[SCM] PostGIS branch master updated. 3.4.0rc1-791-g4e095177d
Tue Nov 21 20:24:32 PST 2023
the project "PostGIS".
       via  4e095177d8515b17897bcd70f33ad870746303d4 (commit)
      from  c806103c878764046c8f1c73392973fadde0f007 (commit)
revisions in full, below.
commit 4e095177d8515b17897bcd70f33ad870746303d4
Author: Weblate <noreply at weblate.org>
Date:   Wed Nov 22 04:21:50 2023 +0000
    Update translation files
    Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index be47bda3f..26078fd23 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-11-14 05:23+0000\n"
+"POT-Creation-Date: 2023-11-22 04:19+0000\n"
 "PO-Revision-Date: 2023-09-22 19:23+0000\n"
 "Last-Translator: Anonymous <noreply at weblate.org>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -8960,18 +8960,12 @@ msgid "Regina Obe"
 msgstr "Regina Obe"
 #. Tag: para
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
-"Buildbot Maintenance, Windows production and experimental builds, "
+"CI and website maintenance, Windows production and experimental builds, "
 "documentation, alignment of PostGIS with PostgreSQL releases, X3D support, "
 "TIGER geocoder support, management functions."
 msgstr ""
-"Buildbot Wartung, Kompilierung produktiver und experimenteller "
-"Softwarepakete für Windows, Abgleich von PostGIS mit den PostgreSQL "
-"Releases, allgemeine Unterstützung von Anwendern auf der PostGIS Newsgroup, "
-"Mitarbeit an X3D, Tiger Geokodierer, an Funktionen zur Verwaltung von "
-"Geometrien; Smoke testing neuer Funktionalität und wichtige Änderungen am "
-"Code."
 #. Tag: term
 #, no-c-format
@@ -8979,14 +8973,11 @@ msgid "Darafei Praliaskouski"
 msgstr "Darafei Praliaskouski"
 #. Tag: para
+#, no-c-format
 msgid ""
 "Index improvements, bug fixing and geometry/geography function improvements, "
-"SFCGAL, raster, GitHub curation, and bot maintenance."
+"SFCGAL, raster, GitHub curation, and ci maintenance."
 msgstr ""
-"Index Optimierung, Bugfixes und Verbesserungen von Funktionen für den "
-"geometrischen/geographischer Datentyp, GitHub Verwalter und Wartung des "
-"Travis Bot."
 #. Tag: term
 #, no-c-format
@@ -9015,17 +9006,12 @@ msgid "Sandro Santilli"
 msgstr "Sandro Santilli"
 #. Tag: para
+#, no-c-format
 msgid ""
-"Bug fixes and maintenance, buildbot maintenance, git mirror management, "
-"management functions, integration of new GEOS functionality and alignment "
-"with GEOS releases, topology support, and raster framework and low level API "
-"functions."
+"Bug fixes and maintenance, ci maintenance, git mirror management, management "
+"functions, integration of new GEOS functionality and alignment with GEOS "
+"releases, topology support, and raster framework and low level API functions."
 msgstr ""
-"Bugfixes, Wartung, Git Mirrors Management und Integration neuer GEOS-"
-"Funktionalitäten, sowie Abstimmung mit den GEOS Versionen, "
-"Topologieunterstützung, Raster Grundstruktur und Funktionen der Low-Level-"
-"API."
 #. Tag: title
 #, no-c-format
@@ -9048,6 +9034,16 @@ msgstr ""
 "Distanz und Funktionen zu räumlichen Beziehungen), Tiny WKB Ausgabeformat "
 "(TWKB) (in Entwicklung) und allgemeine Unterstützung von Anwendern."
+#. Tag: term
+#, no-c-format
+msgid "Loïc Bartoletti"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "SFCGAL enhancments and maintenance and ci support"
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -9081,10 +9077,9 @@ msgstr "Björn Harrtell"
 #. Tag: para
 #, no-c-format
 msgid ""
-"MapBox Vector Tile and GeoBuf functions. Gogs testing and GitLab "
-"experimentation."
+"MapBox Vector Tile, GeoBuf, and Flatgeobuf functions. Gitea testing and "
+"GitLab experimentation."
 msgstr ""
-"MapBox Vector Tile und GeoBuf Funktionen. Gogs Tests und GitLab Experimente."
 #. Tag: term
 #, no-c-format
@@ -9605,11 +9600,6 @@ msgstr ""
 msgid "Leo Hsu"
 msgstr ""
-#. Tag: member
-#, no-c-format
-msgid "Loïc Bartoletti"
-msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "Loic Dachary"
@@ -10782,15 +10772,6 @@ msgid ""
 "function only available if PostGIS compiled with SFCGAL support."
 msgstr ""
-#. Tag: simpara
-#, no-c-format
-msgid ""
-"A <inlinemediaobject><imageobject><imagedata fileref=\"images/"
-"matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject> means the "
-"function support is provided by SFCGAL if PostGIS compiled with SFCGAL "
-"support, otherwise GEOS/built-in support."
-msgstr ""
 #. Tag: simpara
 #, no-c-format
 msgid "geom - Basic 2D geometry support (x,y)."
@@ -30564,17 +30545,6 @@ msgstr ""
 "Dateisystemänderungen vorgesehen, bei denen der externe Raster bestehen "
 "bleibt."
