[PostGIS] #5593: Fails to build with imagemagic 6.9.12.98
PostGIS trac at osgeo.org
Mon Nov 13 02:47:31 PST 2023
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.4.1
 Component:  build           |    Version:  3.4.x
Resolution:                  |   Keywords:
Comment (by strk):
 These security policy errors I've often stumbled upon and always had to
 fix by tweaking  /etc/ImageMagick-*/policy.xml so this would sound like a
 system configuration issue.
 See https://stackoverflow.com/questions/52998331/imagemagick-security-
 policy-pdf-blocking-conversion
 That said, if we can stop using `convert` commandline that could also fix
 the problem and make images generation faster.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5593#comment:1>
