[SCM] PostGIS branch master updated. 3.4.0rc1-764-gdcd9d87fe
Mon Nov 13 21:24:17 PST 2023
the project "PostGIS".
       via  dcd9d87feb28087f20df7d2d9ff13d735dbc59f8 (commit)
       via  49762f0ff699b7eddd6b70e653ba033be4bbf989 (commit)
       via  9439cfd6487fccdcdc171a5231649741febc9db1 (commit)
       via  5d3a79ba875c26a54cf17d79362b6d98fbdbd047 (commit)
      from  c209e806eacfe53a71696f4ee84f19256f3d77da (commit)
revisions in full, below.
commit dcd9d87feb28087f20df7d2d9ff13d735dbc59f8
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Nov 14 00:24:16 2023 -0500
    Update translation template
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 261565368..90359d911 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-11-02 18:50+0000\n"
+"POT-Creation-Date: 2023-11-14 05:23+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -14,530 +14,6 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-#. Tag: chapter
-#, no-c-format
-msgid "&database_tuning;"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "PostGIS Administration"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Configuring raster support"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you enabled raster support you may want to read below how to properly "
-"configure it."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"As of PostGIS 2.1.3, out-of-db rasters and all raster drivers are disabled "
-"by default. In order to re-enable these, you need to set the following "
-"environment variables <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> and "
-"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> in the server environment. "
-"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
-"corresponding <xref linkend=\"PostGIS_GUC\"/>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you want to enable offline raster:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Any other setting or no setting at all will disable out of db rasters."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"In order to enable all GDAL drivers available in your GDAL install, set this "
-"environment variable as follows"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you want to only enable specific drivers, set your environment variable "
-"as follows:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you are on windows, do not quote the driver list"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Setting environment variables varies depending on OS. For PostgreSQL "
-"installed on Ubuntu or Debian via apt-postgresql, the preferred way is to "
-"edit <filename>/etc/postgresql/<replaceable>10</replaceable>/"
-"<replaceable>main</replaceable>/environment</filename> where 10 refers to "
-"version of PostgreSQL and main refers to the cluster."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"On windows, if you are running as a service, you can set via System "
-"variables which for Windows 7 you can get to by right-clicking on Computer-"
-">Properties Advanced System Settings or in explorer navigating to "
-"<varname>Control Panel\\All Control Panel Items\\System</varname>. Then "
-"clicking <emphasis>Advanced System Settings ->Advanced->Environment "
-"Variables</emphasis> and adding new system variables."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"After you set the environment variables, you'll need to restart your "
-"PostgreSQL service for the changes to take effect."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Creating spatial databases"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Spatially enable database using EXTENSION"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you are using PostgreSQL 9.1+ and have compiled and installed the "
-"extensions/postgis modules, you can turn a database into a spatial one using "
-"the EXTENSION mechanism."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Core postgis extension includes geometry, geography, spatial_ref_sys and all "
-"the functions and comments. Raster and topology are packaged as a separate "
-"extension."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Run the following SQL snippet in the database you want to enable spatially:"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Spatially enable database without using EXTENSION (discouraged)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This is generally only needed if you cannot or don't want to get PostGIS "
-"installed in the PostgreSQL extension directory (for example during testing, "
-"development or in a restricted environment)."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Adding PostGIS objects and function definitions into your database is done "
-"by loading the various sql files located in <filename>[prefix]/share/"
-"contrib</filename> as specified during the build phase."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The core PostGIS objects (geometry and geography types, and their support "
-"functions) are in the <filename>postgis.sql</filename> script. Raster "
-"objects are in the <filename>rtpostgis.sql</filename> script. Topology "
-"objects are in the <filename>topology.sql</filename> script."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"For a complete set of EPSG coordinate system definition identifiers, you can "
-"also load the <filename>spatial_ref_sys.sql</filename> definitions file and "
-"populate the <varname>spatial_ref_sys</varname> table. This will permit you "
-"to perform ST_Transform() operations on geometries."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you wish to add comments to the PostGIS functions, you can find them in "
-"the <filename>postgis_comments.sql</filename> script. Comments can be viewed "
-"by simply typing <command>\\dd [function_name]</command> from a "
