[postgis-tickets] [PostGIS] #5387: ST_Transform(geom, str, str) is very slow
PostGIS trac at osgeo.org
Sun May 28 22:48:16 PDT 2023
  Reporter:  cdestigter  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.3.3
 Component:  postgis     |    Version:  3.3.x
Resolution:              |   Keywords:
Comment (by robe):
 Can you output your
 SELECT postgis_full_version();
 I don't see using ST_Transform(geom, srid)  would yield a different answer
 from ST_Transform(geom, text, srid)
 In both cases it should be using the proj.db since the proj.db takes
 precedence over waht is in spatial_ref_sys table.
 Can you output an example where
 ST_AsText(ST_Transform(ST_SetSRID("GEOMETRY", 7844), 4326))
 is different from
 ST_AsText(ST_Transform("GEOMETRY", 'EPSG:7844' , 4326))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5387#comment:2>