-#. Tag: para
-#, no-c-format
-msgid ""
-"Internally, this method replaces the PostGIS raster's band at index "
-"<varname>band</varname> with a new band instead of updating the existing "
-"path information."
-msgstr ""
-"Intern wird bei dieser Methode das PostGIS Raster Band mit dem Index "
-"<varname>band</varname> durch ein neues Band ersetzt, ohne dass die "
-"existierende Pfadinformation aktualisiert wird."
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"RT_ST_SetBandIndex\"/>"
@@ -30607,6 +30577,17 @@ msgstr ""
 "dem PostGIS Raster nicht überprüft. Dieser Modus ist für das Verschieben von "
 "Bändern in einer externen Rasterdatei vorgesehen."
+#. Tag: para
+#, no-c-format
+msgid ""
+"Internally, this method replaces the PostGIS raster's band at index "
+"<varname>band</varname> with a new band instead of updating the existing "
+"path information."
+msgstr ""
+"Intern wird bei dieser Methode das PostGIS Raster Band mit dem Index "
+"<varname>band</varname> durch ein neues Band ersetzt, ohne dass die "
+"existierende Pfadinformation aktualisiert wird."
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"RT_ST_SetBandPath\"/>"
@@ -37666,6 +37647,27 @@ msgstr ""
 msgid ", <xref linkend=\"ST_DelaunayTriangles\"/>"
 msgstr ", <xref linkend=\"ST_LineSubstring\"/>"
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Compute a visibility polygon from a point or a segment in a polygon geometry"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.5.0 - requires SFCGAL >= 1.5.0."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Visibility from the point"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Visibility from the segment"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -37713,11 +37715,6 @@ msgid ""
 "respect to the optimal number."
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 3.5.0 - requires SFCGAL >= 1.5.0."
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -45489,6 +45486,48 @@ msgstr ""
 msgid "Supports geography"
 msgstr ""
+#, fuzzy, no-c-format
+#~ msgid ""
+#~ "Buildbot Maintenance, Windows production and experimental builds, "
+#~ "documentation, alignment of PostGIS with PostgreSQL releases, X3D "
+#~ "support, TIGER geocoder support, management functions."
+#~ msgstr ""
+#~ "Buildbot Wartung, Kompilierung produktiver und experimenteller "
+#~ "Softwarepakete für Windows, Abgleich von PostGIS mit den PostgreSQL "
+#~ "Releases, allgemeine Unterstützung von Anwendern auf der PostGIS "
+#~ "Newsgroup, Mitarbeit an X3D, Tiger Geokodierer, an Funktionen zur "
+#~ "Verwaltung von Geometrien; Smoke testing neuer Funktionalität und "
+#~ "wichtige Änderungen am Code."
+#~ msgid ""
+#~ "Index improvements, bug fixing and geometry/geography function "
+#~ "improvements, SFCGAL, raster, GitHub curation, and bot maintenance."
+#~ msgstr ""
+#~ "Index Optimierung, Bugfixes und Verbesserungen von Funktionen für den "
+#~ "geometrischen/geographischer Datentyp, GitHub Verwalter und Wartung des "
+#~ "Travis Bot."
+#~ msgid ""
+#~ "Bug fixes and maintenance, buildbot maintenance, git mirror management, "
+#~ "management functions, integration of new GEOS functionality and alignment "
+#~ "with GEOS releases, topology support, and raster framework and low level "
+#~ "API functions."
+#~ msgstr ""
+#~ "Bugfixes, Wartung, Git Mirrors Management und Integration neuer GEOS-"
+#~ "Funktionalitäten, sowie Abstimmung mit den GEOS Versionen, "
+#~ "Topologieunterstützung, Raster Grundstruktur und Funktionen der Low-Level-"
+#~ "API."
+#, no-c-format
+#~ msgid ""
+#~ "MapBox Vector Tile and GeoBuf functions. Gogs testing and GitLab "
+#~ "experimentation."
+#~ msgstr ""
+#~ "MapBox Vector Tile und GeoBuf Funktionen. Gogs Tests und GitLab "
+#~ "Experimente."
 #, no-c-format
 #~ msgid "&database_tuning;"
 #~ msgstr "&database_tuning;"
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index a5e3c6bf7..ac2dced88 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
 msgstr ""
 "Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -8077,13 +8077,10 @@ msgstr "Regina Obe"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
-"Buildbot Mantenimiento, producción de Windows y construcciones "
-"experimentales, documentación, alineación de PostGIS con las versiones de "
-"PostgreSQL, soporte X3D, soporte TIGER geocoder, funciones de gestión."
 #. Tag: term
 #, no-c-format
@@ -8094,11 +8091,8 @@ msgstr "Darafei Praliaskouski"
 #, no-c-format
 msgid ""
 msgstr ""
-"Mejoras en el índice, corrección de errores y mejoras en las funciones de "
-"geometría/geografía, SFCGAL, raster, curación en GitHub y mantenimiento del "
-"bot."
 #. Tag: term
 #, no-c-format
@@ -8129,15 +8123,10 @@ msgstr "Sandro Santilli"
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
-"Corrección y mantenimiento de errores, mantenimiento de buildbot, gestión de "
-"réplicas de git, funciones de gestión, integración de nuevas funcionalidades "
-"de GEOS y alineación con las versiones de GEOS, soporte de topología, y "
-"marco de rasterización y funciones API de bajo nivel."
