[SCM] PostGIS branch master updated. 3.4.0rc1-778-g5fefa43d3
Sat Nov 18 19:59:48 PST 2023
the project "PostGIS".
       via  5fefa43d3eca0808c09dd9332459c9f6b779586f (commit)
       via  bda254e5c62d43115d6cd0e66001aaf7b8ae650e (commit)
      from  f0c64c9504156a09fc7b993ca84654d67a5e0617 (commit)
revisions in full, below.
commit 5fefa43d3eca0808c09dd9332459c9f6b779586f
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Nov 18 22:59:08 2023 -0500
    Remove segment in polygon test for now
    until regress issue is resolved.
    References https://trac.osgeo.org/postgis/ticket/5612
    for PostGIS 3.5.0
diff --git a/sfcgal/regress/visibility.sql b/sfcgal/regress/visibility.sql
index 392bd40dd..91b04bfc7 100644
--- a/sfcgal/regress/visibility.sql
+++ b/sfcgal/regress/visibility.sql
@@ -1,4 +1,4 @@
 SELECT 'Visibility point in polygon', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0))', 'POINT(0.5 2.0)'), 2);
 SELECT 'Visibility point in polygon with hole', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0),(0.2 1.8,0.9 1.8,0.7 1.2,0.2 1.8))', 'POINT(0.5 2.0)'), 2);
-SELECT 'Visibility segment in polygon', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0))', 'POINT(1.0 2.0)', 'POINT(4.0 4.0)'), 2);
+--SELECT 'Visibility segment in polygon', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0))', 'POINT(1.0 2.0)', 'POINT(4.0 4.0)'), 2);
 SELECT 'Visibility segment in polygon with hole', ST_AsText(CG_Visibility('POLYGON((1.0 2.0,12.0 3.0,19.0 -2.0,12.0 6.0,14.0 14.0,9.0 5.0,1.0 2.0),(8.0 3.0,8.0 4.0,10.0 3.0,8.0 3.0),(10.0 6.0,11.0 7.0,11.0 6.0,10.0 6.0))', 'POINT(19.0 -2.0)', 'POINT(12.0 6.0)'), 2);
diff --git a/sfcgal/regress/visibility_expected b/sfcgal/regress/visibility_expected
index a42d87699..7ecc5da92 100644
--- a/sfcgal/regress/visibility_expected
+++ b/sfcgal/regress/visibility_expected
@@ -1,4 +1,3 @@
 Visibility point in polygon|POLYGON((3 2,1 2,0 4,0 0,3 2))
 Visibility point in polygon with hole|POLYGON((0 1.67,0.2 1.8,0.9 1.8,1.93 1.29,3 2,1 2,0 4,0 1.67))
-Visibility segment in polygon|POLYGON((1 2,0 4,0 0,4 0,4 4,1 2))
 Visibility segment in polygon with hole|POLYGON((19 -2,12 6,14 14,10.43 7.57,11 7,11 6,10 6,9.56 6,9 5,1 2,4.67 2.33,8 4,10 3,9.87 2.81,12 3,19 -2))
commit bda254e5c62d43115d6cd0e66001aaf7b8ae650e
Date:   Sat Nov 18 22:56:01 2023 -0500
    Fix generation of cg_visibility images.  References https://trac.osgeo.org/postgis/ticket/5612
diff --git a/doc/html/images/Makefile.in b/doc/html/images/Makefile.in
index 7483de7e7..8f33d0d24 100644
--- a/doc/html/images/Makefile.in
+++ b/doc/html/images/Makefile.in
@@ -38,6 +38,9 @@ STATIC_IMAGES_SRC = $(wildcard $(srcdir)/static/*.png $(srcdir)/static/*.gif)
 STATIC_IMAGES = $(subst $(srcdir)/static/,,$(STATIC_IMAGES_SRC))
 GENERATED_IMAGES= \
+  cg_visibility01.png \
+	cg_visibility02.png \
+	cg_visibility03.png \
 	de9im01.png \
 	de9im02.png \
 	st_alphashape01.png \
Summary of changes:
 doc/html/images/Makefile.in        | 3 +++
 sfcgal/regress/visibility.sql      | 2 +-
 sfcgal/regress/visibility_expected | 1 -
 3 files changed, 4 insertions(+), 2 deletions(-)
hooks/post-receive
