[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-954-g36fcdd626
Mon May 29 12:10:36 PDT 2023
the project "PostGIS".
       via  36fcdd626ba8b888119c8a53c7365ca9e9786f61 (commit)
      from  7be99c62a1dd9ee272a87d673960e84822a72a66 (commit)
revisions in full, below.
commit 36fcdd626ba8b888119c8a53c7365ca9e9786f61
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 29 21:10:09 2023 +0200
    Show obtained output on failure, in oriented_envelope test
    References #5391
diff --git a/regress/core/oriented_envelope.sql b/regress/core/oriented_envelope.sql
index 7029e18be..6d7c7c0e2 100644
--- a/regress/core/oriented_envelope.sql
+++ b/regress/core/oriented_envelope.sql
@@ -1,13 +1,12 @@
 -- It's strict
-SELECT 't1', ST_OrientedEnvelope(NULL::geometry) IS NULL;
+SELECT 't1', ST_OrientedEnvelope(NULL::geometry);
 -- Empty polygon on empty inputs
-SELECT 't2', ST_Equals(ST_OrientedEnvelope('POINT EMPTY'), 'POLYGON EMPTY'::geometry);
+SELECT 't2', ST_AsText(ST_OrientedEnvelope('POINT EMPTY'));
 -- SRID is preserved
-SELECT 't3', ST_SRID(ST_OrientedEnvelope('SRID=32611;POINT(4021690.58034526 6040138.01373556)')) = 32611;
+SELECT 't3', ST_SRID(ST_OrientedEnvelope('SRID=32611;POINT(4021690.58034526 6040138.01373556)'));
 -- Can return Point or LineString on degenerate inputs
-SELECT 't4', ST_Equals('LINESTRING (-1 -1, 2 2)', ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (2 2))'));
-SELECT 't5', ST_Equals('POINT (0.9625 2)', ST_OrientedEnvelope('POINT (0.9625 2)'));
+SELECT 't4', ST_AsText(ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (2 2))'));
+SELECT 't5', ST_AsText(ST_OrientedEnvelope('POINT (0.9625 2)'));
 -- Also works for normal inputs
--- Check using text to avoid precision difference between various GEOS versions
-SELECT 't6', ST_AsText(ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (3 2))')) = 'POLYGON((3 2,2.88 2.16,-1.12 -0.84,-1 -1,3 2))';
+SELECT 't6', ST_AsText(ST_Normalize(ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (3 2))')), 2);
diff --git a/regress/core/oriented_envelope_expected b/regress/core/oriented_envelope_expected
index 7590cd39a..5f1ff61cd 100644
--- a/regress/core/oriented_envelope_expected
+++ b/regress/core/oriented_envelope_expected
@@ -1,6 +1,6 @@
-t1|t
-t2|t
-t3|t
-t4|t
-t5|t
-t6|t
+t1|
+t2|POLYGON EMPTY
+t3|32611
+t4|LINESTRING(-1 -1,2 2)
+t5|POINT(0.9625 2)
+t6|POLYGON((-1.12 -0.84,2.88 2.16,3 2,-1 -1,-1.12 -0.84))
Summary of changes:
 regress/core/oriented_envelope.sql      | 13 ++++++-------
 regress/core/oriented_envelope_expected | 12 ++++++------
 2 files changed, 12 insertions(+), 13 deletions(-)
hooks/post-receive