 #. Tag: title
 #, no-c-format
@@ -8160,6 +8149,16 @@ msgstr ""
 "de distancia y relación 3D), formato de salida Tiny WKB (TWKB) y asistencia "
 "general al usuario."
+#. Tag: term
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -8192,11 +8191,9 @@ msgstr "Björn Harrtell"
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
-"Funciones MapBox Vector Tile y GeoBuf. Pruebas con Gogs y experimentación "
-"con GitLab."
 #. Tag: term
 #, no-c-format
@@ -8723,11 +8720,6 @@ msgstr ""
 msgid "Leo Hsu"
 msgstr ""
-#. Tag: member
-#, no-c-format
-msgstr ""
 #. Tag: member
 #, no-c-format
@@ -9877,15 +9869,6 @@ msgid ""
 msgstr ""
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: simpara
 #, no-c-format
@@ -27390,14 +27373,6 @@ msgid ""
 "where the external raster resides."
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -27424,6 +27399,14 @@ msgid ""
 "around in the external raster file."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -33212,6 +33195,27 @@ msgstr ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -33259,11 +33263,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -40936,6 +40935,45 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Buildbot Mantenimiento, producción de Windows y construcciones "
+#~ "experimentales, documentación, alineación de PostGIS con las versiones de "
+#~ "PostgreSQL, soporte X3D, soporte TIGER geocoder, funciones de gestión."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Mejoras en el índice, corrección de errores y mejoras en las funciones de "
+#~ "geometría/geografía, SFCGAL, raster, curación en GitHub y mantenimiento "
+#~ "del bot."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Corrección y mantenimiento de errores, mantenimiento de buildbot, gestión "
+#~ "de réplicas de git, funciones de gestión, integración de nuevas "
+#~ "funcionalidades de GEOS y alineación con las versiones de GEOS, soporte "
+#~ "de topología, y marco de rasterización y funciones API de bajo nivel."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Funciones MapBox Vector Tile y GeoBuf. Pruebas con Gogs y experimentación "
+#~ "con GitLab."
 #, no-c-format
 #~ msgid "PostGIS Administration"
 #~ msgstr "Administración de PostGIS"
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 57900c9ef..a5901e62b 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-14 20:23+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -9379,13 +9379,10 @@ msgstr "Regina Obe"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
-"Maintenance du robot de build, Build de production et expérimental pour "
-"Windows, documentation, Alignement de PostGIS avec les publications "
-"PostgreSQL, support X3D, support du géocoder TIGER, fonctions de gestion."
 #. Tag: term
 #, no-c-format
@@ -9396,11 +9393,8 @@ msgstr "Darafei Praliaskouski"
 #, no-c-format
 msgid ""
 msgstr ""
-"Améliorations des index, correction de bugs et améliorations des fonctions "
-"geometry/geography, SFCGAL, raster, nettoyage de GitHub, maintenance du "
-"robot de build."
 #. Tag: term
 #, no-c-format
@@ -9430,15 +9424,10 @@ msgstr "Sandro Santilli"
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
-"Maintenance et correction de bugs, maintenance du robot de build, gestion du "
-"miroir git, fonctions de gestions, intégration des fonctionnalités GEOS et "
-"alignement avec les publications GEOS, support des topologies, raster et "
-"fonctions de l'API bas-niveau."
 #. Tag: title
 #, no-c-format
@@ -9461,6 +9450,16 @@ msgstr ""
 "distance 3D et relations), format de sortie Tiny WKB (TWKB) et support "
 "utilisateur"
+#. Tag: term
+#, no-c-format
+msgstr "Loïc Bartoletti"
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -9493,11 +9492,9 @@ msgstr "Björn Harrtell"
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
-"Fonctions MapBox Vector Tile et GeoBuf. Tests Gogs et expérimentations "
-"GitLab."
 #. Tag: term
 #, no-c-format
@@ -10020,11 +10017,6 @@ msgstr "Lars Roessiger"
 msgid "Leo Hsu"
 msgstr "Leo Hsu"
-#. Tag: member
-#, no-c-format
-msgstr "Loïc Bartoletti"
 #. Tag: member
 #, no-c-format
@@ -11267,19 +11259,6 @@ msgstr ""
 "que la fonction n'est disponible que si PostGIS a été compilé avec le "
 "support SFCGAL."
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
-"Un <inlinemediaobject><imageobject><imagedata fileref=\"images/"
-"matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject> signifie "
-"que le support de la fonction est fourni par SFCGAL si PostGIS a été compilé "
-"avec le support SFCGAL, sinon le support GEOS/intégré."
 #. Tag: simpara
 #, no-c-format
@@ -32730,17 +32709,6 @@ msgstr ""
 "fichier raster externe et le raster PostGIS. Ce mode est prévu pour les "
 "changements sur le système de fichiers où réside le raster externe."
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
-"En interne, cette méthode remplacement la bande du raster PostGIS à l'index "
-"<varname>band</varname> avec la nouvelle bande, au lieu de mettre à jour les "
-"informations de chemin existantes."
 #. Tag: para
 #, no-c-format
@@ -32773,6 +32741,17 @@ msgstr ""
 "fichier raster externe et le raster PostGIS. Ce mode est destiné aux cas où "
 "les bandes sont déplacées dans le fichier raster externe."
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+"En interne, cette méthode remplacement la bande du raster PostGIS à l'index "
+"<varname>band</varname> avec la nouvelle bande, au lieu de mettre à jour les "
+"informations de chemin existantes."
