[SCM] PostGIS branch stable-3.3 updated. 3.3.4-34-gc4a9ca7ba
Sun Nov 19 20:53:01 PST 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  c4a9ca7ba0906964cc589c6114303876e4f03ca6 (commit)
       via  656329311e49e6d5f9d53c15dd28ae207080ebde (commit)
       via  645c0b9a7a60eb3c66f26b4056dd13227698aa3c (commit)
      from  3da889ad692cdc4128745d0db7854b1f8ee15476 (commit)
revisions in full, below.
commit c4a9ca7ba0906964cc589c6114303876e4f03ca6
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Nov 19 23:51:32 2023 -0500
    Prep for 3.3.5 release
diff --git a/README.postgis b/README.postgis
index 8ce440524..d58ad6dac 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.3.3
-:Date: 2023-05-29
+:Version: 3.3.5
+:Date: 2023-11-19
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 071975f0b..db92085a9 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=5dev
+POSTGIS_MICRO_VERSION=5
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/postgis.xml b/doc/postgis.xml
index b22736150..df8fbf18b 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -14,7 +14,7 @@
 <!ENTITY last_proj_release_version "9.0.1">
 <!ENTITY last_geos_release_version "3.11.1">
 <!ENTITY min_postgres_version "11">
-<!ENTITY max_postgres_version "15">
+<!ENTITY max_postgres_version "16">
 <!ENTITY introduction SYSTEM "introduction.xml">
 <!ENTITY installation SYSTEM "installation.xml">
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 143899d92..02909ccdf 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,8 +2,59 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+        <sect1>
+            <title>PostGIS 3.3.5</title>
+            <para>2023/11/19</para>
+            <para>This version requires PostgreSQL 11-16, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+
+ (and ST_MakeValid enhancements with 3.10+),
+Proj 6.1+, and PostgreSQL 15+.</para>
+            <simplesect><title>Bug Fixes and Enhancements</title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5598">5598</ulink>, Fix restore of 3.3 dumps (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5568">5568</ulink>, Improve robustness of topology face split handling (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5548">5548</ulink>, Fix box-filtered validity check of topologies with edge-less faces
+                          (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5442">5442</ulink>, <ulink url="https://trac.osgeo.org/postgis/ticket/5525">5525</ulink>, [postgis_tiger_geocoder,postgis_topology]
+                          Database search_path does not do
+                          what it intends to do (Jelte Fennema, Sandro Santilli, Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5494">5494</ulink>, Fix double-upgrade with view using st_dwithin(text, ...)
+                <para>Fix JsonB casting issue (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5616">5616</ulink>, Fix to find docbook on newer docbook installs (Regina Obe)</para>
+                </simplesect>
+        </sect1>
+        <sect1>
+            <title>PostGIS 3.3.4</title>
+            <para>2023/07/28</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5450">5450</ulink>, Fix macro expansion recursion on powerpc architectures.
+                        (Bas Couwenberg)</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5395">5395</ulink>, [postgis_topology] Allow unprivileged user dump
+                        of database with topology enabled (Sandro Santilli)</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5394">5394</ulink>, [postgis_topology] Improve robustness of finding
+                        distinct vertices in topology edges (Sandro Santilli)</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5403">5403</ulink>, [postgis_topology] Fix ValidateTopology(bbox) without
+                        topology in search_path (Sandro Santilli)</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5410">5410</ulink>, [postgis_raster] ST_Value bilinear resample,
+                        don't throw an error if Band has no NODATA value
