[postgis-tickets] [PostGIS] #5385: Postgres malloc assertion fail when using pg_cancel_backend with ST_AsMVT
PostGIS trac at osgeo.org
Sun May 28 18:08:21 PDT 2023
  Reporter:  gbartonowenstl  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  high            |  Milestone:  PostGIS 3.3.3
 Component:  postgis         |    Version:  3.3.x
Resolution:                  |   Keywords:  malloc, crash
Comment (by robe):
 okay it did finally crash
 psql:mvt_style_call_minimal_reproduction.sql:53: ERROR:  canceling
 statement due to user request
 5036
 psql:mvt_style_call_minimal_reproduction.sql:53: server closed the
 connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 psql:mvt_style_call_minimal_reproduction.sql:53: error: connection to
 server was lost
 5037
 psql: error: connection to server on socket
 "/var/run/postgresql/.s.PGSQL.5432" failed: FATAL:  the database system is
 in recovery mode
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5385#comment:2>