 #. Tag: para
 #, no-c-format
@@ -40297,6 +40276,27 @@ msgstr "Polygone tessellé"
 msgstr ", <xref linkend=\"ST_DelaunayTriangles\"/>"
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -40351,11 +40351,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -49816,6 +49811,57 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Maintenance du robot de build, Build de production et expérimental pour "
+#~ "Windows, documentation, Alignement de PostGIS avec les publications "
+#~ "PostgreSQL, support X3D, support du géocoder TIGER, fonctions de gestion."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Améliorations des index, correction de bugs et améliorations des "
+#~ "fonctions geometry/geography, SFCGAL, raster, nettoyage de GitHub, "
+#~ "maintenance du robot de build."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Maintenance et correction de bugs, maintenance du robot de build, gestion "
+#~ "du miroir git, fonctions de gestions, intégration des fonctionnalités "
+#~ "GEOS et alignement avec les publications GEOS, support des topologies, "
+#~ "raster et fonctions de l'API bas-niveau."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Fonctions MapBox Vector Tile et GeoBuf. Tests Gogs et expérimentations "
+#~ "GitLab."
+#, no-c-format
+#~ msgid ""
+#~ "A <inlinemediaobject><imageobject><imagedata fileref=\"images/"
+#~ "matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject> means "
+#~ "the function support is provided by SFCGAL if PostGIS compiled with "
+#~ "SFCGAL support, otherwise GEOS/built-in support."
+#~ msgstr ""
+#~ "Un <inlinemediaobject><imageobject><imagedata fileref=\"images/"
+#~ "matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject> signifie "
+#~ "que le support de la fonction est fourni par SFCGAL si PostGIS a été "
+#~ "compilé avec le support SFCGAL, sinon le support GEOS/intégré."
 #, no-c-format
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 819dde241..2174effe5 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-10-14 20:23+0000\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -8017,13 +8017,10 @@ msgstr "Regina Obe"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
-"Manutenzione dei buildbot, compilazione pacchetti windows sperimentali e di "
-"produzione, allineamento dei rilasci di PostGIS con quelli di PostgreSQL, "
-"supporto X3D, support geocoder TIGER, funzioni di gestione."
 #. Tag: term
 #, no-c-format
@@ -8034,11 +8031,8 @@ msgstr "Darafei Praliaskouski"
 #, no-c-format
 msgid ""
 msgstr ""
-"Miglioramento degli indici, correzione di malfunzionamenti e migliorie nelle "
-"funzioni a supporto di geometrie/geografie, SFCGAL, raster, cura di GitHub e "
-"mantenimento bot."
 #. Tag: term
 #, no-c-format
@@ -8069,15 +8063,10 @@ msgstr "Sandro Santilli"
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
-"Correzione e manutenzione di bug, manutenzione di buildbot, gestione del "
-"mirror git, funzioni di gestione, integrazione di nuove funzionalità GEOS e "
-"allineamento con le release GEOS, supporto della topologia, framework raster "
-"e funzioni API di basso livello."
 #. Tag: title
 #, no-c-format
@@ -8100,6 +8089,16 @@ msgstr ""
 "distanza e relazione 3D), formato di output Tiny WKB (TWKB) e supporto "
 "generale agli utenti."
+#. Tag: term
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -8132,11 +8131,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
-"Funzioni MapBox Vector Tile e GeoBuf. Test su Gogs e sperimentazione su "
-"GitLab."
 #. Tag: term
 #, no-c-format
@@ -8661,11 +8658,6 @@ msgstr "Lars Roessiger"
 msgid "Leo Hsu"
 msgstr "Leo Hsu"
-#. Tag: member
 #. Tag: member
@@ -9885,19 +9877,6 @@ msgstr ""
 "che la funzione è disponibile solo se PostGIS è stato compilato con il "
 "supporto SFCGAL."
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
-"matrix_sfcgal_enhanced.png\"/></imageobject> </inlinemediaobject> significa "
-"che il supporto della funzione è fornito da SFCGAL se PostGIS è stato "
-"compilato con il supporto di SFCGAL, altrimenti GEOS/supporto incorporato."
 #. Tag: simpara
 #, no-c-format
@@ -27701,14 +27680,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: para
@@ -27735,6 +27706,14 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: para
@@ -33547,6 +33526,27 @@ msgstr ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -33594,11 +33594,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -40983,6 +40978,58 @@ msgstr "Supporta il 2.5/3D"
 msgstr "Supporta il tipo geography"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Manutenzione dei buildbot, compilazione pacchetti windows sperimentali e "
+#~ "di produzione, allineamento dei rilasci di PostGIS con quelli di "
+#~ "PostgreSQL, supporto X3D, support geocoder TIGER, funzioni di gestione."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Miglioramento degli indici, correzione di malfunzionamenti e migliorie "
+#~ "nelle funzioni a supporto di geometrie/geografie, SFCGAL, raster, cura di "
+#~ "GitHub e mantenimento bot."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Correzione e manutenzione di bug, manutenzione di buildbot, gestione del "
+#~ "mirror git, funzioni di gestione, integrazione di nuove funzionalità GEOS "
+#~ "e allineamento con le release GEOS, supporto della topologia, framework "
+#~ "raster e funzioni API di basso livello."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Funzioni MapBox Vector Tile e GeoBuf. Test su Gogs e sperimentazione su "
+#~ "GitLab."
