[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.2-67-ga230dbc02
Mon May 29 13:00:20 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  a230dbc02753a4e96376f08ebfdb56a347a01e30 (commit)
       via  33d4a9b577046fbf478a23be46a86746b931a113 (commit)
       via  e4535a80e0e130265ea0e39cf6547e9e85f9bd1e (commit)
      from  4910a7ba66b30ef02f863b159933b96db910ec4d (commit)
revisions in full, below.
commit a230dbc02753a4e96376f08ebfdb56a347a01e30
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 29 20:48:34 2023 +0200
    Don't use quad_segs<8, as newest GEOS will force a min of 8 anyway
    References #5391 in stable-3.3 branch (3.3.4dev)
diff --git a/regress/core/offsetcurve.sql b/regress/core/offsetcurve.sql
index 19623b65a..3bb1fcf9b 100644
--- a/regress/core/offsetcurve.sql
+++ b/regress/core/offsetcurve.sql
@@ -13,7 +13,7 @@ SELECT 't5b', ST_AsEWKT(ST_Normalize(ST_OffsetCurve(
  'SRID=42;LINESTRING(0 0, 10 0, 10 10)', 10)));
 SELECT 't6', ST_AsEWKT(ST_Normalize(ST_SnapToGrid(ST_OffsetCurve(
  'SRID=42;LINESTRING(0 0, 10 0, 10 10)', -10,
- 'quad_segs=2'),1)));
+ 'quad_segs=8'),1)));
 SELECT 't7', ST_AsEWKT(ST_Normalize(ST_OffsetCurve(
  'join=bevel'))
diff --git a/regress/core/offsetcurve_expected b/regress/core/offsetcurve_expected
index c06e01514..c3b00af60 100644
--- a/regress/core/offsetcurve_expected
+++ b/regress/core/offsetcurve_expected
@@ -6,7 +6,7 @@ t3|SRID=42;LINESTRING(0 -10,10 -10)
 t4|SRID=42;LINESTRING(0 10,10 10)
 t5|SRID=42;LINESTRING(0 -10,10 -10,12 -10,14 -9,16 -8,17 -7,18 -6,19 -4,20 -2,20 0,20 10)
 t5b|SRID=42;LINESTRING EMPTY
-t6|SRID=42;LINESTRING(0 -10,10 -10,17 -7,20 0,20 10)
+t6|SRID=42;LINESTRING(0 -10,10 -10,12 -10,14 -9,16 -8,17 -7,18 -6,19 -4,20 -2,20 0,20 10)
 t7|SRID=42;LINESTRING(0 -10,10 -10,20 0,20 10)
 t8|SRID=42;LINESTRING(0 -10,20 -10,20 10)
 t10|SRID=42;LINESTRING(0 2,7 2,3 9)
commit 33d4a9b577046fbf478a23be46a86746b931a113
Date:   Mon May 29 21:10:09 2023 +0200
    Show obtained output on failure, in oriented_envelope test
    References #5391
diff --git a/regress/core/oriented_envelope.sql b/regress/core/oriented_envelope.sql
index 7029e18be..6d7c7c0e2 100644
--- a/regress/core/oriented_envelope.sql
+++ b/regress/core/oriented_envelope.sql
@@ -1,13 +1,12 @@
 -- It's strict
-SELECT 't1', ST_OrientedEnvelope(NULL::geometry) IS NULL;
+SELECT 't1', ST_OrientedEnvelope(NULL::geometry);
 -- Empty polygon on empty inputs
-SELECT 't2', ST_Equals(ST_OrientedEnvelope('POINT EMPTY'), 'POLYGON EMPTY'::geometry);
+SELECT 't2', ST_AsText(ST_OrientedEnvelope('POINT EMPTY'));
 -- SRID is preserved
-SELECT 't3', ST_SRID(ST_OrientedEnvelope('SRID=32611;POINT(4021690.58034526 6040138.01373556)')) = 32611;
+SELECT 't3', ST_SRID(ST_OrientedEnvelope('SRID=32611;POINT(4021690.58034526 6040138.01373556)'));
 -- Can return Point or LineString on degenerate inputs
-SELECT 't4', ST_Equals('LINESTRING (-1 -1, 2 2)', ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (2 2))'));
-SELECT 't5', ST_Equals('POINT (0.9625 2)', ST_OrientedEnvelope('POINT (0.9625 2)'));
+SELECT 't4', ST_AsText(ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (2 2))'));
+SELECT 't5', ST_AsText(ST_OrientedEnvelope('POINT (0.9625 2)'));
 -- Also works for normal inputs
--- Check using text to avoid precision difference between various GEOS versions
-SELECT 't6', ST_AsText(ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (3 2))')) = 'POLYGON((3 2,2.88 2.16,-1.12 -0.84,-1 -1,3 2))';
+SELECT 't6', ST_AsText(ST_Normalize(ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (3 2))')), 2);
diff --git a/regress/core/oriented_envelope_expected b/regress/core/oriented_envelope_expected
index 7590cd39a..5f1ff61cd 100644
--- a/regress/core/oriented_envelope_expected
+++ b/regress/core/oriented_envelope_expected
@@ -1,6 +1,6 @@
-t1|t
-t2|t
-t3|t
-t4|t
-t5|t
-t6|t
+t1|
+t2|POLYGON EMPTY
+t3|32611
+t4|LINESTRING(-1 -1,2 2)
+t5|POINT(0.9625 2)
+t6|POLYGON((-1.12 -0.84,2.88 2.16,3 2,-1 -1,-1.12 -0.84))
commit e4535a80e0e130265ea0e39cf6547e9e85f9bd1e
Date:   Mon May 29 21:53:44 2023 +0200
    Flip to next milestone
diff --git a/NEWS b/NEWS
index 12dbad1a5..794334f15 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,9 @@
+PostGIS 3.3.4dev
+YYYY/MM/DD
+* Bug Fixes and Enhancements *
 PostGIS 3.3.3
 2023/05/29
diff --git a/Version.config b/Version.config
index 21d6b459b..550ba44bf 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=3
+POSTGIS_MICRO_VERSION=4dev
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Summary of changes:
 NEWS                                    |  6 ++++++
 Version.config                          |  2 +-
 regress/core/offsetcurve.sql            |  2 +-
 regress/core/offsetcurve_expected       |  2 +-
 regress/core/oriented_envelope.sql      | 13 ++++++-------
 regress/core/oriented_envelope_expected | 12 ++++++------
 6 files changed, 21 insertions(+), 16 deletions(-)
hooks/post-receive
