[SCM] PostGIS branch master updated. 3.4.0rc1-748-gaedf3b14f
Thu Nov 2 22:23:56 PDT 2023
the project "PostGIS".
       via  aedf3b14f7e5bd220b01859f483bcc1168379189 (commit)
      from  ea8364b71272d8e3501d0a5617cacca04c11964e (commit)
revisions in full, below.
commit aedf3b14f7e5bd220b01859f483bcc1168379189
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Fri Nov 3 03:19:30 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5614 of 5614 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index cc89dc815..e4bb26fd7 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-11-02 18:50+0000\n"
-"PO-Revision-Date: 2023-10-31 09:23+0000\n"
+"PO-Revision-Date: 2023-11-03 05:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -7441,6 +7441,10 @@ msgid ""
 "GEOS is available for download from <link xlink:href=\"https://libgeos.org/"
 "\"> https://libgeos.org </link>."
 msgstr ""
+"GEOS 几何库,版本 &min_geos_version; "
+"或更高版本,但为了充分利用所有新的函数和特性,需要使用 GEOS 3.12+。"
+"您可以从以下链接下载 GEOS:<link xlink:href=\"https://libgeos.org/\"> "
+"https://libgeos.org </link>。"
 #. Tag: para
 #, no-c-format
@@ -7528,6 +7532,16 @@ msgid ""
 "sfcgal.org</link>) <link xlink:href=\"https://gitlab.com/sfcgal/SFCGAL/"
 "\">https://gitlab.com/sfcgal/SFCGAL/</link>."
 msgstr ""
+"SFCGAL,版本 1.3.1(或更高版本),建议使用 1.4.1 "
+"或更高版本,以能够使用所有功能。SFCGAL 可用于为 PostGIS 提供额外的 2D 和 3D "
+"高级分析功能,详情请参考 <xref linkend=\"reference_sfcgal\"/>。此外,"
+"还可以使用 SFCGAL 替代 GEOS 来执行某些由两个后端都提供的 2D 函数(例如 "
+"ST_Intersection 或 ST_Area)。如果已安装 SFCGAL,则用户可以通过 PostgreSQL "
+"配置变量 <code>postgis.backend</code> 来控制使用哪个后端(默认为 "
+"GEOS)。注意:SFCGAL 1.2 至少需要 CGAL 4.3 和 Boost 1.54(参见:<link "
+"xlink:href=\"https://sfcgal.org\">https://sfcgal.org</link>) <link "
+"xlink:href=\"https://gitlab.com/sfcgal/SFCGAL/\">https://gitlab.com/sfcgal/"
+"SFCGAL/</link>。"
 #. Tag: para
 #, no-c-format
@@ -13906,12 +13920,15 @@ msgid ""
 "Creates a 2D XY, 3D XYZ or 4D XYZM Point geometry. Use <xref linkend="
 "\"ST_MakePointM\"/> to make points with XYM coordinates."
 msgstr ""
+"创建一个2D XY、3D XYZ 或 4D XYZM 的点几何对象。使用 <xref linkend="
+"\"ST_MakePointM\"/> 来创建带有 XYM 坐标的点。"
 #. Tag: para
 #, no-c-format
 msgid ""
 "Use <xref linkend=\"ST_SetSRID\"/> to specify a SRID for the created point."
-msgstr ""
+msgstr "使用 <xref linkend=\"ST_SetSRID\"/> "
+"来为创建的点指定一个空间参考标识码(SRID)。"
 #. Tag: para
 #, no-c-format
@@ -13939,6 +13956,9 @@ msgid ""
 "<xref linkend=\"ST_PointM\"/>, and <xref linkend=\"ST_PointZM\"/> can be "
 "used to create points with a given SRID."
 msgstr ""
+"可以使用函数 <xref linkend=\"ST_Point\"/>、<xref linkend=\"ST_PointZ\"/>、"
+"<xref linkend=\"ST_PointM\"/> 和 <xref linkend=\"ST_PointZM\"/> "
+"来创建具有指定 SRID 的点。"
 #. Tag: para
 #, no-c-format
@@ -13948,6 +13968,10 @@ msgid ""
 "linkend=\"ST_PointZ\"/>, <xref linkend=\"ST_PointM\"/>, <xref linkend="
 "\"ST_PointZM\"/>"
 msgstr ""
+", <xref linkend=\"ST_PointFromText\"/>, <xref linkend=\"ST_SetSRID\"/>, "
+"<xref linkend=\"ST_MakePointM\"/>, <xref linkend=\"ST_Point\"/>, <xref "
+"linkend=\"ST_PointZ\"/>, <xref linkend=\"ST_PointM\"/>, <xref linkend="
+"\"ST_PointZM\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -13960,6 +13984,8 @@ msgid ""
 "Creates a point with X, Y and M (measure) ordinates. Use <xref linkend="
 "\"ST_MakePoint\"/> to make points with XY, XYZ, or XYZM coordinates."
 msgstr ""
+"创建一个具有X、Y和M(测量值)坐标的点。使用 <xref linkend=\"ST_MakePoint\"/> "
+"来创建具有XY、XYZ或XYZM坐标的点。"
 #. Tag: para
 #, no-c-format
@@ -13967,6 +13993,8 @@ msgid ""
 "The functions <xref linkend=\"ST_PointM\"/>, and <xref linkend=\"ST_PointZM"
 "\"/> can be used to create points with an M value and a given SRID."
 msgstr ""
+"函数 <xref linkend=\"ST_PointM\"/> 和 <xref linkend=\"ST_PointZM\"/> "
+"可用于创建具有 M 值和指定 SRID 的点。"
 #. Tag: para
 #, no-c-format
@@ -13997,6 +14025,8 @@ msgid ""
 ", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_PointM\"/>, <xref "
 "linkend=\"ST_PointZM\"/>"
 msgstr ""
+", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_PointM\"/>, <xref "
+"linkend=\"ST_PointZM\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -14147,12 +14177,12 @@ msgstr "示例:几何"
 #. Tag: para
 #, no-c-format
 msgid "Creating a point with SRID specified:"
-msgstr ""
+msgstr "创建一个指定了SRID的点:"
 #. Tag: para
 #, no-c-format
 msgid "Alternative way of specifying SRID:"
-msgstr ""
+msgstr "指定 SRID 的另一种方式:"
 #. Tag: title
 #, no-c-format
@@ -14165,11 +14195,13 @@ msgid ""
 "Create <link linkend=\"PostGIS_Geography\">geography</link> points using the "
 "<varname>::</varname> cast syntax:"
 msgstr ""
+"创建 <link linkend=\"PostGIS_Geography\">地理</link> 点(使用 <varname>::</"
+"varname> 转换语法):"
 #. Tag: para
 #, no-c-format
 msgid "Pre-PostGIS 3.2 code, using <varname>CAST</varname>:"
-msgstr ""
+msgstr "在Pre-PostGIS 3.2版本的代码中,使用 <varname>CAST</varname>:"
 #. Tag: para
 #, no-c-format
@@ -14190,6 +14222,9 @@ msgid ""
 "linkend=\"ST_PointZM\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref linkend="
 "\"ST_Transform\"/>"
 msgstr ""
+", <xref linkend=\"ST_PointZ\"/>, <xref linkend=\"ST_PointM\"/>, <xref "
+"linkend=\"ST_PointZM\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref linkend="
+"\"ST_Transform\"/>"
 #. Tag: refpurpose
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 45 +++++++++++++++++++++++++++++++++++-----
 1 file changed, 40 insertions(+), 5 deletions(-)
hooks/post-receive
