[PostGIS] #5614: regress/core/delaunaytriangles failure
PostGIS trac at osgeo.org
Sat Nov 18 09:56:03 PST 2023
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.4.1
 Component:  postgis         |    Version:  3.4.x
Resolution:                  |   Keywords:
Comment (by robe):
 ./regress/core/delaunaytriangles_expected  doesn't use GDAL at all so that
 would be strictly a GEOS issue. Looks like strk already patched this issue
 at [1cebea67/git]
 The delaunaytriangles was a result of order changes in the micro releases
 of GEOS.  So they should all disappear once we release 3.4.1, which should
 hopefully be soon.
 Can you test with [1cebea67/git] patch and confirm it fixes your issue?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5614#comment:2>
