[SCM] PostGIS branch master updated. 3.4.0rc1-742-g6adb29e43
Wed Nov 1 13:10:54 PDT 2023
the project "PostGIS".
       via  6adb29e43b5514be567c4f91b43c635ad9163948 (commit)
      from  826f7c73f81646c87f5d47466d5319368581c0a1 (commit)
revisions in full, below.
commit 6adb29e43b5514be567c4f91b43c635ad9163948
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Nov 1 13:10:52 2023 -0700
    Improve doc for ST_Point examples
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index ba281c5f1..77353a666 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -700,22 +700,23 @@ FROM provinces p;
 		<title>Examples: Geometry</title>
         <programlisting>SELECT ST_Point( -71.104, 42.315);</programlisting>
-        <programlisting>SELECT ST_SetSRID(ST_Point( -71.104, 42.315),4326);</programlisting>
-        <para>New in 3.2.0: With SRID specified</para>
+        <para>Creating a point with SRID specified:</para>
 		<programlisting>SELECT ST_Point( -71.104, 42.315, 4326);</programlisting>
+        <para>Alternative way of specifying SRID:</para>
+        <programlisting>SELECT ST_SetSRID( ST_Point( -71.104, 42.315), 4326);</programlisting>
 	  </refsection>
 	  <refsection>
 		<title>Examples: Geography</title>
-        <para>Pre-PostGIS 3.2 syntax</para>
-        <programlisting>SELECT CAST( ST_SetSRID(ST_Point( -71.104, 42.315), 4326) AS geography);</programlisting>
-        <para>3.2 and on you can include the srid</para>
-		<programlisting>SELECT CAST( ST_Point( -71.104, 42.315, 4326) AS geography);</programlisting>
-		<para>PostgreSQL also provides the <varname>::</varname> short-hand for casting</para>
+		<para>Create <link linkend="PostGIS_Geography">geography</link> points using the <varname>::</varname> cast syntax:</para>
 		<programlisting>SELECT ST_Point( -71.104, 42.315, 4326)::geography;</programlisting>
+        <para>Pre-PostGIS 3.2 code, using <varname>CAST</varname>:</para>
+        <programlisting>SELECT CAST( ST_SetSRID(ST_Point( -71.104, 42.315), 4326) AS geography);</programlisting>
 <para>If the point coordinates are not in a geodetic coordinate system (such as WGS84),
 then they must be reprojected before casting to a geography.
 In this example a point in Pennsylvania State Plane feet (SRID 2273)
@@ -728,7 +729,7 @@ SELECT ST_Transform( ST_Point( 3637510, 3014852, 2273), 4326)::geography;</progr
 	  <refsection>
 		<title>See Also</title>
-		<para><xref linkend="PostGIS_Geography"/>, <xref linkend="ST_MakePoint"/>,
+		<para><xref linkend="ST_MakePoint"/>,
 			<xref linkend="ST_PointZ"/>, <xref linkend="ST_PointM"/>, <xref linkend="ST_PointZM"/>,
 			<xref linkend="ST_SetSRID"/>, <xref linkend="ST_Transform"/></para>
 	  </refsection>
Summary of changes:
 doc/reference_constructor.xml | 17 +++++++++--------
 1 file changed, 9 insertions(+), 8 deletions(-)
hooks/post-receive
