[SCM] PostGIS branch stable-3.1 updated. 3.1.9-19-g4e93a1a2a
Sun Nov 19 15:58:45 PST 2023
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  4e93a1a2aa8e51d0d8a56468a6d6a4e3eda004d7 (commit)
      from  cd8397da6834834d81b4e85775e4e1d21c093367 (commit)
revisions in full, below.
commit 4e93a1a2aa8e51d0d8a56468a6d6a4e3eda004d7
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Nov 19 18:58:39 2023 -0500
    Fix for docbook path. References #5616 for PostGIS 3.1.10
diff --git a/NEWS b/NEWS
index e25ad88c5..057bdd079 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.1.10
-2023/11/18
+2023/11/19
 * Bug Fixes *
   - #5568, Improve robustness of topology face split handling (Sandro Santilli)
@@ -10,6 +10,7 @@ PostGIS 3.1.10
   - #5385, Postgres malloc assertion fail when using pg_cancel_backend
            with ST_AsMVT (Regina Obe, Paul Ramsey)
  - Fix JsonB casting issue (Paul Ramsey)
+ - #5616, Fix to find docbook on newer docbook installs (Regina Obe)
 * Breaking Changes *
diff --git a/configure.ac b/configure.ac
index 3cad004d5..d6151e51f 100644
--- a/configure.ac
+++ b/configure.ac
@@ -224,6 +224,7 @@ if test "x$XSLBASE" = "x"; then
 	SEARCHPATH="
 		/usr/share/sgml/docbook/xsl-stylesheets
 		/usr/share/xml/docbook/stylesheet/docbook-xsl
+		/usr/share/xml/docbook/stylesheet/docbook-xsl-ns
 		/usr/share/xml/docbook/stylesheet/nwalsh
 		/usr/share/sgml/docbook/stylesheet/xsl/nwalsh
 		/opt/local/share/xsl/docbook-xsl
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 6d1f89090..f39f1a2b7 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -16,6 +16,7 @@
               <para><ulink url="https://trac.osgeo.org/postgis/ticket/5385">5385</ulink>, Postgres malloc assertion fail when using pg_cancel_backend
                         with ST_AsMVT (Regina Obe, Paul Ramsey)</para>
               <para>Fix JsonB casting issue (Paul Ramsey)</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5616">5616</ulink>,  Fix to find docbook on newer docbook installs (Regina Obe)</para>
         </simplesect>
     </sect1>
     <sect1>
Summary of changes:
 NEWS                  | 3 ++-
 configure.ac          | 1 +
 doc/release_notes.xml | 1 +
 3 files changed, 4 insertions(+), 1 deletion(-)
hooks/post-receive
