[postgis-tickets] [PostGIS] #5389: ST_Transform broken with PROJ 9.2.0
PostGIS trac at osgeo.org
Sun May 28 17:49:05 PDT 2023
  Reporter:  tjay     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.9
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:  proj
Comment (by robe):
 This might be the same issue we are running into with our tests failing
 for 9.2.0 when certain grid shift files aren't available as discussed in
 #5360 and I'm pretty sure we had same issue with our GHA latest that runs
 9.2.0, but can't find that ticket.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5389#comment:3>