-"<command>psql</command> terminal window."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Run the following Shell commands in your terminal:"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Upgrading spatial databases"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Upgrading existing spatial databases can be tricky as it requires "
-"replacement or introduction of new PostGIS object definitions."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Unfortunately not all definitions can be easily replaced in a live database, "
-"so sometimes your best bet is a dump/reload process."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"PostGIS provides a SOFT UPGRADE procedure for minor or bugfix releases, and "
-"a HARD UPGRADE procedure for major releases."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Before attempting to upgrade PostGIS, it is always worth to backup your "
-"data. If you use the -Fc flag to pg_dump you will always be able to restore "
-"the dump with a HARD UPGRADE."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Soft upgrade"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you installed your database using extensions, you'll need to upgrade "
-"using the extension model as well. If you installed using the old sql script "
-"way, you are advised to switch your install to extensions because the script "
-"way is no longer supported."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Soft Upgrade 9.1+ using extensions"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you originally installed PostGIS with extensions, then you need to "
-"upgrade using extensions as well. Doing a minor upgrade with extensions, is "
-"fairly painless."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you are running PostGIS 3 or above, then you should use the <xref "
-"linkend=\"PostGIS_Extensions_Upgrade\"/> function to upgrade to the latest "
-"version you have installed."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you are running PostGIS 2.5 or lower, then do the following:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you have multiple versions of PostGIS installed, and you don't want to "
-"upgrade to the latest, you can explicitly specify the version as follows:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you get an error notice something like:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Then you'll need to backup your database, create a fresh one as described in "
-"<xref linkend=\"create_new_db_extensions\"/> and then restore your backup on "
-"top of this new database."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "If you get a notice message like:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Then everything is already up to date and you can safely ignore it. "
-"<emphasis role=\"bold\">UNLESS</emphasis> you're attempting to upgrade from "
-"an development version to the next (which doesn't get a new version number); "
-"in that case you can append \"next\" to the version string, and next time "
-"you'll need to drop the \"next\" suffix again:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you installed PostGIS originally without a version specified, you can "
-"often skip the reinstallation of postgis extension before restoring since "
-"the backup just has <code>CREATE EXTENSION postgis</code> and thus picks up "
-"the newest latest version during restore."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you are upgrading PostGIS extension from a version prior to 3.0.0, you "
-"will have a new extension <emphasis>postgis_raster</emphasis> which you can "
-"safely drop, if you don't need raster support. You can drop as follows:"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Soft Upgrade Pre 9.1+ or without extensions"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"This section applies only to those who installed PostGIS not using "
-"extensions. If you have extensions and try to upgrade with this approach "
-"you'll get messages like:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"NOTE: if you are moving from PostGIS 1.* to PostGIS 2.* or from PostGIS 2.* "
-"prior to r7409, you cannot use this procedure but would rather need to do a "
-"<link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"After compiling and installing (make install) you should find a set of "
-"<filename>*_upgrade.sql</filename> files in the installation folders. You "
-"can list them all with:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Load them all in turn, starting from <filename>postgis_upgrade.sql</"
-"filename>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The same procedure applies to raster, topology and sfcgal extensions, with "
-"upgrade files named <filename>rtpostgis_upgrade.sql</filename>, "
-"<filename>topology_upgrade.sql</filename> and <filename>sfcgal_upgrade.sql</"
-"filename> respectively. If you need them:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "You are advised to switch to an extension based install by running"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you can't find the <filename>postgis_upgrade.sql</filename> specific for "
-"upgrading your version you are using a version too early for a soft upgrade "
-"and need to do a <link linkend=\"hard_upgrade\">HARD UPGRADE</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The <xref linkend=\"PostGIS_Full_Version\"/> function should inform you "
-"about the need to run this kind of upgrade using a \"procs need upgrade\" "
-"message."
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Hard upgrade"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"By HARD UPGRADE we mean full dump/reload of postgis-enabled databases. You "
-"need a HARD UPGRADE when PostGIS objects' internal storage changes or when "
-"SOFT UPGRADE is not possible. The <link linkend=\"release_notes\">Release "
-"Notes</link> appendix reports for each version whether you need a dump/"
-"reload (HARD UPGRADE) to upgrade."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The dump/reload process is assisted by the postgis_restore script which "