+                        (Regina Obe)</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5385">5385</ulink>, Postgres malloc assertion fail when
+                        using pg_cancel_backend with ST_AsMVT
+                        (Regina Obe, Paul Ramsey)</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5452">5452</ulink>, Updated README.postgis for apt-based systems
+                        (Jelte Fennema)</para>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5385">5385</ulink>, Take out interruptability of ST_AsMVT
+                          as it causes backend crash under intense conditions
+            </simplesect>
+        </sect1>
         <sect1>
             <title>PostGIS 3.3.3</title>
+            <para>2023/05/29</para>
             <para>This version requires PostgreSQL 11-16beta1, GEOS 3.6 or higher, and Proj 4.9+
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 1f2806cd1..59317bb61 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -69,6 +69,7 @@ UPGRADEABLE_VERSIONS = \
 	3.0.7 \
 	3.0.8 \
 	3.0.9 \
+	3.0.10 \
 	3.1.0 \
 	3.1.1 \
 	3.1.2	\
@@ -79,15 +80,16 @@ UPGRADEABLE_VERSIONS = \
 	3.1.7 \
 	3.1.8 \
 	3.1.9 \
+	3.1.10 \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
 	3.2.3 \
 	3.2.4 \
 	3.2.5 \
+	3.2.6 \
 	3.3.0 \
 	3.3.1 \
 	3.3.2 \
 	3.3.3 \
-	3.3.4 \
-	3.3.5dev
+	3.3.4
commit 656329311e49e6d5f9d53c15dd28ae207080ebde
Date:   Sun Nov 19 23:50:35 2023 -0500
    Closes #5616 for PostGIS 3.3.5
diff --git a/configure.ac b/configure.ac
index d7e821667..93e80a715 100644
--- a/configure.ac
+++ b/configure.ac
@@ -259,6 +259,7 @@ if test "x$XSLBASE" = "x"; then
 	SEARCHPATH="
 		/usr/share/sgml/docbook/xsl-stylesheets
 		/usr/share/xml/docbook/stylesheet/docbook-xsl
+		/usr/share/xml/docbook/stylesheet/docbook-xsl-ns
 		/usr/share/xml/docbook/stylesheet/nwalsh
 		/usr/share/sgml/docbook/stylesheet/xsl/nwalsh
 		/opt/local/share/xsl/docbook-xsl
commit 645c0b9a7a60eb3c66f26b4056dd13227698aa3c
Date:   Sun Nov 19 23:07:31 2023 -0500
    Don't use pg_file_settings unless person creating extension
    is a super user
    References #5525 for PostGIS 3.3.5
diff --git a/NEWS b/NEWS
index c8471451b..cee2f638b 100644
--- a/NEWS
+++ b/NEWS
@@ -1,17 +1,22 @@
-PostGIS 3.3.5dev
-YYYY/MM/DD
+PostGIS 3.3.5
+2023/11/19
+This version requires PostgreSQL 11-16, GEOS 3.6 or higher, and Proj 4.9+
 * Bug Fixes and Enhancements *
  - #5598, Fix restore of 3.3 dumps (Sandro Santilli)
  - #5568, Improve robustness of topology face split handling (Sandro Santilli)
  - #5548, Fix box-filtered validity check of topologies with edge-less faces
           (Sandro Santilli)
- - #5442, [postgis_tiger_geocoder,postgis_topology]
+ - #5442,#5525 [postgis_tiger_geocoder,postgis_topology]
-          what it intends to do (Jelte Fennema)
  - #5494, Fix double-upgrade with view using st_dwithin(text, ...)
           (Sandro Santilli)
  - Fix JsonB casting issue (Paul Ramsey)
+ - #5616, Fix to find docbook on newer docbook installs (Regina Obe)
 PostGIS 3.3.4
diff --git a/libpgcommon/sql/AddToSearchPath.sql.inc b/libpgcommon/sql/AddToSearchPath.sql.inc
index c3746c522..a5e02279e 100644
--- a/libpgcommon/sql/AddToSearchPath.sql.inc
+++ b/libpgcommon/sql/AddToSearchPath.sql.inc
@@ -29,7 +29,8 @@ BEGIN
 	RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
-	IF var_cur_search_path IS NULL THEN
+	-- only run this test if person creating the extension is a super user
+	IF var_cur_search_path IS NULL AND (SELECT rolsuper FROM pg_roles where rolname = CURRENT_USER) THEN
 		SELECT setting
 		INTO var_cur_search_path
 		FROM pg_file_settings
Summary of changes:
 NEWS                                    | 13 ++++++---
 README.postgis                          |  4 +--
 Version.config                          |  2 +-
 configure.ac                            |  1 +
 doc/postgis.xml                         |  2 +-
 doc/release_notes.xml                   | 51 +++++++++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk      |  6 ++--
 libpgcommon/sql/AddToSearchPath.sql.inc |  3 +-
 8 files changed, 71 insertions(+), 11 deletions(-)
hooks/post-receive
