[SCM] PostGIS branch master updated. 3.4.0rc1-787-g8af35118b
Sun Nov 19 22:50:34 PST 2023
the project "PostGIS".
       via  8af35118bd1b1524945085d6500584b7e2b8debd (commit)
       via  d1abcc12826e00f80a17ef0928f8cf825d0fadee (commit)
       via  22937a5ba61be60210bd5397d877e24a415a0901 (commit)
      from  966f687e50fed58c16ac856a67f87b7c390bb859 (commit)
revisions in full, below.
commit 8af35118bd1b1524945085d6500584b7e2b8debd
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 20 01:50:21 2023 -0500
    Fix ST_Project lon,lon issue. References #5581 for PostGIS 3.5.0
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 3469d29d7..3e255f9ec 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -2487,7 +2487,7 @@ project_pt(const POINT2D *P, double distance, double azimuth, POINT2D *R)
 	double dx = cos(slope) * distance;
 	double dy = sin(slope) * distance;
 	R->x = P->x + dx;
-	R->y = P->x + dy;
+	R->y = P->y + dy;
 	return LW_TRUE;
commit d1abcc12826e00f80a17ef0928f8cf825d0fadee
Date:   Mon Nov 20 01:17:03 2023 -0500
    Regression failure when installed by non-superuser
    Closes #5525 for PostGIS 3.5.0
diff --git a/libpgcommon/sql/AddToSearchPath.sql.inc b/libpgcommon/sql/AddToSearchPath.sql.inc
index c3746c522..a5e02279e 100644
--- a/libpgcommon/sql/AddToSearchPath.sql.inc
+++ b/libpgcommon/sql/AddToSearchPath.sql.inc
@@ -29,7 +29,8 @@ BEGIN
 	RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
-	IF var_cur_search_path IS NULL THEN
+	-- only run this test if person creating the extension is a super user
+	IF var_cur_search_path IS NULL AND (SELECT rolsuper FROM pg_roles where rolname = CURRENT_USER) THEN
 		SELECT setting
 		INTO var_cur_search_path
 		FROM pg_file_settings
commit 22937a5ba61be60210bd5397d877e24a415a0901
Date:   Mon Nov 20 01:14:55 2023 -0500
    Fix ST_LineExtend example closes #5594 for PostGIS 3.5.0
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 69ac545d0..6f524ec14 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1278,9 +1278,9 @@ SELECT ST_AsText(ST_Multi('POLYGON ((10 30, 30 30, 30 10, 10 10, 10 30))'));
             <title>Example: Projected point at 100,000 meters and bearing 45 degrees </title>
 <programlisting>
-SELECT ST_AsText(ST_Project('POINT(0 0)'::geography, 100000, radians(45.0)));
+SELECT ST_AsText(ST_LineExtend('LINESTRING(0 0, 0 10)'::geometry, 5, 6));
- POINT(0.635231029125537 0.639472334729198)
+LINESTRING(0 -6,0 0,0 10,0 15)
 </programlisting>
           </refsection>
Summary of changes:
 doc/reference_editor.xml                | 4 ++--
 liblwgeom/measures.c                    | 2 +-
 libpgcommon/sql/AddToSearchPath.sql.inc | 3 ++-
 3 files changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
