[PostGIS] #5525: ERROR: permission denied for view pg_file_settings
PostGIS trac at osgeo.org
Sun Nov 19 21:17:15 PST 2023
  Reporter:  robe    |      Owner:  strk
      Type:  defect  |     Status:  closed
  Priority:  medium  |  Milestone:  PostGIS 3.3.5
 Component:  build   |    Version:  3.3.x
Resolution:  fixed   |   Keywords:  pgextwlist
Changes (by Regina Obe <lr@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"ef657b983be3707265fe29fe9364c3779742f0db/git" ef657b9/git]:
 {{{#!CommitTicketReference repository="git"
 revision="ef657b983be3707265fe29fe9364c3779742f0db"
 Regression failure when installed by non-superuser
 Closes #5525 for PostGIS 3.4.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5525#comment:25>