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "matrix_sfcgal_enhanced.png\"/></imageobject> </inlinemediaobject> "
+#~ "significa che il supporto della funzione è fornito da SFCGAL se PostGIS è "
+#~ "stato compilato con il supporto di SFCGAL, altrimenti GEOS/supporto "
+#~ "incorporato."
 #, no-c-format
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index ba4d00ce9..d955393b2 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-11-06 05:23+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -8976,12 +8976,10 @@ msgstr "Regina Obe"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
-"Buildbotのメンテナンス、Windows版と試験版のビルド、ドキュメンテーション、"
-"PostgreSQLとの調整、X3D対応、Tiger Geocoder機能、関数管理。"
 #. Tag: term
 #, no-c-format
@@ -8992,10 +8990,8 @@ msgstr "Darafei Praliaskouskiさん"
 #, no-c-format
 msgid ""
 msgstr ""
-"インデックス改善、誤り修正とジオメトリ/ジオグラフィ関数の改善、SFCGAL、ラス"
-"タ、GitHubキュレーション、Botのメンテナンス。"
 #. Tag: term
 #, no-c-format
@@ -9024,14 +9020,10 @@ msgstr "Sandro Santilli"
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
-"誤り修正とメンテナンス、ビルドボットのメンテナンス、gitミラーの管理、関数管"
-"理、GEOSの新機能の統合、GEOSリリースとの調整、トポロジ機能、ラスタフレーム"
-"ワークと低水準API関数。"
 #. Tag: title
 #, no-c-format
@@ -9053,6 +9045,16 @@ msgstr ""
 "距離関数の強化 (3次元距離、関係関数を含む)と追加、Tiny WKB出力書式(TWKB)と"
 "一般的なユーザサポート。"
+#. Tag: term
+#, no-c-format
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -9085,9 +9087,9 @@ msgstr "Björn Harrtell"
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
-msgstr "MapBox Vector Tile関数とGeoBuf関数、Gogsの試験とGitLabの実験。"
+msgstr ""
 #. Tag: term
 #, no-c-format
@@ -9602,11 +9604,6 @@ msgstr "Lars Roessiger"
 msgid "Leo Hsu"
 msgstr "Leo Hsu"
-#. Tag: member
-#, no-c-format
 #. Tag: member
 #, no-c-format
@@ -10804,19 +10801,6 @@ msgstr ""
 "matrix_sfcgal_required.png\"/></imageobject></inlinemediaobject>は、PostGISを"
 "SFCGAL対応でコンパイルした場合にのみ利用可能な関数です。"
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
-"<inlinemediaobject><imageobject><imagedata fileref=\"images/"
-"matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject>は、PostGISを"
-"SFCGAL対応でコンパイルした場合には、SFCGALが提供し、その他の場合には、GEOSま"
-"たは組み込み関数で対応します。"
 #. Tag: simpara
 #, no-c-format
@@ -31365,16 +31349,6 @@ msgstr ""
 "のモードは、外部ラスタファイルが存在するファイルシステムの変更を目的としてい"
 "ます。"
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
-"内部的には、このメソッドは、存在するパス情報を更新する替わりに、PostGISラスタ"
-"の<varname>band</varname>で指定したバンドを新しいバンドに置き換えます。"
 #. Tag: para
 #, no-c-format
@@ -31406,6 +31380,16 @@ msgstr ""
 "の互換性 (例:アラインメント、ピクセル対応)確認のためのテストを行いません。こ"
 "のモードは、バンドが外部ラスタファイル内で移動する場所を対象としています。"
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+"内部的には、このメソッドは、存在するパス情報を更新する替わりに、PostGISラスタ"
+"の<varname>band</varname>で指定したバンドを新しいバンドに置き換えます。"
 #. Tag: para
 #, no-c-format
@@ -38669,6 +38653,27 @@ msgstr "テッセレーションを施したポリゴン"
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -38720,11 +38725,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -47709,6 +47709,52 @@ msgstr "2.5次元/3次元対応"
 msgstr "ジオグラフィ対応"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Buildbotのメンテナンス、Windows版と試験版のビルド、ドキュメンテーション、"
+#~ "PostgreSQLとの調整、X3D対応、Tiger Geocoder機能、関数管理。"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "インデックス改善、誤り修正とジオメトリ/ジオグラフィ関数の改善、SFCGAL、ラ"
+#~ "スタ、GitHubキュレーション、Botのメンテナンス。"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "誤り修正とメンテナンス、ビルドボットのメンテナンス、gitミラーの管理、関数"
+#~ "管理、GEOSの新機能の統合、GEOSリリースとの調整、トポロジ機能、ラスタフレー"
+#~ "ムワークと低水準API関数。"
+#, no-c-format
+#~ msgid ""
+#~ msgstr "MapBox Vector Tile関数とGeoBuf関数、Gogsの試験とGitLabの実験。"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "<inlinemediaobject><imageobject><imagedata fileref=\"images/"
+#~ "matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject>は、"
+#~ "PostGISをSFCGAL対応でコンパイルした場合には、SFCGALが提供し、その他の場合"
+#~ "には、GEOSまたは組み込み関数で対応します。"
 #, no-c-format
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index d5c56c52c..35a2356ea 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
 msgstr ""
 "Language-Team: Korean <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -8420,7 +8420,7 @@ msgstr "레지나 오베(Regina Obe)"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -8434,7 +8434,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: term
@@ -8460,10 +8460,9 @@ msgstr "산드로 산틸리(Sandro Santilli)"
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
 #. Tag: title
@@ -8486,6 +8485,16 @@ msgstr ""
 "거리 함수 개선(3D 거리와 관계 함수 포함) 및 추가 작업, TWKB(Tiny WKB) 출력 포"
 "맷(개발중), 개괄적인 사용자 지원을 담당"
+#. Tag: term
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -8516,8 +8525,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
 #. Tag: term
@@ -9026,11 +9035,6 @@ msgstr ""
 msgid "Leo Hsu"
 msgstr ""
-#. Tag: member
-#, no-c-format
-msgstr ""
 #. Tag: member
 #, no-c-format
@@ -10183,15 +10187,6 @@ msgid ""
 msgstr ""
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: simpara
 #, no-c-format
@@ -28853,14 +28848,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -28887,6 +28874,14 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -35626,6 +35621,27 @@ msgstr "다듬어진 폴리곤"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -35678,11 +35694,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index 2b56f5903..51c8759e2 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
 msgstr ""
 "Language-Team: Polish <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -7030,7 +7030,7 @@ msgstr "Regina Obe"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -7044,7 +7044,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: term
@@ -7070,10 +7070,9 @@ msgstr "Sandro Santilli"
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
 #. Tag: title
@@ -7094,6 +7093,16 @@ msgid ""
 "support"
 msgstr ""
+#. Tag: term
