[SCM] PostGIS branch stable-3.3 updated. 3.3.5-1-g82299afb6
Sun Nov 19 21:31:16 PST 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  82299afb6bd499ec721e3df7870ad6c0d7f51f2d (commit)
       via  97969989e8a1cbfa424b305f5c99c157921c9650 (commit)
      from  c4a9ca7ba0906964cc589c6114303876e4f03ca6 (commit)
revisions in full, below.
commit 82299afb6bd499ec721e3df7870ad6c0d7f51f2d
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 20 00:31:02 2023 -0500
    Flip to 3.3.6dev milestone
diff --git a/NEWS b/NEWS
index a2aa3951b..d0d85c978 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,12 @@
+PostGIS 3.3.6dev
+xxxx/xx/xx
+This version requires PostgreSQL 11-16, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+
+ (and ST_MakeValid enhancements with 3.10+),
+Proj 6.1+, and PostgreSQL 15+.
+* Bug Fixes and Enhancements *
 PostGIS 3.3.5
 2023/11/19
diff --git a/Version.config b/Version.config
index db92085a9..39d3320e7 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=5
+POSTGIS_MICRO_VERSION=6dev
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 59317bb61..1b04e030d 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -92,4 +92,5 @@ UPGRADEABLE_VERSIONS = \
 	3.3.1 \
 	3.3.2 \
 	3.3.3 \
-	3.3.4
+	3.3.4 \
+	3.3.5
commit 97969989e8a1cbfa424b305f5c99c157921c9650
Date:   Mon Nov 20 00:28:27 2023 -0500
    Fix regression failures with GEOS 3.13. Closes #5605 for PostGIS 3.3.5
index cee2f638b..a2aa3951b 100644
--- a/NEWS
+++ b/NEWS
@@ -17,6 +17,7 @@ Proj 6.1+, and PostgreSQL 15+.
           (Sandro Santilli)
  - Fix JsonB casting issue (Paul Ramsey)
  - #5616, Fix to find docbook on newer docbook installs (Regina Obe)
+ - #5605, Fix regression failure with GEOS 3.13, main branch (Regina Obe)
 PostGIS 3.3.4
diff --git a/regress/core/regress_buffer_params.sql b/regress/core/regress_buffer_params.sql
index cb239341d..dae12b4fd 100644
--- a/regress/core/regress_buffer_params.sql
+++ b/regress/core/regress_buffer_params.sql
@@ -6,14 +6,14 @@
 -- Ouput is snapped to grid to account for small floating numbers
 -- differences between architectures
 SELECT 'point quadsegs=2', ST_AsText( ST_SnapToGrid(st_buffer('POINT(0 0)', 1, 'quad_segs=2'), 0.0001), 4);
-SELECT 'line quadsegs=2', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 3);
-SELECT 'line quadsegs=2 endcap=flat', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=flat'), 5);
-SELECT 'line quadsegs=2 endcap=butt', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=butt'), 5);
-SELECT 'line quadsegs=2 endcap=square', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=square'), 5);
+SELECT 'line quadsegs=2', ST_AsText(ST_Normalize(ST_SnapToGrid(ST_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 0.0001)), 3);
+SELECT 'line quadsegs=2 endcap=flat', ST_AsText(ST_SnapToGrid(ST_Buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=flat'),0.0001), 5);
+SELECT 'line quadsegs=2 endcap=butt', ST_AsText(ST_Normalize(ST_Buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=butt')), 5);
+SELECT 'line quadsegs=2 endcap=square', ST_AsText(ST_Normalize(ST_Buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=square')), 5);
 --SELECT 'line join=mitre mitre_limit=1.0 side=both', ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'join=mitre mitre_limit=1.0 side=both'), 5);
-SELECT 'line side=left',ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=left'), 5);