-"takes care of skipping from the dump all definitions which belong to PostGIS "
-"(including old ones), allowing you to restore your schemas and data into a "
-"database with PostGIS installed without getting duplicate symbol errors or "
-"bringing forward deprecated objects."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Supplementary instructions for windows users are available at <link xlink:"
-"href=\"http://trac.osgeo.org/postgis/wiki/UsersWikiWinUpgrade\">Windows Hard "
-"upgrade</link>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "The Procedure is as follows:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Create a \"custom-format\" dump of the database you want to upgrade (let's "
-"call it <varname>olddb</varname>) include binary blobs (-b) and verbose (-v) "
-"output. The user can be the owner of the db, need not be postgres super "
-"account."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Do a fresh install of PostGIS in a new database -- we'll refer to this "
-"database as <varname>newdb</varname>. Please refer to <xref "
-"linkend=\"create_new_db\"/> and <xref linkend=\"create_new_db_extensions\"/> "
-"for instructions on how to do this."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"The spatial_ref_sys entries found in your dump will be restored, but they "
-"will not override existing ones in spatial_ref_sys. This is to ensure that "
-"fixes in the official set will be properly propagated to restored databases. "
-"If for any reason you really want your own overrides of standard entries "
-"just don't load the spatial_ref_sys.sql file when creating the new db."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If your database is really old or you know you've been using long deprecated "
-"functions in your views and functions, you might need to load "
-"<filename>legacy.sql</filename> for all your functions and views etc. to "
-"properly come back. Only do this if _really_ needed. Consider upgrading your "
-"views and functions before dumping instead, if possible. The deprecated "
-"functions can be later removed by loading <filename>uninstall_legacy.sql</"
-"filename>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Restore your backup into your fresh <varname>newdb</varname> database using "
-"postgis_restore. Unexpected errors, if any, will be printed to the standard "
-"error stream by psql. Keep a log of those."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Errors may arise in the following cases:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Some of your views or functions make use of deprecated PostGIS objects. In "
-"order to fix this you may try loading <filename>legacy.sql</filename> script "
-"prior to restore or you'll have to restore to a version of PostGIS which "
-"still contains those objects and try a migration again after porting your "
-"code. If the <filename>legacy.sql</filename> way works for you, don't forget "
-"to fix your code to stop using deprecated functions and drop them loading "
-"<filename>uninstall_legacy.sql</filename>."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Some custom records of spatial_ref_sys in dump file have an invalid SRID "
-"value. Valid SRID values are bigger than 0 and smaller than 999000. Values "
-"in the 999000.999999 range are reserved for internal use while values > "
-"999999 can't be used at all. All your custom records with invalid SRIDs will "
-"be retained, with those > 999999 moved into the reserved range, but the "
-"spatial_ref_sys table would lose a check constraint guarding for that "
-"invariant to hold and possibly also its primary key ( when multiple invalid "
-"SRIDS get converted to the same reserved SRID value )."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"In order to fix this you should copy your custom SRS to a SRID with a valid "
-"value (maybe in the 910000..910999 range), convert all your tables to the "
-"new srid (see <xref linkend=\"UpdateGeometrySRID\"/>), delete the invalid "
-"entry from spatial_ref_sys and re-construct the check(s) with:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"If you are upgrading an old database containing french <link xlink:"
-"href=\"https://en.wikipedia.org/wiki/Institut_g%C3%A9ographique_national\"> "
-"IGN </link> cartography, you will have probably SRIDs out of range and you "
-"will see, when importing your database, issues like this :"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"In this case, you can try following steps : first throw out completely the "
-"IGN from the sql which is resulting from postgis_restore. So, after having "
-"run :"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "run this command :"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Create then your newdb, activate the required Postgis extensions, and insert "
-"properly the french system IGN with : <link xlink:href=\"https://raw."
-"githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/"
-"Put_IGN_SRS_into_Postgis.sql\"> this script </link> After these operations, "
-"import your data :"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Performance Tuning"
@@ -7150,6 +6626,11 @@ msgid ""
 "Confirm you do by doing the following queries from psql or pgAdmin"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "This will only have data is you marked zcta5 to be loaded"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -31393,6 +30874,11 @@ msgstr ""
 msgid "LineString Extruded along Z produces a PolyhedralSurfaceZ"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"CG_ExtrudeStraightSkeleton\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Force LHR orientation"
@@ -31638,6 +31124,172 @@ msgstr ""
 msgid ", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes y-monotone partition of the polygon geometry"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Computes y-monotone partition of the polygon geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A partition of a polygon P is a set of polygons such that the interiors of "