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -7124,8 +7133,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
 #. Tag: term
@@ -7627,11 +7636,6 @@ msgstr ""
 msgid "Leo Hsu"
 msgstr ""
-#. Tag: member
-#, no-c-format
-msgstr ""
 #. Tag: member
 #, no-c-format
@@ -8689,15 +8693,6 @@ msgid ""
 msgstr ""
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: simpara
 #, no-c-format
@@ -25431,14 +25426,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -25465,6 +25452,14 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -31249,6 +31244,27 @@ msgstr ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -31296,11 +31312,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index b0638b739..0141a5e6f 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
 msgstr ""
 "Language-Team: Portuguese (Brazil) <https://weblate.osgeo.org/projects/"
@@ -8536,7 +8536,7 @@ msgstr "Regina Obe"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -8550,7 +8550,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: term
@@ -8576,10 +8576,9 @@ msgstr "Sandro Santilli"
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
 #. Tag: title
@@ -8603,6 +8602,16 @@ msgstr ""
 "funções de relacionamento), Tiny WKB (TWKB) (em desenvolvimento) e suporte "
 "ao usuário geral."
+#. Tag: term
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -8633,8 +8642,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
 #. Tag: term
@@ -9149,11 +9158,6 @@ msgstr ""
 msgid "Leo Hsu"
 msgstr ""
-#. Tag: member
-#, no-c-format
-msgstr ""
 #. Tag: member
 #, no-c-format
@@ -10308,15 +10312,6 @@ msgid ""
 msgstr ""
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: simpara
 #, no-c-format
@@ -29177,14 +29172,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -29211,6 +29198,14 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -36035,6 +36030,27 @@ msgstr "Polígono tesselado "
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -36088,11 +36104,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index b453490c2..195f3c729 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
 msgstr ""
 "Language-Team: Romanian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -6990,7 +6990,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -7004,7 +7004,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: term
@@ -7030,10 +7030,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
 #. Tag: title
@@ -7054,6 +7053,16 @@ msgid ""
 "support"
 msgstr ""
+#. Tag: term
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -7084,8 +7093,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
 #. Tag: term
@@ -7584,11 +7593,6 @@ msgstr ""
 msgid "Leo Hsu"
 msgstr ""
-#. Tag: member
-#, no-c-format
-msgstr ""
 #. Tag: member
 #, no-c-format
@@ -8623,15 +8627,6 @@ msgid ""
 msgstr ""
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: simpara
 #, no-c-format
@@ -25240,14 +25235,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -25274,6 +25261,14 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -31058,6 +31053,27 @@ msgstr ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -31105,11 +31121,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index 634fc0f90..ff0ed6c2c 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-25 16:23+0000\n"
 "Language-Team: Russian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -6996,7 +6996,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -7010,7 +7010,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: term
@@ -7036,10 +7036,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
 #. Tag: title
@@ -7060,6 +7059,16 @@ msgid ""
 "support"
 msgstr ""
+#. Tag: term
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -7090,8 +7099,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
 #. Tag: term
@@ -7590,11 +7599,6 @@ msgstr ""
 msgid "Leo Hsu"
 msgstr ""
-#. Tag: member
-#, no-c-format
-msgstr ""
 #. Tag: member
 #, no-c-format
@@ -8644,15 +8648,6 @@ msgid ""
 msgstr ""
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: simpara
 #, no-c-format
@@ -25261,14 +25256,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: para
 #, no-c-format
@@ -25295,6 +25282,14 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -31079,6 +31074,27 @@ msgstr ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -31126,11 +31142,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 6f4aceb45..98c8b7d04 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Language-Team: Ukrainian <https://weblate.osgeo.org/projects/postgis/postgis-"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: term
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
 #. Tag: title
 "support"
 msgstr ""
+#. Tag: term
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
 msgstr ""
 #. Tag: term
 msgid "Leo Hsu"
 msgstr ""
-#. Tag: member
-#, no-c-format
-msgstr ""
 #. Tag: member
 #, no-c-format
 msgstr ""
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: simpara
 #, no-c-format
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 8b126731a..41d77dfc8 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-11-16 06:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
@@ -8381,12 +8381,10 @@ msgstr "Regina Obe"
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
-"Buildbot 维护、Windows 生产和实验构建、文档、PostGIS 与 PostgreSQL 版本的对"
-"齐、X3D 支持、TIGER 地理编码器支持、管理功能。"
 #. Tag: term
 #, no-c-format
@@ -8397,9 +8395,8 @@ msgstr "Darafei Praliaskouski"
 #, no-c-format
 msgid ""
 msgstr ""
-"索引改进、纠错和几何/地理功能改进、SFCGAL、栅格、GitHub 策展、机器人维护。"
 #. Tag: term
 #, no-c-format
@@ -8427,13 +8424,10 @@ msgstr "Sandro Santilli"
 #. Tag: para
 #, no-c-format
 msgid ""
-"functions."
