[PostGIS] #5565: ST_Snap doesn't maintain the input type
PostGIS trac at osgeo.org
Sun Nov 19 22:22:03 PST 2023
  Reporter:  lkajan   |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  3.4.x
Resolution:  wontfix  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
 * milestone:  PostGIS 3.4.1 => PostGIS GEOS
Comment:
 I don't think ST_Snap was designed to work with z coordinates and on tok
 of that in some of your examples you are mixing dimensions.  Regardless
 most of the logic of ST_Snap resides in GEOS so wouldn't be fixed in
 PostGIS.
 @pramsey I'm going to close this out as a won't fix.  Feel free to do
 something about it if you want.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5565#comment:1>