+"the polygons do not intersect and the union of the polygons is equal to the "
+"interior of the original polygon P. A y-monotone polygon is a polygon whose "
+"vertices v1,…,vn can be divided into two chains v1,…,vk and vk,…,vn,v1, such "
+"that any horizontal line intersects either chain at most once. This "
+"algorithm does not guarantee a bound on the number of polygons produced with "
+"respect to the optimal number."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.5.0 - requires SFCGAL >= 1.5.0."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Y-Monotone Partition (same example As <xref "
+"linkend=\"CG_ApproxConvexPartition\"/>, <xref "
+"linkend=\"CG_GreeneApproxConvexPartition\"/> and <xref "
+"linkend=\"CG_OptimalConvexPartition\"/>)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"CG_GreeneApproxConvexPartition\"/>, <xref "
+"linkend=\"CG_OptimalConvexPartition\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes approximal convex partition of the polygon geometry"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Computes approximal convex partition of the polygon geometry (using a "
+"triangulation)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"interior of the original polygon P. CG_ApproxConvexPartition and "
+"CG_GreeneApproxConvexPartition functions produce approximately optimal "
+"convex partitions. Both these functions produce convex decompositions by "
+"first decomposing the polygon into simpler polygons; "
+"CG_ApproxConvexPartition uses a triangulation and "
+"CG_GreeneApproxConvexPartition a monotone partition. These two functions "
+"both guarantee that they will produce no more than four times the optimal "
+"number of convex pieces but they differ in their runtime complexities. "
+"Though the triangulation-based approximation algorithm often results in "
+"fewer convex pieces, this is not always the case."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Approximal Convex Partition (same example As <xref "
+"linkend=\"CG_YMonotonePartition\"/>, <xref "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Computes approximal monotone convex partition of the polygon geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Greene Approximal Convex Partition (same example As <xref "
+"linkend=\"CG_ApproxConvexPartition\"/> and <xref "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"CG_ApproxConvexPartition\"/>, <xref "
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes an optimal convex partition of the polygon geometry"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Computes an optimal convex partition of the polygon geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"interior of the original polygon P. CG_OptimalConvexPartition produces a "
+"partition that is optimal in the number of pieces."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Optimal Convex Partition (same example As <xref "
+"linkend=\"CG_GreeneApproxConvexPartition\"/>)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"linkend=\"CG_GreeneApproxConvexPartition\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Straight Skeleton Extrusion"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Computes an extrusion with a maximal height of the polygon geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Perhaps the first (historically) use-case of straight skeletons: given a "
+"polygonal roof, the straight skeleton directly gives the layout of each "
+"tent. If each skeleton edge is lifted from the plane a height equal to its "
+"offset distance, the resulting roof is \"correct\" in that water will always "
+"fall down to the contour edges (the roof's border), regardless of where it "
+"falls on the roof. The function computes this extrusion aka \"roof\" on a "
+"polygon. If the argument body_height > 0, so the polygon is extruded like "
+"with ST_Extrude(polygon, 0, 0, body_height). The result is an union of these "
+"polyhedralsurfaces."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_StraightSkeleton\"/>"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Spatial Reference System Functions"
commit 49762f0ff699b7eddd6b70e653ba033be4bbf989
Merge: c209e806e 9439cfd64
Date:   Tue Nov 14 00:21:29 2023 -0500
    Merge remote-tracking branch 'lbartoletti/sfcgal_extrudestraightskeleton'
    Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/157
commit 9439cfd6487fccdcdc171a5231649741febc9db1
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri Nov 10 07:20:09 2023 +0100
    Rename to CG_ExtrudeStraightSkeleton
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 6e8bb2663..b15f29b62 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -847,7 +847,7 @@ select ST_DelaunayTriangles(
 	  </refsection>
         <refsection>
 		<title>See Also</title>
-                <para><xref linkend="ST_AsX3D"/>, <xref linkend="ST_ExtrudeStraightSkeleton" /></para>
+                <para><xref linkend="ST_AsX3D"/>, <xref linkend="CG_ExtrudeStraightSkeleton" /></para>
 	  </refsection>
 	</refentry>
@@ -1264,7 +1264,7 @@ MULTIPOLYGON(
       <refsection>
-                <para><xref linkend="ST_ExtrudeStraightSkeleton" /></para>
+                <para><xref linkend="CG_ExtrudeStraightSkeleton" /></para>
 	  </refsection>
 	</refentry>
@@ -1650,9 +1650,9 @@ MULTIPOLYGON(
 	  </refsection>
 	</refentry>
-    <refentry xml:id="ST_ExtrudeStraightSkeleton">
+    <refentry xml:id="CG_ExtrudeStraightSkeleton">
 	  <refnamediv>
-		<refname>ST_ExtrudeStraightSkeleton</refname>
+		<refname>CG_ExtrudeStraightSkeleton</refname>
 		<refpurpose>Straight Skeleton Extrusion</refpurpose>
 	  </refnamediv>
@@ -1660,7 +1660,7 @@ MULTIPOLYGON(
 	  <refsynopsisdiv>
 		<funcsynopsis>
 		  <funcprototype>
-			<funcdef>geometry <function>ST_ExtrudeStraightSkeleton</function></funcdef>