 msgstr ""
-"Bug 修复和维护、buildbot 维护、git 镜像管理、管理功能、新 GEOS 功能的集成以及"
-"与 GEOS 版本的一致性、拓扑支持以及栅格框架和低级 API 功能。"
 #. Tag: title
 #, no-c-format
@@ -8455,6 +8449,16 @@ msgstr ""
 "距离函数增强(包括 3D 距离和关系函数)和附加功能、Tiny WKB (TWKB) 输出格式和"
 "一般用户支持"
+#. Tag: term
+#, no-c-format
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: term
 #, no-c-format
 msgid "Dan Baston"
@@ -8485,9 +8489,9 @@ msgstr "Björn Harrtell"
 #. Tag: para
 #, no-c-format
 msgid ""
-"experimentation."
-msgstr "MapBox Vector Tile和GeoBuf函数,Gogs测试和GitLab实验。"
+msgstr ""
 #. Tag: term
 #, no-c-format
@@ -8995,11 +8999,6 @@ msgstr "Lars Roessiger"
 msgid "Leo Hsu"
 msgstr "Leo Hsu"
-#. Tag: member
-#, no-c-format
 #. Tag: member
 #, no-c-format
@@ -10162,19 +10161,6 @@ msgstr ""
 "matrix_sfcgal_required.png\"/></imageobject></inlinemediaobject>表示该功能仅"
 "在使用 SFCGAL 支持编译 PostGIS 时可用。"
-#. Tag: simpara
-#, no-c-format
-msgid ""
-msgstr ""
-"matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject>表示如果 "
-"PostGIS 使用 SFCGAL 支持编译,则功能支持由 SFCGAL 提供,否则 GEOS/built-in支"
-"持。"
 #. Tag: simpara
 #, no-c-format
@@ -29636,16 +29622,6 @@ msgstr ""
 "和PostGIS栅格之间的兼容性(例如对齐、像素支持)。 此模式适用于外部栅格所在的"
 "文件系统更改。"
-#. Tag: para
-#, no-c-format
-msgid ""
-msgstr ""
-"在内部,此方法将索引<varname>band</varname>处的 PostGIS 栅格波段替换为新波"
-"段,而不是更新现有的路径信息。"
 #. Tag: para
 #, no-c-format
@@ -29677,6 +29653,16 @@ msgstr ""
 "和PostGIS栅格之间的兼容性(例如对齐、像素支持)。 此模式适用于在外部栅格文件"
 "中移动波段的情况。"
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+"在内部,此方法将索引<varname>band</varname>处的 PostGIS 栅格波段替换为新波"
+"段,而不是更新现有的路径信息。"
 #. Tag: para
 #, no-c-format
@@ -36585,6 +36571,27 @@ msgstr "细分多边形"
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr "可用性:3.5.0 - 需要 SFCGAL >= 1.5.0。"
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -36634,15 +36641,10 @@ msgid ""
 "algorithm does not guarantee a bound on the number of polygons produced with "
 msgstr ""
-"多边形 P 的一个划分是指一组多边形,这些多边形的内部不相交,"
-"并且这些多边形的并集等于原始多边形 P 的内部。一个 y-单调多边形是指其顶点 v1,…"
-",vn 可以划分成两个链 v1,…,vk 和 vk,…,vn,v1,使得任何水平线最多与其中一条链相"
-"交一次。该算法不能保证在产生的多边形数量上达到最优数量的界限。"
-#. Tag: para
-#, no-c-format
-msgstr "可用性:3.5.0 - 需要 SFCGAL >= 1.5.0。"
+"多边形 P 的一个划分是指一组多边形,这些多边形的内部不相交,并且这些多边形的并"
+"集等于原始多边形 P 的内部。一个 y-单调多边形是指其顶点 v1,…,vn 可以划分成两个"
+"链 v1,…,vk 和 vk,…,vn,v1,使得任何水平线最多与其中一条链相交一次。该算法不能"
+"保证在产生的多边形数量上达到最优数量的界限。"
 #. Tag: para
 #, no-c-format
@@ -36693,13 +36695,13 @@ msgid ""
 "Though the triangulation-based approximation algorithm often results in "
 "fewer convex pieces, this is not always the case."
