[PostGIS] #5606: Valid polygons in SQL Server are invalid in POSTGIS
PostGIS trac at osgeo.org
Thu Nov 9 11:17:20 PST 2023
  Reporter:  samnull10  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  high       |  Milestone:  PostGIS 3.4.1
 Component:  postgis    |    Version:  3.4.x
Resolution:             |   Keywords:
Comment (by ImreSamu):
 > either as WKB format or using geopandas
 Is the export feature to the "OGC Extended Well-Known Text (EWKT)" format
 functioning correctly?
 ( see https://postgis.net/docs/ST_GeomFromEWKT.html )
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5606#comment:2>