+			<funcdef>geometry <function>CG_ExtrudeStraightSkeleton</function></funcdef>
 			<paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
                         <paramdef><type>float </type> <parameter>roof_height</parameter></paramdef>
                         <paramdef choice="opt"><type>float </type> <parameter>body_height = 0</parameter></paramdef>
@@ -1687,7 +1687,7 @@ MULTIPOLYGON(
 	  <refsection>
 	      <title>Examples</title>
 <para>
-         <programlisting>SELECT ST_AsText(ST_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));</programlisting>
+         <programlisting>SELECT ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));</programlisting>
           <screen>POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((4 5 2,5 5 2,4 4 2,4 5 2)),((2 1 2,5 0 2,0 0 2,2 1 2)),((5 5 2,5 0 2,4 4 2,5 5 2)),((2 1 2,0 0 2,1 1 2,2 1 2)),((1 2 2,1 1 2,0 0 2,1 2 2)),((0 4 2,2 2 2,1 2 2,0 4 2)),((0 4 2,1 2 2,0 0 2,0 4 2)),((4 4 2,5 0 2,2 2 2,4 4 2)),((4 4 2,2 2 2,0 4 2,4 4 2)),((2 2 2,5 0 2,2 1 2,2 2 2)),((0.5 2.5 2.5,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5)),((1 3 3,0 4 2,0.5 2.5 2.5,1 3 3)),((0.5 2.5 2.5,0 4 2,0 0 2,0.5 2.5 2.5)),((2.5 0.5 2.5,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5)),((0 0 2,5 0 2,2.5 0.5 2.5,0 0 2)),((0.5 0.5 2.5,0 0 2,2.5 0.5 2.5,0.5 0.5 2.5)),((4.5 3.5 2.5,
 5 5 2,4.5 4.5 2.5,4.5 3.5 2.5)),((3.5 2.5 3.5,3.5 1.5 3.5,4.5 3.5 2.5,3.5 2.5 3.5)),((4.5 3.5 2.5,5 0 2,5 5 2,4.5 3.5 2.5)),((3.5 1.5 3.5,5 0 2,4.5 3.5 2.5,3.5 1.5 3.5)),((5 5 2,4 5 2,4.5 4.5 2.5,5 5 2)),((4.5 4.5 2.5,4 4 2,4.5 3.5 2.5,4.5 4.5 2.5)),((4.5 4.5 2.5,4 5 2,4 4 2,4.5 4.5 2.5)),((3 3 3,0 4 2,1 3 3,3 3 3)),((3.5 2.5 3.5,4.5 3.5 2.5,3 3 3,3.5 2.5 3.5)),((3 3 3,4 4 2,0 4 2,3 3 3)),((4.5 3.5 2.5,4 4 2,3 3 3,4.5 3.5 2.5)),((2 1 2,1 1 2,0.5 0.5 2.5,2 1 2)),((2.5 0.5 2.5,2 1 2,0.5 0.5 2.5,2.5 0.5 2.5)),((1 1 2,1 2 2,0.5 2.5 2.5,1 1 2)),((0.5 0.5 2.5,1 1 2,0.5 2.5 2.5,0.5 0.5 2.5)),((1 3 3,2 2 2,3 3 3,1 3 3)),((0.5 2.5 2.5,1 2 2,1 3 3,0.5 2.5 2.5)),((1 3 3,1 2 2,2 2 2,1 3 3)),((2 2 2,2 1 2,2.5 0.5 2.5,2 2 2)),((3.5 2.5 3.5,3 3 3,3.5 1.5 3.5,3.5 2.5 3.5)),((3.5 1.5 3.5,2 2 2,2.5 0.5 2.5,3.5 1.5 3.5)),((3 3 3,2 2 2,3.5 1.5 3.5,3 3 3)))</screen>
         </para>
 	  </refsection>
diff --git a/sfcgal/regress/extrudestraigthskeleton.sql b/sfcgal/regress/extrudestraigthskeleton.sql
index 2fa4f26ee..c0b8df3c1 100644
--- a/sfcgal/regress/extrudestraigthskeleton.sql
+++ b/sfcgal/regress/extrudestraigthskeleton.sql
@@ -1,2 +1,2 @@
-SELECT 'Extrude roof', ST_AsText(ST_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 2.0));
-SELECT 'Extrude building and roof', ST_AsText(ST_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));
+SELECT 'Extrude roof', ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 2.0));
+SELECT 'Extrude building and roof', ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index 3745c4b6e..946a5b979 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -191,7 +191,6 @@ CREATE OR REPLACE FUNCTION ST_OptimalAlphaShape(g1 geometry, allow_holes boolean
 COMMIT;
 -- Availability: 3.5.0
-<<<<<<< HEAD
 CREATE OR REPLACE FUNCTION CG_YMonotonePartition(g1 geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'sfcgal_ymonotonepartition'
commit 5d3a79ba875c26a54cf17d79362b6d98fbdbd047
Date:   Tue Oct 3 11:20:32 2023 +0200
    [sfcgal]: Add ST_ExtrudeStraightSkeleton
diff --git a/NEWS b/NEWS
index c6602214a..0d60e6781 100644
--- a/NEWS
+++ b/NEWS
@@ -15,7 +15,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
            ) (Sandro Santilli)
   - #5536, comments are not anymore included in PostGIS extensions
     (Sandro Santilli)
-  - xmllint is now required to build comments and
+  - xmllint is now required to build comments and
     (Sandro Santilli)
   - DocBook5 XSL is now required to build html documentation
     (Sandro Santilli)
@@ -27,6 +27,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
            error with <> and != (Paul Ramsey)
   - Add ST_HasZ/ST_HasM (Loïc Bartoletti)
   - GT-123, postgis_sfcgal: CG_YMonotonePartition, CG_ApproxConvexPartition, CG_GreeneApproxConvexPartition and CG_OptimalConvexPartition (Loïc Bartoletti)
+  - GT-157, postgis_sfcgal: Add ST_ExtrudeStraightSkeleton (Loïc Bartoletti)
 * Enhancements *
index 8dff4f89f..6e8bb2663 100644
@@ -846,10 +846,9 @@ select ST_DelaunayTriangles(
 			</informaltable>
 	  </refsection>
         <refsection>
-                <title>See Also</title>
-                <para><xref linkend="ST_AsX3D"/></para>
-        </refsection>
+		<title>See Also</title>
+                <para><xref linkend="ST_AsX3D"/>, <xref linkend="ST_ExtrudeStraightSkeleton" /></para>
+	  </refsection>
 	</refentry>
 	<refentry xml:id="ST_ForceLHR">
@@ -1263,6 +1262,10 @@ MULTIPOLYGON(
 			</informaltable>
 	  </refsection>
+      <refsection>
+                <para><xref linkend="ST_ExtrudeStraightSkeleton" /></para>
+	  </refsection>
 	</refentry>
@@ -1646,5 +1649,52 @@ MULTIPOLYGON(
                 <para><xref linkend="CG_YMonotonePartition" />, <xref linkend="CG_ApproxConvexPartition" />, <xref linkend="CG_GreeneApproxConvexPartition" /></para>
 	  </refsection>
+	</refentry>
+    <refentry xml:id="ST_ExtrudeStraightSkeleton">
+	  <refnamediv>
+		<refname>ST_ExtrudeStraightSkeleton</refname>
+		<refpurpose>Straight Skeleton Extrusion</refpurpose>
+	  </refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>geometry <function>ST_ExtrudeStraightSkeleton</function></funcdef>
+			<paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+                        <paramdef><type>float </type> <parameter>roof_height</parameter></paramdef>
+                        <paramdef choice="opt"><type>float </type> <parameter>body_height = 0</parameter></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+        <title>Description</title>
+          <para>Computes an extrusion with a maximal height of the polygon geometry.
