[SCM] PostGIS branch master updated. 3.4.0rc1-749-g42f04a29e
Fri Nov 3 03:23:51 PDT 2023
the project "PostGIS".
       via  42f04a29effdd9e8280c7aba17420ba306fc73f4 (commit)
      from  aedf3b14f7e5bd220b01859f483bcc1168379189 (commit)
revisions in full, below.
commit 42f04a29effdd9e8280c7aba17420ba306fc73f4
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Fri Nov 3 08:57:58 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5614 of 5614 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index e4bb26fd7..d729914fd 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-11-02 18:50+0000\n"
-"PO-Revision-Date: 2023-11-03 05:23+0000\n"
+"PO-Revision-Date: 2023-11-03 10:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -39007,8 +39007,9 @@ msgid ""
 "components that collapse to a lower dimensionality, for example a one-point "
 "linestring would be dropped."
 msgstr ""
-"“keepcollapsed”键仅对“结构”算法有效。 以“真”或“假”为例。 如果指定了“false”,"
-"则将显示已折叠为较低维度的几何元素,例如单个 LINESTRING。"
+"\"keepcollapsed\" 键仅对 \"structure\" 算法有效,其取值为 \"true\" 或 \"false"
+"\"。当设置为 \"false\" "
+"时,会删除折叠到更低维度的几何组件,例如一维线串(linestring)会被丢弃。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
hooks/post-receive
