[SCM] PostGIS branch master updated. 3.4.0rc1-743-g5375fbef8
Thu Nov 2 05:08:45 PDT 2023
the project "PostGIS".
       via  5375fbef86e47b478623689b43f5458134a8149a (commit)
      from  6adb29e43b5514be567c4f91b43c635ad9163948 (commit)
revisions in full, below.
commit 5375fbef86e47b478623689b43f5458134a8149a
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Sep 7 11:53:42 2023 +0200
    [woodie] Stop using ci/dronie/postgis_regress.sh
    Uses a multi-step approach to have logs better organized.
    Ideally we would not need to do this but upstream does not
    support better organization of logs at the moment, see:
    https://github.com/woodpecker-ci/woodpecker/discussions/2263
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index c0bbe64ca..dab9e0885 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -1,5 +1,44 @@
 variables:
   test-image: &test-image docker.osgeo.org/postgis/build-test:trisquel3
+  steps-env: &steps-env
+    - export PATH=/usr/lib/postgresql/$${PGVER}/bin:$${PATH}
+    - export PGPORT=$$(grep ^port /etc/postgresql/$${PGVER}/main/postgresql.conf | awk '{print $$3}')
+    - export POSTGIS_REGRESS_DB_OWNER=postgis_reg_unprivileged_user
+    - export RUNTESTFLAGS="-v --after-create-db-script $${CI_WORKSPACE}/regress/hooks/configure-pgextwlist.sql"
+    - export SRCDIR=$${CI_WORKSPACE}
+    - export BUILDDIR=$${SRCDIR}/build/pg$${PGVER}
+    - export CURRENTVERSION=$$(grep '^POSTGIS_' $${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.')
+    - pg_config --version
+  steps-start-postgresql: &steps-start-postgresql
+    - service postgresql start $${PGVER}
+    - psql -c 'select version()' template1
+  steps-pg-build: &steps-pg-build
+    - mkdir -p "$${BUILDDIR}"
+    - cd "$${BUILDDIR}"
+    - $${SRCDIR}/configure
+      --with-library-minor-version
+      --enable-lto
+      --enable-lto
+      CFLAGS="-O2 -Wall -fno-omit-frame-pointer -Werror"
+    - make -j
+  steps-pg-test-preinstall: &steps-pg-test-preinstall
+    - cd build/pg$${PGVER}
+    - make check
+    - make check-double-upgrade
+    - make check-locked-upgrade
+  steps-pg-install: &steps-pg-install
+    - make -C build/pg$${PGVER} install
+  steps-pg-test-install: &steps-pg-test-install
+    - make -C build/pg$${PGVER} installcheck
+  steps-pg-test-all-upgrades: &steps-pg-test-all-upgrades
+    - mkfifo check.fifo
+    - tee check.log < check.fifo &
+    - $${SRCDIR}/utils/check_all_upgrades.sh -s $${CURRENTVERSION}! > check.fifo
+    - wait # for tee process to flush its buffers
+    - echo "-- Summary of upgrade tests --"
+    - egrep '(PASS|FAIL|SKIP|INFO|ERROR)' check.log
 clone:
   clone:
@@ -14,22 +53,86 @@ steps:
     commands:
       - ./autogen.sh
-  regress-pg12:
+  build-pg12:
     image: *test-image
     group: build
     environment:
       - PGVER=12
-      - POSTGIS_REGRESS_DB_OWNER=postgis_reg_unprivileged_user
-      - RUNTESTFLAGS=--after-create-db-script $${CI_WORKSPACE}/regress/hooks/configure-pgextwlist.sql
     commands:
-      - sh ci/dronie/postgis_regress.sh
+      - <<: *steps-env
+      - <<: *steps-pg-build
-  regress-pg15:
+  build-pg15:
     image: *test-image
     group: build
     environment:
       - PGVER=15
     commands:
+      - <<: *steps-env
+  check-pg12:
+    image: *test-image
+    group: check
+    environment:
+      - PGVER=12
+    commands:
+      - <<: *steps-env
+      - <<: *steps-start-postgresql
+      - <<: *steps-pg-test-preinstall
+  check-pg15:
+    group: check
+    environment:
+      - PGVER=15
+    commands:
+      - <<: *steps-env
+  installcheck-pg12:
+    group: installcheck
+    environment:
+      - PGVER=12
+    commands:
+      - <<: *steps-env
+      - <<: *steps-pg-install
+      - <<: *steps-pg-test-install
+  installcheck-pg15:
+    environment:
+      - PGVER=15
+    commands:
+      - <<: *steps-env
+  upgradecheck-pg12:
+    group: upgradecheck
+    environment:
+      - PGVER=12
+    commands:
+      - <<: *steps-env
+      - <<: *steps-pg-test-all-upgrades
+  upgradecheck-pg15:
+    environment:
+      - PGVER=15
+    commands:
+      - <<: *steps-env
Summary of changes:
 .woodpecker/regress.yml | 119 ++++++++++++++++++++++++++++++++++++++++++++----
 1 file changed, 111 insertions(+), 8 deletions(-)
hooks/post-receive
