[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.3-6-g930f474c5
Tue May 30 21:30:22 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  930f474c58f4e12ff1fa61dfc3ef54f87584d53e (commit)
      from  ffd855ba878d2c9459bc7ae487c8cc398925e905 (commit)
revisions in full, below.
commit 930f474c58f4e12ff1fa61dfc3ef54f87584d53e
Author: Regina Obe <lr at pcorp.us>
Date:   Wed May 31 00:30:15 2023 -0400
    Numerous packaging and regress fixes to work with newer proj and other libs
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index fed194481..c50538c1c 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -16,18 +16,18 @@ fi;
 export PROTOBUF_VER=3.2.0
 export PROTOBUFC_VER=1.2.1
-export JSON_VER=0.12
+export JSON_VER=0.16
 export PCRE_VER=8.33
 if  [[ "${ICON_VER}" == '' ]] ; then
-  export ICON_VER=1.15
+  export ICON_VER=1.17
 fi;
 echo "ICON_VER ${ICON_VER}"
 #set to something even if override is on but not set
 if  [[ "${ZLIB_VER}" == '' ]] ; then
-  export ZLIB_VER=1.2.11
+  export ZLIB_VER=1.2.13
 fi;
@@ -95,8 +95,8 @@ export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
 export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig::${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
 export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
 CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index f23534dbd..23a59eba8 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -138,10 +138,10 @@ cp ${PGPATHEDB}/bin/libpq.dll  $outdir/bin/postgisgui
 cp ${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin/libicon*.dll $outdir/bin/postgisgui
 cp ${PGPATHEDB}/bin/libintl*.dll $outdir/bin/postgisgui
-cp ${PGPATHEDB}/bin/ssleay32.dll $outdir/bin/postgisgui
-cp ${PGPATHEDB}/bin/libeay32.dll $outdir/bin/postgisgui
-cp ${PGPATHEDB}/bin/libcrypto-1_1-x64.dll $outdir/bin/postgisgui
-cp ${PGPATHEDB}/bin/libssl-1_1-x64.dll $outdir/bin/postgisgui
+#cp ${PGPATHEDB}/bin/ssleay32.dll $outdir/bin/postgisgui
+#cp ${PGPATHEDB}/bin/libeay32.dll $outdir/bin/postgisgui
+#cp ${PGPATHEDB}/bin/libcrypto-1_1-x64.dll $outdir/bin/postgisgui
+#cp ${PGPATHEDB}/bin/libssl-1_1-x64.dll $outdir/bin/postgisgui
 #pg 15 is shipping with newer ssl
 cp ${PGPATHEDB}/bin/libcrypto-3-x64.dll $outdir/bin/postgisgui
@@ -166,6 +166,8 @@ cp ${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
 # new proj >= 8 folder prefixed with proj
 cp ${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj/* $outdir/share/contrib/postgis-${POSTGIS_MINOR_VER}/proj
 cp ${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin
+#for some reason shp2pgsql-gui has a dependency on proj, so annoying
+cp ${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 #start shipping the projsync
 cp ${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/projsync.exe $outdir/bin
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index a12277eba..9da1a3399 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,7 +1,7 @@
 #!/usr/bin/env bash
 set -e
 if  [[ "${OVERRIDE}" == '' ]] ; then
-	export GEOS_VER=3.11.0
+	export GEOS_VER=3.11.2
 	export GDAL_VER=3.4.2
 	export PROJ_VER=7.2.1
 	export SFCGAL_VER=1.4.1
@@ -10,7 +10,7 @@ if  [[ "${OVERRIDE}" == '' ]] ; then
-	export JSON_VER=0.1
+	export JSON_VER=0.16
 	export PROJSO=libproj-19.dll
 fi;
Summary of changes:
 ci/winnie/build_postgis.sh   | 10 +++++-----
 ci/winnie/package_postgis.sh | 10 ++++++----
 ci/winnie/regress_postgis.sh |  4 ++--
 3 files changed, 13 insertions(+), 11 deletions(-)
hooks/post-receive