-SELECT 'line side=right',ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=right'),5);
-SELECT 'line side=left join=mitre',ST_AsText(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=left join=mitre'),5);
+SELECT 'line side=left',ST_AsText(ST_Normalize(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=left')), 5);
+SELECT 'line side=right',ST_AsText(ST_Normalize(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=right')),5);
+SELECT 'line side=left join=mitre',ST_AsText(ST_Normalize(ST_Buffer('LINESTRING(50 50,150 150,150 50)',10,'side=left join=mitre')),5);
 SELECT 'poly quadsegs=2 join=round', ST_AsText(ST_Normalize(st_buffer(
 	'POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))',
 	2, 'quad_segs=2 join=round'
diff --git a/regress/core/regress_buffer_params_expected b/regress/core/regress_buffer_params_expected
index d32aa2507..c882917fa 100644
--- a/regress/core/regress_buffer_params_expected
+++ b/regress/core/regress_buffer_params_expected
@@ -1,11 +1,11 @@
 point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,0 -1,-0.7071 -0.7071,-1 0,-0.7071 0.7071,0 1,0.7071 0.7071,1 0))
-line quadsegs=2|POLYGON((10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0 -2,-1.414 -1.414,-2 2.449e-16,-1.414 1.414,0 2,10 2))
+line quadsegs=2|POLYGON((-2 0,-1.414 1.414,0 2,10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0 -2,-1.414 -1.414,-2 0))
 line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
-line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
-line quadsegs=2 endcap=square|POLYGON((10 2,12 2,12 -2,0 -2,-2 -2,-2 2,10 2))
-line side=left|POLYGON((150 50,150 150,50 50,42.92893 57.07107,142.92893 157.07107,144.4443 158.3147,146.17317 159.2388,148.0491 159.80785,150 160,151.9509 159.80785,153.82683 159.2388,155.5557 158.3147,157.07107 157.07107,158.3147 155.5557,159.2388 153.82683,159.80785 151.9509,160 150,160 50,150 50))
+line quadsegs=2 endcap=butt|POLYGON((0 -2,0 2,10 2,10 -2,0 -2))
+line quadsegs=2 endcap=square|POLYGON((-2 -2,-2 2,10 2,12 2,12 -2,0 -2,-2 -2))
+line side=left|POLYGON((42.92893 57.07107,142.92893 157.07107,144.4443 158.3147,146.17317 159.2388,148.0491 159.80785,150 160,151.9509 159.80785,153.82683 159.2388,155.5557 158.3147,157.07107 157.07107,158.3147 155.5557,159.2388 153.82683,159.80785 151.9509,160 150,160 50,150 50,150 150,50 50,42.92893 57.07107))
 line side=right|POLYGON((50 50,150 150,150 50,140 50,140 125.85786,57.07107 42.92893,50 50))
-line side=left join=mitre|POLYGON((150 50,150 150,50 50,42.92893 57.07107,160 174.14214,160 50,150 50))
+line side=left join=mitre|POLYGON((42.92893 57.07107,160 174.14214,160 50,150 50,150 150,50 50,42.92893 57.07107))
 poly quadsegs=2 join=round|POLYGON((-2 0,-2 10,-1.41421 11.41421,0 12,10 12,11.41421 11.41421,12 10,12 0,11.41421 -1.41421,10 -2,0 -2,-1.41421 -1.41421,-2 0))
 poly quadsegs=2 join=bevel|POLYGON((-2 0,-2 10,0 12,10 12,12 10,12 0,10 -2,0 -2,-2 0))
 poly boundary rhr side=left|POLYGON((10 20,10 50,50 50,50 10,20 10,20 20,10 20),(20 20,40 20,40 40,20 40,20 20))
Summary of changes:
 NEWS                                        | 10 ++++++++++
 Version.config                              |  2 +-
 extensions/upgradeable_versions.mk          |  3 ++-
 regress/core/regress_buffer_params.sql      | 14 +++++++-------
 regress/core/regress_buffer_params_expected | 10 +++++-----
 5 files changed, 25 insertions(+), 14 deletions(-)
hooks/post-receive