+          </para>
+        <note><para>
+	Perhaps the first (historically) use-case of straight skeletons: given a polygonal roof, the straight skeleton directly gives the layout of each tent. If each skeleton edge is lifted from the plane a height equal to its offset distance, the resulting roof is "correct" in that water will always fall down to the contour edges (the roof's border), regardless of where it falls on the roof.
+	The function computes this extrusion aka "roof" on a polygon. If the argument body_height > 0, so the polygon is extruded like with ST_Extrude(polygon, 0, 0, body_height). The result is an union of these polyhedralsurfaces.
+        </para></note>
+		<para>Availability: 3.5.0 - requires SFCGAL >= 1.5.0.</para>
+		<para>&sfcgal_required;</para>
+	  </refsection>
+	  <refsection>
+	      <title>Examples</title>
+<para>
+         <programlisting>SELECT ST_AsText(ST_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));</programlisting>
+          <screen>POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((4 5 2,5 5 2,4 4 2,4 5 2)),((2 1 2,5 0 2,0 0 2,2 1 2)),((5 5 2,5 0 2,4 4 2,5 5 2)),((2 1 2,0 0 2,1 1 2,2 1 2)),((1 2 2,1 1 2,0 0 2,1 2 2)),((0 4 2,2 2 2,1 2 2,0 4 2)),((0 4 2,1 2 2,0 0 2,0 4 2)),((4 4 2,5 0 2,2 2 2,4 4 2)),((4 4 2,2 2 2,0 4 2,4 4 2)),((2 2 2,5 0 2,2 1 2,2 2 2)),((0.5 2.5 2.5,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5)),((1 3 3,0 4 2,0.5 2.5 2.5,1 3 3)),((0.5 2.5 2.5,0 4 2,0 0 2,0.5 2.5 2.5)),((2.5 0.5 2.5,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5)),((0 0 2,5 0 2,2.5 0.5 2.5,0 0 2)),((0.5 0.5 2.5,0 0 2,2.5 0.5 2.5,0.5 0.5 2.5)),((4.5 3.5 2.5,
+        </para>
+	  </refsection>
+      <refsection>
+                <para><xref linkend="ST_Extrude" />, <xref linkend="ST_StraightSkeleton" /></para>
+	  </refsection>
 	</refentry>
 </section>
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 10742c9d5..0276d625e 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -861,3 +861,42 @@ Datum sfcgal_optimalconvexpartition(PG_FUNCTION_ARGS)
 #endif
+PG_FUNCTION_INFO_V1(sfcgal_extrudestraightskeleton);
+Datum sfcgal_extrudestraightskeleton(PG_FUNCTION_ARGS)
+#if POSTGIS_SFCGAL_VERSION < 10500
+  lwpgerror("The SFCGAL version this PostGIS binary "
+	          "was compiled against (%d) doesn't support "
+	          "'sfcgal_extrude_straigth_skeleton' function (1.5.0+ required)",
+	          POSTGIS_SFCGAL_VERSION);
+	          PG_RETURN_NULL();
+#else /* POSTGIS_SFCGAL_VERSION >= 10500 */
+	GSERIALIZED *input, *output;
+	sfcgal_geometry_t *geom;
+	sfcgal_geometry_t *result;
+  double building_height, roof_height;
+	srid_t srid;
+	sfcgal_postgis_init();
+	input = PG_GETARG_GSERIALIZED_P(0);
+	srid = gserialized_get_srid(input);
+	geom = POSTGIS2SFCGALGeometry(input);
+	PG_FREE_IF_COPY(input, 0);
+	roof_height = PG_GETARG_FLOAT8(1);
+	building_height = PG_GETARG_FLOAT8(2);
+	if(building_height <= 0.0 ) {
+		result = sfcgal_geometry_extrude_straight_skeleton(geom, roof_height);
+	else {
