[PostGIS] #5584: PostGIS Upgrade Issue
PostGIS trac at osgeo.org
Sat Nov 18 14:22:25 PST 2023
  Reporter:  rama          |      Owner:  strk
      Type:  defect        |     Status:  new
  Priority:  critical      |  Milestone:  PostGIS Packaging
 Component:  upgrade/soft  |    Version:  3.3.x
Resolution:                |   Keywords:  windows
Comment (by robe):
 Slight correction I forgot you already said you can't upgrade pgrouting,
 so yes the solution sadly is to
 DROP EXTENSION pgrouting; -- it will fail, not all the views it complains
 about, save the definitions and drop them
 CREATE EXTENSION pgrouting;
 -- recreate your views
 regarding Issue 1, I think we have a fix for this in upcoming PostGIS
 release.
 But what you said, change the ownership of the functions being complained
 about to postgres should work.
 A simpler solution, I think the check only complains if they owner of the
 function is not a super user.  So what you could try is make xyz a super
 user just before you run the upgrade.  You can get rid of the super user
 status after.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5584#comment:20>
