[SCM] PostGIS branch master updated. 3.4.0rc1-789-gf0643233c
Mon Nov 20 00:05:42 PST 2023
the project "PostGIS".
       via  f0643233c02e31ff98de3b8ec6c4b9670500ce06 (commit)
       via  28d7f6f9062cd7e3dbfac870160c6f1bbe0efdec (commit)
      from  8af35118bd1b1524945085d6500584b7e2b8debd (commit)
revisions in full, below.
commit f0643233c02e31ff98de3b8ec6c4b9670500ce06
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 20 02:35:51 2023 -0500
    Remove invalid note about ST_SetBandPath.
    References #5609 for PostGIS 3.5.0
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 8216d600a..b0a33b1b6 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -7709,12 +7709,6 @@ select st_bandisnodata(rast, 1) from dummy_rast where rid = 1; -- Expected true
                     </para>
                 </note>
-                <note>
-                    <para>
-                        Internally, this method replaces the PostGIS raster's band at index <varname>band</varname> with a new band instead of updating the existing path information.
-                    </para>
-                </note>
                 <para role="availability" conformance="2.5.0">Availability: 2.5.0</para>
             </refsection>
commit 28d7f6f9062cd7e3dbfac870160c6f1bbe0efdec
Date:   Mon Nov 20 02:08:58 2023 -0500
    Upgrade default geos for debbie
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 47f09f9b9..b7e52e5ad 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -12,7 +12,7 @@ export MSYS2_ARG_CONV_EXCL=/config/tags
 export XML_CATALOG_FILES="/projects/docbook/docbook-5.0.1/catalog.xml"
 if  [[ "${OVERRIDE}" == '' ]] ; then
-	export GEOS_VER=3.12.0
+	export GEOS_VER=3.13
 	export GDAL_VER=3.7.1
 	export PROJ_VER=8.2.1
 	export SFCGAL_VER=1.5.0
Summary of changes:
 ci/winnie/winnie_common.sh | 2 +-
 doc/reference_raster.xml   | 6 ------
 2 files changed, 1 insertion(+), 7 deletions(-)
hooks/post-receive