+		result = sfcgal_geometry_extrude_polygon_straight_skeleton(geom, building_height, roof_height);
+	sfcgal_geometry_delete(geom);
+	output = SFCGALGeometry2POSTGIS(result, 0, srid);
+	sfcgal_geometry_delete(result);
+	PG_RETURN_POINTER(output);
+#endif
diff --git a/sfcgal/lwgeom_sfcgal.h b/sfcgal/lwgeom_sfcgal.h
index 71f1608a3..16fe536a1 100644
--- a/sfcgal/lwgeom_sfcgal.h
+++ b/sfcgal/lwgeom_sfcgal.h
@@ -57,6 +57,7 @@ Datum sfcgal_ymonotonepartition(PG_FUNCTION_ARGS);
 Datum sfcgal_approxconvexpartition(PG_FUNCTION_ARGS);
 Datum sfcgal_greeneapproxconvexpartition(PG_FUNCTION_ARGS);
 Datum sfcgal_optimalconvexpartition(PG_FUNCTION_ARGS);
+Datum sfcgal_extrudestraigthskeleton(PG_FUNCTION_ARGS);
 /* Initialize sfcgal with PostGIS error handlers */
 void sfcgal_postgis_init(void);
new file mode 100644
index 000000000..2fa4f26ee
--- /dev/null
@@ -0,0 +1,2 @@
+SELECT 'Extrude roof', ST_AsText(ST_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 2.0));
+SELECT 'Extrude building and roof', ST_AsText(ST_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));
diff --git a/sfcgal/regress/extrudestraigthskeleton_expected b/sfcgal/regress/extrudestraigthskeleton_expected
index 000000000..0b3805b35
--- /dev/null
+++ b/sfcgal/regress/extrudestraigthskeleton_expected
@@ -0,0 +1,2 @@
+Extrude roof|POLYHEDRALSURFACE Z (((4 5 0,5 5 0,4 4 0,4 5 0)),((2 1 0,5 0 0,0 0 0,2 1 0)),((5 5 0,5 0 0,4 4 0,5 5 0)),((2 1 0,0 0 0,1 1 0,2 1 0)),((1 2 0,1 1 0,0 0 0,1 2 0)),((0 4 0,2 2 0,1 2 0,0 4 0)),((0 4 0,1 2 0,0 0 0,0 4 0)),((4 4 0,5 0 0,2 2 0,4 4 0)),((4 4 0,2 2 0,0 4 0,4 4 0)),((2 2 0,5 0 0,2 1 0,2 2 0)),((0.5 2.5 0.5,0 0 0,0.5 0.5 0.5,0.5 2.5 0.5)),((1 3 1,0 4 0,0.5 2.5 0.5,1 3 1)),((0.5 2.5 0.5,0 4 0,0 0 0,0.5 2.5 0.5)),((2.5 0.5 0.5,5 0 0,3.5 1.5 1.5,2.5 0.5 0.5)),((0 0 0,5 0 0,2.5 0.5 0.5,0 0 0)),((0.5 0.5 0.5,0 0 0,2.5 0.5 0.5,0.5 0.5 0.5)),((4.5 3.5 0.5,5 5 0,4.5 4.5 0.5,4.5 3.5 0.5)),((3.5 2.5 1.5,3.5 1.5 1.5,4.5 3.5 0.5,3.5 2.5 1.5)),((4.5 3.5 0.5,5 0 0,5 5 0,4.5 3.5 0.5)),((3.5 1.5 1.5,5 0 0,4.5 3.5 0.5,3.5 1.5 1.5)),((5 5 0,4 5 0,4.5 4.5 0.5,5 5 0)),((4.5 4.5 0.5,4 4 0,4.5 3.5 0.5,4.5 4.5 0.5)),((4.5 4.5 0.5,4 5 0,4 4 0,4.5 4.5 0.5)),((3 3 1,0 4 0,1 3 1,3 3 1)),((3.5 2.5 1.5,4.5 3.5 0.5,3 3 1,3.5 2.5 1.5)),((3 3 1,4 4 0,0 4 0,3 3 1)),((4.5 3.5 0.5,4 4 0,3 3 1,4.5 3
 .5 0.5)),((2 1 0,1 1 0,0.5 0.5 0.5,2 1 0)),((2.5 0.5 0.5,2 1 0,0.5 0.5 0.5,2.5 0.5 0.5)),((1 1 0,1 2 0,0.5 2.5 0.5,1 1 0)),((0.5 0.5 0.5,1 1 0,0.5 2.5 0.5,0.5 0.5 0.5)),((1 3 1,2 2 0,3 3 1,1 3 1)),((0.5 2.5 0.5,1 2 0,1 3 1,0.5 2.5 0.5)),((1 3 1,1 2 0,2 2 0,1 3 1)),((2 2 0,2 1 0,2.5 0.5 0.5,2 2 0)),((3.5 2.5 1.5,3 3 1,3.5 1.5 1.5,3.5 2.5 1.5)),((3.5 1.5 1.5,2 2 0,2.5 0.5 0.5,3.5 1.5 1.5)),((3 3 1,2 2 0,3.5 1.5 1.5,3 3 1)))
