[SCM] postgis.net branch website updated. clarity-final-68-ga7a0298
Tue Nov 7 16:45:44 PST 2023
the project "postgis.net".
The branch, website has been updated
       via  a7a029835c67ee06e9ee99e2da8b4af29da0219c (commit)
      from  36d68ab72a764966b0b6d14a19b2ab7feef40d69 (commit)
revisions in full, below.
commit a7a029835c67ee06e9ee99e2da8b4af29da0219c
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Nov 7 19:44:57 2023 -0500
    Clean up install instructions, fix typo
diff --git a/content/documentation/getting_started/install_red_hat.md b/content/documentation/getting_started/install_red_hat.md
index a32142a..18f604b 100644
--- a/content/documentation/getting_started/install_red_hat.md
+++ b/content/documentation/getting_started/install_red_hat.md
@@ -6,9 +6,9 @@ geekdocHidden: true
 geekdocHiddenTocTree: false
-The best place to get the latest binaries for both PostgreSQL and PostGIS is from the [PostgreSQL download page](https://www.postgresql.org/download/).
+The best place to get the latest binaries for both PostgreSQL and PostGIS is from the [PostgreSQL download page Redhat Derivatives](https://www.postgresql.org/download/linux/redhat/).
-* Select the "Linux" operating system and "Red Hat" distribution.
+* Select the PostgreSQL version
 * Select a "Platform" and an "Architecture".
 * Copy and run the setup script as root.
@@ -21,10 +21,13 @@ dnf -y install epel-release
 # Enable PowerTools repo (required for some of the dependencies):
 dnf -y config-manager --set-enabled PowerTools
+# for Rocky 8 and above might need to do this as well
+crb enable
 # Now, you can finally install PostGIS
 # Select the right PostGIS and PostgreSQL versions
-dnf -y install postgis33_15
+dnf -y install postgis34_16
-systemctl restart postgresql-15
+systemctl restart postgresql-16
diff --git a/content/documentation/getting_started/install_ubuntu.md b/content/documentation/getting_started/install_ubuntu.md
index ab566d5..e1927c7 100644
--- a/content/documentation/getting_started/install_ubuntu.md
+++ b/content/documentation/getting_started/install_ubuntu.md
@@ -6,6 +6,8 @@ geekdocHidden: true
+* The best place to get the latest binaries for both PostgreSQL and PostGIS is from the [PostgreSQL download page Debian](https://www.postgresql.org/download/linux/ubuntu/) and [PostgreSQL download page Ubuntu](https://www.postgresql.org/download/linux/ubuntu/).
 * The PostgreSQL build team has packages for Debian and Ubuntu for several versions of PostgreSQL and PostGIS [APT repository](https://wiki.postgresql.org/wiki/Apt) for PostgreSQL builds.
 * For specific PostGIS directions, see the [Ubuntu install guide](https://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS3UbuntuPGSQLApt).
\ No newline at end of file
diff --git a/content/documentation/getting_started/install_windows/released_versions.md b/content/documentation/getting_started/install_windows/released_versions.md
index 7e3d8a5..37b040f 100644
--- a/content/documentation/getting_started/install_windows/released_versions.md
+++ b/content/documentation/getting_started/install_windows/released_versions.md
@@ -8,7 +8,7 @@ geekdocHiddenTocTree: false
 PostGIS 3.4.0 came out August 15th, 2023. Windows PostGIS Bundle 3.4.0 was released August 19th, 2023.
-Binaries for versions of PostgreSQL 12-16 (64-bit) available in `Unreleased PostGIS Versions` and [OSGeo downloads][5]). Installers for 12-6(64-bit) and older releases of PostGIS are available on stackbuilder and [OSGeo downloads][5].
+Binaries for versions of PostgreSQL 12-16 (64-bit) available in `Unreleased PostGIS Versions` and [OSGeo downloads][5]). Installers for 12-16(64-bit) and older releases of PostGIS are available on stackbuilder and [OSGeo downloads][5].
 If you are using PostgreSQL < 12, use the PostGIS 3.3 bundle, because PostGIS 3.4+  does not support those versions.
Summary of changes:
 content/documentation/getting_started/install_red_hat.md      | 11 +++++++----
 content/documentation/getting_started/install_ubuntu.md       |  2 ++
 .../getting_started/install_windows/released_versions.md      |  2 +-
 3 files changed, 10 insertions(+), 5 deletions(-)
hooks/post-receive
postgis.net
