[PostGIS] #5212: Can't regress test PostGIS using non-superuser PostgreSQL role (cannot set lc_messages)
PostGIS trac at osgeo.org
Wed Nov 1 00:26:49 PDT 2023
lc_messages)
  Reporter:  robe          |      Owner:  robe
      Type:  defect        |     Status:  closed
  Priority:  medium        |  Milestone:  PostGIS 3.5.0
 Component:  QA/testsuite  |    Version:  3.0.x
Resolution:  wontfix       |   Keywords:  pgextwlist
Changes (by strk):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 I think we can close this as won't-fix as in order to load postgis
 function you'll need superuser anyway. Surely for script based and also
 for extension based unless we turn the extension into a trusted one ( ref
 #5567 ).
 Sandboxed based testing is now supported and used by Woodie.
 Regina: feel free to reopen if you disagree
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5212#comment:11>