+Extrude building and roof|POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((4 5 2,5 5 2,4 4 2,4 5 2)),((2 1 2,5 0 2,0 0 2,2 1 2)),((5 5 2,5 0 2,4 4 2,5 5 2)),((2 1 2,0 0 2,1 1 2,2 1 2)),((1 2 2,1 1 2,0 0 2,1 2 2)),((0 4 2,2 2 2,1 2 2,0 4 2)),((0 4 2,1 2 2,0 0 2,0 4 2)),((4 4 2,5 0 2,2 2 2,4 4 2)),((4 4 2,2 2 2,0 4 2,4 4 2)),((2 2 2,5 0 2,2 1 2,2 2 2)),((0.5 2.5 2.5,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5)),((1 3 3,0 4 2,0.5 2.5 2.5,1 3 3)),((0.5 2.5 2.5,0 4 2,0 0 2,0.5 2.5 2.5)),((2.5 0.5 2.5,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5)),((0 0 2,5 0 2,2.5 0.5 2.5,0 0 2)),((0.5 0.5 2.5,0 0 2,2.5 0.5 2.5,0.5 0.5 2.5)),((4.5
 3.5 2.5,5 5 2,4.5 4.5 2.5,4.5 3.5 2.5)),((3.5 2.5 3.5,3.5 1.5 3.5,4.5 3.5 2.5,3.5 2.5 3.5)),((4.5 3.5 2.5,5 0 2,5 5 2,4.5 3.5 2.5)),((3.5 1.5 3.5,5 0 2,4.5 3.5 2.5,3.5 1.5 3.5)),((5 5 2,4 5 2,4.5 4.5 2.5,5 5 2)),((4.5 4.5 2.5,4 4 2,4.5 3.5 2.5,4.5 4.5 2.5)),((4.5 4.5 2.5,4 5 2,4 4 2,4.5 4.5 2.5)),((3 3 3,0 4 2,1 3 3,3 3 3)),((3.5 2.5 3.5,4.5 3.5 2.5,3 3 3,3.5 2.5 3.5)),((3 3 3,4 4 2,0 4 2,3 3 3)),((4.5 3.5 2.5,4 4 2,3 3 3,4.5 3.5 2.5)),((2 1 2,1 1 2,0.5 0.5 2.5,2 1 2)),((2.5 0.5 2.5,2 1 2,0.5 0.5 2.5,2.5 0.5 2.5)),((1 1 2,1 2 2,0.5 2.5 2.5,1 1 2)),((0.5 0.5 2.5,1 1 2,0.5 2.5 2.5,0.5 0.5 2.5)),((1 3 3,2 2 2,3 3 3,1 3 3)),((0.5 2.5 2.5,1 2 2,1 3 3,0.5 2.5 2.5)),((1 3 3,1 2 2,2 2 2,1 3 3)),((2 2 2,2 1 2,2.5 0.5 2.5,2 2 2)),((3.5 2.5 3.5,3 3 3,3.5 1.5 3.5,3.5 2.5 3.5)),((3.5 1.5 3.5,2 2 2,2.5 0.5 2.5,3.5 1.5 3.5)),((3 3 3,2 2 2,3.5 1.5 3.5,3 3 3)))
diff --git a/sfcgal/regress/tests.mk.in b/sfcgal/regress/tests.mk.in
index aef48abab..e3bd2d342 100644
--- a/sfcgal/regress/tests.mk.in
+++ b/sfcgal/regress/tests.mk.in
@@ -24,5 +24,6 @@ endif
 ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 10500),1)
 	TESTS += \
-		$(top_srcdir)/sfcgal/regress/partition.sql
+		$(top_srcdir)/sfcgal/regress/partition.sql \
+		$(top_srcdir)/sfcgal/regress/extrudestraigthskeleton.sql
 endif
index 851373ec1..3745c4b6e 100644
@@ -191,6 +191,7 @@ CREATE OR REPLACE FUNCTION ST_OptimalAlphaShape(g1 geometry, allow_holes boolean
 COMMIT;
+<<<<<<< HEAD
        RETURNS geometry
@@ -222,3 +223,10 @@ CREATE OR REPLACE FUNCTION CG_OptimalConvexPartition(g1 geometry)
        COST 100;
 COMMIT;
+-- Availability: 3.5.0
+CREATE OR REPLACE FUNCTION ST_ExtrudeStraightSkeleton(g1 geometry, top_height float8, body_height float8 DEFAULT 0.0)
+       RETURNS geometry
+       AS 'MODULE_PATHNAME', 'sfcgal_extrudestraightskeleton'
+       LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+       COST 100;
+COMMIT;
Summary of changes:
 NEWS                                            |   3 +-
 doc/po/templates/postgis-manual.pot             | 702 ++++++------------------
 doc/reference_sfcgal.xml                        |  58 +-
 sfcgal/lwgeom_sfcgal.c                          |  39 ++
 sfcgal/lwgeom_sfcgal.h                          |   1 +
 sfcgal/regress/extrudestraigthskeleton.sql      |   2 +
 sfcgal/regress/extrudestraigthskeleton_expected |   2 +
 sfcgal/regress/tests.mk.in                      |   3 +-
 sfcgal/sfcgal.sql.in                            |   7 +
 9 files changed, 286 insertions(+), 531 deletions(-)
 create mode 100644 sfcgal/regress/extrudestraigthskeleton.sql
 create mode 100644 sfcgal/regress/extrudestraigthskeleton_expected
hooks/post-receive
