[SCM] PostGIS branch master updated. 3.4.0rc1-760-gc209e806e
Mon Nov 13 05:39:27 PST 2023
the project "PostGIS".
       via  c209e806eacfe53a71696f4ee84f19256f3d77da (commit)
      from  0f4ce41779f4bda70c02fb1a547bf3dc8c12a8ea (commit)
revisions in full, below.
commit c209e806eacfe53a71696f4ee84f19256f3d77da
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Nov 13 12:53:14 2023 +0100
    Use better named vars for PostgreSQL build support
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 579b7553d..d8c28b937 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -5,7 +5,7 @@
 SUBDIRS = liblwgeom @RASTER@ loader
-ifeq (@LIBLWGEOM_ONLY@,no)
+ifeq (@SUPPORT_POSTGRESQL@,yes)
 SUBDIRS += @DEPS_SUBDIR@ libpgcommon postgis regress @TOPOLOGY@ @SFCGAL@ utils doc @EXTENSIONS@
 endif
@@ -55,7 +55,7 @@ endif
 all: postgis_revision.h
 ifeq ($(CAN_BUILD_COMMENTS),yes)
 install: comments-install
 uninstall: comments-uninstall
@@ -71,7 +71,7 @@ test: check
 check: check-unit docs-check check-lint
 check: check-regress
 endif
diff --git a/configure.ac b/configure.ac
index cd136395f..62efadb95 100644
--- a/configure.ac
+++ b/configure.ac
@@ -2,7 +2,9 @@ dnl **********************************************************************
 dnl *
 dnl * PostGIS - Spatial Types for PostgreSQL
 dnl * http://postgis.net
-dnl * Copyright 2008 Mark Cave-Ayland
+dnl *
+dnl * Copyright (C) 2010-2023 Sandro Santilli <strk at kbt.io>
+dnl * Copyright (C) 2008 Mark Cave-Ayland
 dnl *
 dnl * This is free software; you can redistribute and/or modify it under
 dnl * the terms of the GNU General Public Licence. See the COPYING file.
@@ -487,20 +489,20 @@ fi
 AC_SUBST([ICONV_LDFLAGS])
 AC_SUBST([ICONV_CFLAGS])
-LIBLWGEOM_ONLY="no"
-AC_SUBST([LIBLWGEOM_ONLY])
 dnl ===========================================================================
 dnl Detect the version of PostgreSQL installed on the system, if needed
+SUPPORT_POSTGRESQL=yes
+AC_SUBST([SUPPORT_POSTGRESQL])
 AC_ARG_VAR(PG_CONFIG, [PostgreSQL configure command to determine Postgres version to build against.])
 AC_ARG_WITH([pgconfig],
 	[AS_HELP_STRING([--with-pgconfig=FILE], [specify an alternative pg_config file or disable postgresql (--without-pgconfig)])],
 	[PG_CONFIG="$withval"], [])
 if test "x$PG_CONFIG" = "xno"; then
-	LIBLWGEOM_ONLY="yes"
+	SUPPORT_POSTGRESQL="no"
 	AC_MSG_RESULT([PostgreSQL support disabled])
 elif test "x$PG_CONFIG" = "x"; then
@@ -524,7 +526,7 @@ else
 	fi
 fi
-if test "x$LIBLWGEOM_ONLY" = "xno"; then
+if test "x$SUPPORT_POSTGRESQL" = "xyes"; then dnl {
   dnl Ensure that $PG_CONFIG --pgxs points to a valid file. This is because some
@@ -643,7 +645,7 @@ if test "x$LIBLWGEOM_ONLY" = "xno"; then
   AC_SUBST([POSTGIS_PGSQL_HR_VERSION])
   AC_SUBST([HAVE_SPGIST])
-fi dnl LIBLWGEOM_ONLY != no
+fi dnl } SUPPORT_POSTGRESQL = yes
@@ -1909,7 +1911,7 @@ if test "x$SFCGAL" = "xsfcgal"; then
     AC_MSG_RESULT([  SFCGAL config:        ${SFCGAL_CONFIG}])
     AC_MSG_RESULT([  SFCGAL version:       ${SFCGAL_VERSION}])
 fi
   AC_MSG_RESULT([  PostgreSQL config:    ${PG_CONFIG}])
   AC_MSG_RESULT([  PostgreSQL version:   ${PGSQL_FULL_VERSION}])
 else
Summary of changes:
 GNUmakefile.in |  6 +++---
 configure.ac   | 18 ++++++++++--------
 2 files changed, 13 insertions(+), 11 deletions(-)
hooks/post-receive
