[SCM] PostGIS branch master updated. 3.4.0rc1-775-g86e698565
Wed Nov 15 22:23:54 PST 2023
the project "PostGIS".
       via  86e698565bd5cf13a95fc70199f7e3d51a92c769 (commit)
      from  96e13bab69519da3f67878b56555485f518d4b45 (commit)
revisions in full, below.
commit 86e698565bd5cf13a95fc70199f7e3d51a92c769
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Thu Nov 16 05:17:52 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5568 of 5568 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index a43d13d5d..8b126731a 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-11-14 05:23+0000\n"
-"PO-Revision-Date: 2023-11-15 09:23+0000\n"
+"PO-Revision-Date: 2023-11-16 06:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -35833,9 +35833,9 @@ msgid ""
 "defaults to <varname>use_spheroid = true</varname>. For faster evaluation "
 "use <varname>use_spheroid = false</varname> to measure on the sphere."
 msgstr ""
-"对于<type>地理</type>:单位为米,距离测量默认为<varname> use_spheroid = "
-"true</varname>。 为了更快地进行评估,请使用<varname> use_spheroid = false </"
-"varname>在球体上进行测量。"
+"对于 <type>地理</type>:单位为米,距离测量默认使用 <varname>use_spheroid = "
+"true</varname>(使用椭球体)。为了更快的计算,可以使用 <varname>use_spheroid "
+"= false</varname>,在球面上进行测量。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
