[PostGIS] #5609: Description note in ST_SetBandPath is not correct
PostGIS trac at osgeo.org
Tue Nov 14 06:51:00 PST 2023
 Reporter:  paulovieira    |      Owner:  robe
     Type:  enhancement    |     Status:  new
 Priority:  low            |  Milestone:  PostGIS 3.4.1
Component:  documentation  |    Version:  3.4.x
 Keywords:                 |
 Docs for ST_SetBandPath: https://postgis.net/docs/RT_ST_SetBandPath.html
 The second note says: "Internally, this method replaces the PostGIS
 raster's band at index band with a new band instead of updating the
 existing path information."
 The "instead of updating the existing path information." is not correct.
 The objective of this function is precisely to update the path information
 (right?).
 I believe this originated from the documentation of the related
 ST_SetBandIndex (which also has this note, but in that case it's correct).
 Thanks.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5609>
