <yellow at affrc.go.jp>, 2016
-# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2022.
+# Teramoto Ikuhiro <yellow at affrc.go.jp>, 2022, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-05-25 20:53+0000\n"
-"PO-Revision-Date: 2022-09-12 12:43+0000\n"
+"PO-Revision-Date: 2023-05-27 06:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "using_raster_datamanxml/ja/>\n"
@@ -17,7 +17,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 4.13.1\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: title
 #: using_raster_dataman.xml:3
@@ -57,6 +57,9 @@ msgid ""
 "raster table. It is capable of loading folders of raster files as well as "
 "creating overviews of rasters."
 msgstr ""
+"<varname>raster2pgsql</varname>は、GDALがサポートするラスタ書式をPostGISラス"
+"タテーブルにロードするのに適切なSQLにする実行ファイルです。ラスタのオーバビュ"
+"ーの生成だけでなく、ラスタファイルのフォルダのロードも可能です。"
 #. Tag: para
 #: using_raster_dataman.xml:13
@@ -68,6 +71,11 @@ msgid ""
 "list of raster types your particular <varname>raster2pgsql</varname> "
 "supports use the <varname>-G</varname> switch."
 msgstr ""
+"かなり多くの場合、(ご自分のGDALライブラリをコンパイルしない限り) raster2pgsql"
+"はPostGISの一部としてコンパイルされるので、実行ファイルがサポートするラスタタ"
+"イプはGDALの依存ライブラリでコンパイルされたものと同じになります。お手持ちの<"
+"varname>raster2pgsql</varname>がサポートするラスタタイプの一覧は、<varname>-G"
+"</varname>スイッチで見ることができます。"
 #. Tag: para
 #: using_raster_dataman.xml:16
@@ -88,7 +96,7 @@ msgstr ""
 #: using_raster_dataman.xml:20
 #, no-c-format
 msgid "Example Usage"
-msgstr ""
+msgstr "使用例"
 #. Tag: para
 #: using_raster_dataman.xml:22
@@ -119,6 +127,20 @@ msgid ""
 "# -f read this file after connecting\n"
 "psql -d gisdb -f elev.sql"
 msgstr ""
+"# -s SRID 4326を使用します\n"
+"# -I 空間インデックスを作ります\n"
+"# -C 標準的なラスタ制約を使用します\n"
+"# -M ロード後vacuum analyzeを実行します\n"
+"# *.tif 該当する全てのファイルをロードします\n"
+"# -F ラスタテーブルにfilenameカラムを入れます\n"
+"# -t 100x100のタイル出力にします\n"
+"# public.demelevation このテーブルにロードします\n"
+"raster2pgsql -s 4326 -I -C -M -F -t 100x100 *.tif public.demelevation > elev."
+"sql\n"
+"\n"
+"# -d このデータベースに接続します\n"
+"# -f ロード後にこのファイルを読み込みます\n"
+"psql -d gisdb -f elev.sql"
 #. Tag: para
 #: using_raster_dataman.xml:27
@@ -128,6 +150,8 @@ msgid ""
 "will be created in the default schema of the database or user you are "
 "connecting with."
 msgstr ""
+"対象テーブル名の一部としてスキーマを指定しない場合には、テーブルはデータベー"
+"スのデフォルトスキーマ内かユーザが接続しているスキーマ内に作られます。"
 #. Tag: para
 #: using_raster_dataman.xml:30
@@ -210,12 +234,25 @@ msgid ""
 "  ZMap Plus Grid\n"
 "  NOAA NGS Geoid Height Grids"
 msgstr ""
+"Available GDAL raster formats:\n"
+"  Virtual Raster\n"
+"  GeoTIFF\n"
+"  National Imagery Transmission Format\n"
+"  Raster Product Format TOC format\n"
+"  ECRG TOC format\n"
+"  Erdas Imagine Images (.img)\n"
+"  CEOS SAR Image\n"
+"  CEOS Image\n"
+"  ...\n"
+"  Arc/Info Export E00 GRID\n"
+"  ZMap Plus Grid\n"
+"  NOAA NGS Geoid Height Grids"
 #. Tag: title
 #: using_raster_dataman.xml:46
 #, no-c-format
 msgid "raster2pgsql options"
-msgstr ""
+msgstr "raster2pgsqlオプション"
 #. Tag: term
 #: using_raster_dataman.xml:50
commit 57c733a08eecd92dd38d6994b8fe4ab4fdadda98
Date:   Fri May 26 05:37:58 2023 +0000
    Currently translated at 100.0% (409 of 409 strings)
    Translation: postgis/reference_processing.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_processingxml/ja/
diff --git a/doc/po/ja/reference_processing.xml.po b/doc/po/ja/reference_processing.xml.po
index a4a6ea518..51b2b7331 100644
--- a/doc/po/ja/reference_processing.xml.po
+++ b/doc/po/ja/reference_processing.xml.po
@@ -10,7 +10,7 @@ msgstr ""
-"PO-Revision-Date: 2023-05-15 11:08+0000\n"
 "reference_processingxml/ja/>\n"
@@ -1925,6 +1925,9 @@ msgid ""
 "linkend=\"ST_ConstrainedDelaunayTriangles\"/>, <xref "
 "linkend=\"ST_VoronoiLines\"/>, <xref linkend=\"ST_ConvexHull\"/>"
 msgstr ""
+", <xref linkend=\"ST_TriangulatePolygon\"/>, <xref linkend="
+"\"ST_ConstrainedDelaunayTriangles\"/>, <xref linkend=\"ST_VoronoiLines\"/>, "
+"<xref linkend=\"ST_ConvexHull\"/>"
 #. Tag: refname
 #: reference_processing.xml:942
@@ -2873,7 +2876,7 @@ msgstr ""
 #: reference_processing.xml:1427
 #, no-c-format
 msgid "Availability: 2.5.0, requires GEOS >= 3.6.0"
-msgstr ""
+msgstr "Availability: 2.5.0, GEOS 3.6.0以上が必要です"
 #. Tag: programlisting
 #: reference_processing.xml:1434
Summary of changes:
 doc/po/ja/reference_processing.xml.po |  7 ++++--
 doc/po/ja/using_raster_dataman.xml.po | 47 +++++++++++++++++++++++++++++++----
 2 files changed, 47 insertions(+), 7 deletions(-)
hooks/post-receive