 msgstr ""
-"并且这些多边形的并集等于原始多边形 P 的内部。CG_ApproxConvexPartition 和 "
+"集等于原始多边形 P 的内部。CG_ApproxConvexPartition 和 "
 "CG_GreeneApproxConvexPartition 函数生成近似最优的凸分割。这两个函数通过首先将"
-"多边形分解为更简单的多边形来生成凸分解;CG_ApproxConvexPartition "
-"使用三角剖分,而 CG_GreeneApproxConvexPartition 使用一个单调分割。这两个函数"
-"都保证它们生成的凸片段数不会超过最优数量的四倍,但它们在运行时复杂性上有所不"
-"同。尽管基于三角剖分的近似算法通常会产生较少的凸片段,但并非总是如此。"
+"多边形分解为更简单的多边形来生成凸分解;CG_ApproxConvexPartition 使用三角剖"
+"分,而 CG_GreeneApproxConvexPartition 使用一个单调分割。这两个函数都保证它们"
+"生成的凸片段数不会超过最优数量的四倍,但它们在运行时复杂性上有所不同。尽管基"
+"于三角剖分的近似算法通常会产生较少的凸片段,但并非总是如此。"
 #. Tag: para
 #, no-c-format
@@ -36725,8 +36727,8 @@ msgid ""
 "and <xref linkend=\"CG_OptimalConvexPartition\"/>)"
 msgstr ""
 "格林近似凸分割(与 <xref linkend=\"CG_YMonotonePartition\"/>、<xref linkend="
-"\"CG_ApproxConvexPartition\"/> 和 <xref linkend=\"CG_OptimalConvexPartition\""
-"/> 相同的示例)"
+"\"CG_ApproxConvexPartition\"/> 和 <xref linkend=\"CG_OptimalConvexPartition"
+"\"/> 相同的示例)"
 #. Tag: para
 #, no-c-format
@@ -36755,9 +36757,9 @@ msgid ""
 "interior of the original polygon P. CG_OptimalConvexPartition produces a "
 "partition that is optimal in the number of pieces."
 msgstr ""
-"并且这些多边形的并集等于原始多边形 P 的内部。CG_OptimalConvexPartition "
-"生成的划分在片段数量上是最优的。"
+"集等于原始多边形 P 的内部。CG_OptimalConvexPartition 生成的划分在片段数量上是"
+"最优的。"
 #. Tag: para
 #, no-c-format
@@ -36805,9 +36807,9 @@ msgstr ""
 "或许是直线骨架的最早应用案例之一:给定一个多边形屋顶,直线骨架直接提供了每个"
 "建筑物的布局。如果将每个骨架边沿其偏移距离从平面抬升到相应的高度,得到的屋顶"
 "是“正确”的,因为水将始终流向轮廓边缘(屋顶的边界),无论它在屋顶的哪个位置下"
-"落。该函数计算多边形的这种挤出,又称“屋顶”。如果参数 body_height > 0,"
-"则多边形就像使用 ST_Extrude(polygon, 0, 0, body_height) "
-"一样挤出。结果是这些多面体表面的并集。"
+"落。该函数计算多边形的这种挤出,又称“屋顶”。如果参数 body_height > 0,则多边"
+"形就像使用 ST_Extrude(polygon, 0, 0, body_height) 一样挤出。结果是这些多面体"
+"表面的并集。"
 #. Tag: para
 #, no-c-format
@@ -45150,6 +45152,50 @@ msgstr "2.5/3D 支持"
 msgstr "支持地理"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Buildbot 维护、Windows 生产和实验构建、文档、PostGIS 与 PostgreSQL 版本的"
+#~ "对齐、X3D 支持、TIGER 地理编码器支持、管理功能。"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "索引改进、纠错和几何/地理功能改进、SFCGAL、栅格、GitHub 策展、机器人维护。"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Bug 修复和维护、buildbot 维护、git 镜像管理、管理功能、新 GEOS 功能的集成"
+#~ "以及与 GEOS 版本的一致性、拓扑支持以及栅格框架和低级 API 功能。"
+#, no-c-format
+#~ msgid ""
+#~ msgstr "MapBox Vector Tile和GeoBuf函数,Gogs测试和GitLab实验。"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject>表示如果 "
+#~ "PostGIS 使用 SFCGAL 支持编译,则功能支持由 SFCGAL 提供,否则 GEOS/built-in"
+#~ "支持。"
 #, no-c-format
Summary of changes:
 doc/po/de/postgis-manual.po      | 151 +++++++++++++++++++++------------
 doc/po/es/postgis-manual.po      | 134 ++++++++++++++++++-----------
 doc/po/fr/postgis-manual.po      | 156 ++++++++++++++++++++++------------
 doc/po/it_IT/postgis-manual.po   | 151 +++++++++++++++++++++------------
 doc/po/ja/postgis-manual.po      | 146 +++++++++++++++++++++-----------
 doc/po/ko_KR/postgis-manual.po   |  83 ++++++++++--------
 doc/po/pl/postgis-manual.po      |  83 ++++++++++--------
 doc/po/pt_BR/postgis-manual.po   |  83 ++++++++++--------
 doc/po/ro/postgis-manual.po      |  83 ++++++++++--------
 doc/po/ru/postgis-manual.po      |  83 ++++++++++--------
 doc/po/uk/postgis-manual.po      |  83 ++++++++++--------
 doc/po/zh_Hans/postgis-manual.po | 178 ++++++++++++++++++++++++---------------
 12 files changed, 871 insertions(+), 543 deletions(-)
hooks/post-receive
